JBA noise????
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Thread: JBA noise????
  1. #1
    Supporter cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13 would rather be driving his reputation. cleanb13's Avatar
    Join Date
    Mar 2003
    Location
    Putnam, CT
    Age
    38
    Posts
    624
    Liked
    1 times
    Images
    27
    Rep Power
    706
    Default JBA noise????
    For those who installed JBA's, can you hear exhaust noise (more when your windows are up?) I used the JBA gaskets and torqued down the nuts twice since installation and it still makes an exhaust leak sound. It's not the same noise as a cracked manifold- it's more like air rushing through the tubes. I hate to take the them apart to replace the gaskets with factory ones but I will if I have to. I should have straight edged the flanges before installation but I didn't.
    2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 BFG AT KO on Wheeler's black alloys, True Flow intake tube with Amsoil Air Filter, JBA titanium coated headers, Magnaflow Magnapack 10426 with stainless steel pipes and resonator removed, Skidrow front skidplate with custom made aluminum side shields, extended rear diff breather hose, Hawk LTS brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Downey Offroad front swaybar link kit and cv joint boots,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Viair 300P air compressor, blacked out mouldings, bumpers and grille emblem
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member dezert_rida is on a distinguished road.
    Join Date
    Jan 2004
    Location
    Oceanside,CA
    Posts
    706
    Liked
    0 times
    Rep Power
    10
    Quote Originally Posted by cleanb13
    Some headers sound tinny. The exhaust is moving faster through the headers primaries, than the stock manifolds. If thats all your hearing, your fine. If you dont know how to properly check for a leak, take it to someone that does.
  4. #3
    Junior Member triggs75 is on a distinguished road. triggs75's Avatar
    Join Date
    May 2004
    Location
    Pomona, CA
    Age
    39
    Posts
    362
    Liked
    0 times
    Rep Power
    9
    I had the same question about a month or so ago, and yes you do hear the exauhst alot more and with the windows shut. I posted about the same question also.
    chad
    2004 V8 TRD Offroad package SR5 4x2 Access Cab
    STEREO MODS: Pioneer 8600 headunit | jl 250/1 amp | Alpine 320/2 amp | kicker 65/2 door speakers | 2x 8" punch 2's in Q-Logic box under seat | XM pioneer gex-910 radio tuner | Harmon Kardon Plug and Play | Street wires set up | & dynamat
    Exterior Add-ons:2.5" King Coilovers | 4.5" TC Lift | Bilstein 5100 Rear shocks | AAL Rear | 4" rear block | 315/70/17 BFG AT's | 17x9" Boze Fatal's 3 5/8" B.S. | Custom steering shaft | Extended driveshaft | JBA Headers | Mangnaflow 14" muffler | Front Grille | Advance Cover | Bed Mat | Challenger Running boards | Window Tints | Debadged | AMI Antenna | Temp & Comp. rear view mirror | TRD oil & Radiotor caps | Clear Corners | X51 Fatboy Bulbs & IPF Wiring Harness | Backup Sensors
    Recently Added:ARB Airlocker with 4.56 gears.
  5. #4
    Supporter Rlockyer is on a distinguished road. Rlockyer's Avatar
    Join Date
    Nov 2002
    Location
    CA
    Posts
    1,593
    Liked
    0 times
    Rep Power
    12
    If you've got a leak, you'll probably know it.
    Years ago, my ex felt left out when I was working on the Camaro and wanted to help, so after changing the plugs, I had her torque down the headers (ya, I had to pull the headers to change plugs).
    I asked her 5 times if they were tight. Yup.
    Okay... turned the key and it sounded like a machine gun
    She never asked to help on the car again.
    2008 Tacoma 2.7 RC Base
    2003 SR5 TRD V8 <<< Sold 2005
    Better Built toolbox / Limited leather / Power outlet mod / RS3200 Plus / Rebadged w/TRD / Bully Nerf bars / '05 OEM Taillights / Clear corners / Factory Woodgrain kit / Gentex EC Mirror / Gaylord's Toolbox-Lid / MB Overdrives / Muthco Signal Mirrors / Sport Grille / TRD Dual Exhaust / Camry Nav System
  6. #5
    Guest mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch.
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    6,007
    Liked
    29 times
    Blog Entries
    4
    Rep Power
    0
    Look where the steering column goes thru the floor. There is a rubber grommet there. It is probably torn or worn out. The exhaust exits very near this under the truck and there is a tendancy for you to hear the exhaust rushing out the pipe with the windows up.
    The headers do create a kind of tinny sound, but the JBA gaskets are adequate, factory ones would have been better.
    I'd check the steering shaft groomet before i tore it apart to change gaskets that are probably ok.
  7. #6
    Supporter tundrafire is a splendid one to behold. tundrafire is a splendid one to behold. tundrafire is a splendid one to behold. tundrafire is a splendid one to behold. tundrafire is a splendid one to behold. tundrafire is a splendid one to behold. tundrafire is a splendid one to behold. tundrafire is a splendid one to behold. tundrafire is a splendid one to behold. tundrafire is a splendid one to behold. tundrafire is a splendid one to behold.
    Join Date
    Jun 2002
    Location
    La Mesa, CA
    Age
    46
    Posts
    410
    Liked
    0 times
    Rep Power
    26
    Check the alignment of the gasket at the collector. If it's the slightest bit off, you'll hear a "ticking" type sound.
    Dark charcoal gray CST leather, Wheeler's coils w/ HD Bilsteins, BFG 265/70/R17 A/Ts on 17x8 Boyd's, factory DVD RSE system, tinted windows, black OEM all-weather floor mats, BedBolts hooks in the center of the bed (dog anchors), an OEM rubber bed mat, VSE Subwoofer, K&N FIPK, JBA Titanium coated headers, Spintech 3333 Sportsman muffler..........so far.
    Coming Soon: Line-X, maybe a billet grill.
    Vehicles/Toys
    2005 Toyota Tundra DC 4x4 SR5
    2002 Toyota Epic S22 V-Drive Wakeboard Boat
    2002 Honda Accord V6
    1996 Harley Davidson FLSTN
  8. #7
    Junior Member JeffD is on a distinguished road. JeffD's Avatar
    Join Date
    Jul 2002
    Location
    Jupiter, Fl
    Age
    40
    Posts
    417
    Liked
    0 times
    Rep Power
    11
    Mine seem to do that too, I hear it with the windows down echoing off things, but I can't find any evidence of a leak. If mine is leaking it would definately not be at the head. Maybe at the collector on the passenger side. I think my old truck sounded the same way with the same headers. I remember thinking I should check it for a leak, but with all the miles I had I figured it wasn't worth pursuing.
    2000 4x4 LTD AC Sunfire Red - Sold w/ 200K
    2005 4x4 LTD AC Phantom grey w/ dark grey - Sold w/ 20K
    Alpine CDA-9835, W/ KCA-420i, Focal 165KP front, Focal 165V Rear speakers. powered by 2 MMats SQ2150 amps. Alpine MRD-M501 powering a JL Stealthbox with Infinity Perfect 10D VQ
    Sound deadened everything with Cascade VB2HD, and Dynamat Extreme
    2005 G35 Sedan 6MT - Returned due to paint work on a 'new' car.
    2006 G35 Sedan 6MT - all stock. Where do I hook up the trailer and where's the bass?
  9. #8
    Junior Member Diablo is on a distinguished road. Diablo's Avatar
    Join Date
    Nov 2002
    Location
    Fort Worth, Texas
    Age
    48
    Posts
    213
    Liked
    1 times
    Rep Power
    11
    My JBAs do that too. I like it now. At first, I thought it sounded like an exhaust leak but it is just the sound of the headers and the gases rushing through them. Now, I think it's cool. I get horrible gas mileage with the 295s so I like to at least hear it when it is burning gas. I have JBA headers, an AEM brute force intake, Tuff Country lift with Bilstein adj. coilovers, and 295/75/16s. The headers and intake helped a lot with getting some of the power back. The AEM really makes some noise, which I like. The headers were a great addition too and the noise they make is fine with me.
  10. #9
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    6,007
    Liked
    29 times
    Blog Entries
    4
    Rep Power
    0
    Quote Originally Posted by Diablo
    Ever thought of RE-GEARING to help get your power & fuel mileage back?
  11. #10
    Join Date
    Nov 2002
    Location
    Fort Worth, Texas
    Age
    48
    Posts
    213
    Liked
    1 times
    Rep Power
    11
    Quote Originally Posted by mustang67408
    Yes, I would love to. I still need new chrome wheels and to get rid of this stock muffler first. The regearing seems to be around $1K or so from what I've read here. That's pretty steep for the time being but I am sure that I'll do it at some point. Thanks for the tip.
  12. #11
    Lurking Member Eride33 is on a distinguished road. Eride33's Avatar
    Join Date
    Jul 2004
    Location
    Aurora, CO
    Posts
    41
    Liked
    0 times
    Rep Power
    9
    Mine is doing the same thing. Mine seems like it is on the right hand bank. I used all JBA gaskets and the left collector may be off a bit. I do have a ticking sound under acceleration. If i unbolt the collector, will i have to use a new gasket or will that one work. I did the install yesterday and just now rechecking everything so they havent been on for a while but something is not right
    '01 Tundra... 4in. suspension lift, custom modern 16in. wheels, 285/75/R16 BFG AT's. Debadged, Westin Ultimate bull bar and nerf bars. Helping the IForce 4.7L is a K&N FIPK intake system and a flowmaster with 3in. from cat back with 3 1/2in. tip.
  13. #12
    Supercharged Member MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER has blessed us with their presence. MOREPOWER's Avatar
    Join Date
    Dec 2004
    Location
    NEXT TO A THIEF!!!
    Posts
    2,094
    Liked
    0 times
    Rep Power
    40
    its the sound you hear when you have headers, my new jba headers do it but its not very loud, i had a 302 mustang with steel headers and it was very noticeable
  14. #13
    Obama lies ~ the economy dies H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN has mentally logged off-topic. H2O_MAN's Avatar
    Join Date
    Jul 2003
    Location
    USA
    Age
    52
    Posts
    5,694
    Liked
    77 times
    Rep Power
    12638
    No noise from mine.
    I used all Toyota gaskets and have maybe
    350/400 miles on them and they are quiet.
    2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
  15. #14
    Junior Member hirschg is on a distinguished road. hirschg's Avatar
    Join Date
    Dec 2003
    Location
    Pittsburgh, Pa.
    Posts
    72
    Liked
    0 times
    Rep Power
    0
    Question
    I'm ready to have my new JBA Headers installed and I'm going to use toyota gaskets but is it really necessary to use all toyota studs and nuts I priced them and it is over 50.00 I can see the gaskets making a differance but what is wrong with using the hardware that came with the JBA headers?
    hirschg
  16. #15
    Supporter LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002 is a pinnacle in their own mind. LGL002's Avatar
    Join Date
    Jan 2003
    Location
    Plymouth, MN
    Age
    72
    Posts
    2,196
    Liked
    9 times
    Images
    17
    Rep Power
    1317
    Quote Originally Posted by hirschg
    hirschg
    Generally it is just easier to slip the header flange over studs than to try hold it in place while trying to thread bolts into the head. Some members have reused the old nuts and I haven't heard about any problems doing that. You don't have to remove or replace the factory studs unless you are going to use the JBA bolts or if they are damaged. I'd rather use the factory studs and it's my choice to use new nuts to be sure they stay snug after retightening them after the first warm up.
    Larry
    2003 Camry SE V6 Navigation, Sirius, Lunar Mist
    Optima 34R battery
    Turn signals are meant to indicate intent not result.
  1. engine noise
    By nhparrot in forum Engine & Drivetrain
    Last Post: 02-27-2011, 08:11 AM
  2. Wind Noise Over 80MPH
    By paulhw69 in forum Tacoma
    Last Post: 04-05-2009, 01:39 PM
  3. Belt Noise
    Last Post: 05-11-2006, 04:31 PM
  4. Sun Roof has a rattling Noise at 40+ MPH
    By devillar in forum 1Gen-Sequoia
    Last Post: 03-09-2005, 12:24 PM
  5. Grinding exhaust noise?
    By mr_tundra in forum Engine & Drivetrain
    Last Post: 10-28-2003, 04:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
