Old 06-07-2002, 07:08 PM
pdc pdc is offline
Last Online: 06-10-2003 05:51 PM
pdc is on a distinguished road.
pdc's Photo Albums
Default Propeller shaft bolt
The manual says re-torgue the propeller shaft bolt, is it actually one bolt or all the bolts?
Old 06-07-2002, 08:40 PM
Dealer : Stevens Creek Toyota
Last Online: 08-16-2009 10:56 AM
akauth will become famous soon enough.
akauth's Photo Albums
Default Re: Propeller shaft bolt
They want you do check all the bolts.
As a tip, after you torque them (check), mark the bolts and nuts with a yellow marking pen (not magic marker, of course - permanent) so that you can see if the bolts/nuts move at all. That way when you grease the axle, you can do a visual check and make sure the none of your nuts are moving (loosening).
Actually, it's a good idea to run through and check and mark the other nuts too on the frame/suspension from time to time. They don't usually come loose, but they do come loose.
I had a frame bolt come loose on another vehicle (Ford "Exploder") and it made a slamming sound when you backed up the vehicle (actually changed direction, didn't matter which way you were heading intitially).
Alan
Old 06-07-2002, 08:56 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
On the 4wd only, two center support bearing bolts @ 30 ft-lbs, & sixteen flange yoke bolts @ 54 ft-lbs.
Ken
Old 06-07-2002, 10:50 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:02 AM
nhparrot's Photo Albums
pdc - see http://www.tundrasolutions.com/forum...&threadid=1662
~Glenn
Old 06-10-2002, 11:27 AM
cappi's Avatar
Dealer : Spitzer Toyota
2001 Toyota Tundra,
2006 Toyota Sequoia
Last Online: 11-17-2007 11:40 AM
cappi is on a distinguished road.
cappi's Photo Albums
Default yeh but...
I know I'm being picky here but there are also 4 companion flange bolts. Shouldn't they be retorqued also. For all intensive purposes they act the same as the flange yoke?
Old 06-10-2002, 11:54 AM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
On a 2WD vehicle there are 6 bolts to check (4 flange & 2 center support bearing) on the 4WD there are 18 bolts to check (16 flange & 2 center support bearing)
~Glenn
Old 06-11-2002, 10:07 AM
cappi's Avatar
2001 Toyota Tundra,
2006 Toyota Sequoia
As far as the 16 flange yoke and 2 center support bearing bolts, I have read the info in the garage and completely agree.
But is there a reason they do not include the 4 bolts on the companion flange to be retorqued? It would bring the total to 16, 2, and 4. No big deal, I just thought it was strange that the service notes did not include them.
Old 06-11-2002, 10:35 AM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
Cappi - you are right, I miscounted when I built the page - there are a total of 22 bolts. I will updated the page.
~Glenn
