This is a discussion thread titled "Anyone have Tundra/Tacoma Front Differential knowledge?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-21-2005, 10:46 PM
Mike Donofrio's Avatar
Dealer : Gateway Toyota
Last Online: 01-14-2008 05:40 PM
Mike Donofrio is on a distinguished road.
Mike Donofrio's Photo Albums
Default Anyone have Tundra/Tacoma Front Differential knowledge?
Okay gang, many of you may know that for the past several months I've been doing a Front Locker test fit that has proved largely fruitless. If we are ever going to get a front locker application for our trucks, I am going to need some help from you all.
I first tried the Lock Right 1611 which is made for Tacoma front diffs (27 spline, 7.5" ring gear) and the application guide on Powertrax's website lists it for:
86-00 4Runner
86-95 Pickup
93-98 T-100
95-99 Tacoma
http://www.powertrax.com/toyotalr.pdf
The Detroit/Tractech people list a similar application restriction:
http://www.tractech.com/docs/TT-List-LTPM1004.pdf
Here's where it gets confusing. When installing the 1611 in the front Diff of the Tundra, we are left with 1/2 gap where the half-shaft meets the front diff. The feeling is that the different axle shafts for the Tundra (and for the 00 Tacoma for some reason?!?!) are different, event though they have the 27 spline, 7.5 ring gear!
The locker installs just fine and you can take it out and beat the death out of it, but you have a gap and eventually water and mud will get in, so this is really a short term solution to the weak front diff.
Here are some questions for the Tacoma/Tundra owning public, perhaps you can help:
-What is the difference in the front diff between an 00 and a 99 Tacoma that makes the 1611 not a direct fit for the Tundra?
-What is so different about the front axles between the Tundra 27 spline shaft versus the Tacoma 27 spline shaft? (apart from the obvious length) that makes it not install fully into the diff?
http://home.4x4wire.com/erik/diffs/
AFAIK there are three Tundrasolutions members that have done this install and all have reported the same problems. Somewhere out there, someone knows the answer, if you drive a Tundra and you 'wheel it--you will likely come to appreciate the work being done so we can get a front locker. Anyone having insights here would be much appreciated.
Mike D
Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/lockrite.htm
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
Old 06-27-2005, 05:30 PM
Dealer : Quesnel Toyota
2005 Toyota Tundra
Last Online: 12-05-2008 10:03 PM
tacodriver2 is on a distinguished road.
tacodriver2's Photo Albums
Hi Mike,
Don't know if I can help you...is the gap the same on both half shafts or only on one side. I thought that the tundra and Tacoma diffs were identical. I have a spare front diff from my 01 taco that I was planning on regearing and installing on my tundra when I get it. Hope someone else chimes in.
86-00 4Runner
86-95 Pickup
93-98 T-100
95-99 Tacoma
Old 06-27-2005, 05:40 PM
Originally Posted by tacodriver2
Hi Mike,
At this point, ANY info would be helpful!
As you will notice on mater model (ADD equipped) Toyota front diffs. The housing is extended on the passenger side of the diff to accomodate the ADD, you wouldn't be able to see the shaft on the driver's side due to this but you can assume it's the case. Odd thing is, the ARB has the same product for both diffs (Tundra and Taco) so a 'universal fit' should be possible. I've heard that the Tundra model uses needles bearings whereas the Taco one doesn't, but no confirmation yet.
Mike D
Old 06-29-2005, 04:24 PM
2005 Toyota Tundra
Have you tried to slide in the half shaft into the diff while it is all off the truck? Is the retainer clip pointed in the right direction when you slide the shaft in? Just some thoughts, though I am sure you have already tried.
Just FYI I changed my 2001 front diff (4.10) to a used one from a pre 98 I believe, that already had 4.88 set up. The shafts fit fine. Wish I could be of more help.
Bookmarks
Similar Threads for: Anyone have Tundra/Tacoma Front Differential knowledge?
Double Cab Lift = Destroyed Front Diff?!? Dirt_dont_Hurt Suspension & Axle 33 02-04-2006 01:31 AM
What is your driving condition like in the snow? PagalDesi4Life 1Gen-Sequoia 34 08-23-2005 12:37 PM
POWERTRAX, or ARB AIR-LOCKER users chime in wylcat Engine & Drivetrain 41 06-29-2004 11:56 AM
Shocks and front springs Evel Suspension & Axle 4 05-19-2004 09:10 AM
Front hubs wont' disengage?? shermanct Engine & Drivetrain 4 10-01-2003 03:23 PM
