This is a discussion thread titled "check engine light?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
For all those that have experienced this problem On the check engine light going off what were your problem's? Mine deceided yesterday to go off and I tend to beleive it's the O2 sensor i've been reading in the forurms if that's the case when your o2 sensor is going bad what problem's do you look for because My engine has been running fine
T3 Grill, Line X extra front Bumper coating (too many mod's to list)
The first time mine was the o2 sensor right bank. The about a week later the dam light came on again, I was like mother ******!!!!!!!! Ran the code it was fuel evac, which is unscrew you gas cap and put it back on. (worked for me!) Tank pressure was low.
If your light dosen't go off in a day or two try a new gas cap.
Plus... if you're in a county that uses that new "inspection system" at 30-friggin'-dollars a pop... PER VEHICLE, PER INSPECTION , it probably WON'T pass inspection anyway, until you fix the damn thing!
I won't get on my soapbox here over this, but suffice it to say, IMHO this "new" computer inspection set-up bull$hit is... JUST F$@* WRONG!!!
Nuf said... .
__________________ 2004 SR5 Double Cab 4x4 w/TRD Pkg. Mods to Date:
16" 5 Spoke Brawn Enkei Wheels, Keyless Entry, Line-X Bed Liner, Challenger Running Boards, Husky Floor Liners, Bug Flector II (painted to match), Colegan Bra, Borla Dual (Side-Exit) Exhaust System, 2" Wheeler's Coil Lift, TRD Add-A-Leafs Mods to Come:
265/75/16 BFG A/T's, Possible Mods:
I just got back from my Indendant service dept shop and he just hooked the OBD tool in and found an error code on bank number two (oxy sensor) or the cat could be going bad as well .I was informed it would be around $150 which is not that bad consiring he did great work on my engine Timing belt's project...I Love this shop vs the Toyota stealership's
seem's there are a lot of unhappy tundra owner's on this topic Mine lasted a wile (118k) so I am not complaining and replacing all oxygen sensor's in mine just to insure no more problem's come out of this..
Yeah you can say that again. There is definitely a few unhappy tundra owners on this topic. Since buying my truck I had the check engine light come one once. The culprit was a bad/clogged MAF and bad 02 sensor. Took it into the dealership two days later, so don't know about gas mileage but the truck had trouble starting and shifting. Unfornately I did not get as much mileage out of my sensors as you did. about 21,000 miles
2003 Tundra Imperial Jade TRD offroad Performance modifications
2.5 Camburg C/O w/ King 14" 600lb springs, Skidrow Automotive Skidplate
285x75x16 Goodyear Wrangler ATS, 16x8 Ivan Stewart Wheels
4.30 ring and pinion gears, Stock exhaust w/ Magnaflow 18" muffler, TrueFlow filter, Superlift TruSpeed Cosmetic modifications
Debadged, De-decaled and De-labeled sun visors
Pace Edwards Retractable Cover, Toyota Sport Grille
TRD radiator cap, TRD oil cap
RS 3200 Plus Upgrade Modification wishlist
TRD or JBA titanium headers
JBA or possible custom y-pipe
TRD supercharger
IPT valve body mod
Custom Offroad Bumper
Demello offroad sliders
rear disc conversion
Moonroof and power sliding rear window
Where does it ever end
Nuf said... .
dang Dave.....somebody musta struck a nerve!
__________________ HAVE YOU DRIVEN OVER A FORD LATELY?
Team West SAWS (cranked up to 3.25")
Total Chaos UCA
ORS Manual hub kit
reese front receiver hitch
10,000 lb. winch on receiver hitch
Warn Quick connects front and rear
rear brake porportioning valve mod
3" perfomance products body lift
skyjacker AAL
wheelers urithane kit for front swaybar and steering rack
BFG AT's
Eagle101 wheels
CB radio W/ dual fiberglass 48" ant.
Nuf said... .
Come on Dave dont be shy say what you think ----Know what your talking about--we have the same thing. The only good thing is they just inspect the safety items on motorcycles----buts its today---not tomorrow yet ---Buzz
Nuf said... .
Think on the bright side somebody is making money out of it surely ain't me
dave did you have your coffee this morning just kidding my friend
ERIK
The check engine light came on in my 05 Tundra at about 7000kms, I didn't notice any difference in performance or the way it was running. It was the right rear O2 sensor. After I got it replaced about an hour later the light came on again. Got it checked and it was the right front 02 sensor this time. Got that one replaced an it has been fine so far.
even the new tundra with vvti are doing this great somethings never change It figures I haven't seen much changes since it came out other then the new vvti upgrades based on the same engine for 2005....
