This is a discussion thread titled "Unusual Problem - Oil in Radiator", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 07-25-2005, 05:42 PM
Last Online: 01-26-2008 01:18 AM
ciresmis is on a distinguished road.
ciresmis's Photo Albums
Default Unusual Problem - Oil in Radiator
My truck quit the other day, and I found oil in the radiator. There was no oil in the block and no oil on the dipstick but no water residue either. The engine turns over but does not start. I cannot get my code reader to work apparently because the motor never started running. I'm not sure. I had it towed to my home. Another inspection found some oil in the block. I then had it towed to my mechanic this morning. He said there was no oil in the radiator at all, but the block was a quart low. He thought it might be the oil cooler, but he found no oil in the radiator and no oil residue in the radiator at all. The fuse had blown that controlled the fuel injectors, but replacing it had no effect. I have had the fuel pump replaced, and he thought that might be the problem. He also thinks it may be a computer issue. He will do more tomorrow to find out. In the meantime I was wondering if anyone had any suggestions I could pass along to him. I drive a 2000 Tundra V-8 2WD. 115K miles. Two oxygen sensors were out and were scheduled to be replaced later this month. Thanks in advance for any guidance concerning this problem. - Eric
Old 07-25-2005, 06:08 PM
basian99's Avatar
Dealer : Champion Toyota Scion of Austin
2003 Toyota Tundra
Last Online: Yesterday 11:55 AM
basian99 is on a distinguished road.
basian99's Photo Albums
I'm no mechanic but every time I've seen something like that it's been a head gasket
Old 07-25-2005, 07:42 PM
Tundra_DC's Avatar
Dealer : Sand Mountain Toyota
2007 Toyota Tundra double cab SR5 5.7,
2008 Toyota Sienna
Last Online: Yesterday 09:51 AM
Tundra_DC is on a distinguished road.
Tundra_DC's Photo Albums
Eric,
Really hard to say. if you didn't see any oil on the dipstick, usually means it was lower than a quart. usually if you cracked a head or head gasket the oil should look milky. Not sure if the timing belt was changed at 90k , if it has never been changed, It could very well have slipped timing? If you are blowing fuses could be something in the electrical. Really hard to say without seeing it myself. Good luck, I hope it is nothing major.
Bookmarks
Similar Threads for: Unusual Problem - Oil in Radiator
Lowest Oil pressure question akauth Engine & Drivetrain 10 08-13-2007 05:51 PM
Oil changes Cloud9 Engine & Drivetrain 28 04-25-2007 04:00 AM
Oil Filter Change nhparrot Engine & Drivetrain 7 02-07-2006 08:33 PM
Idiots left oil plug off! (long) justagirl Engine & Drivetrain 11 07-14-2003 06:24 PM
Need help on oil types and quantity (Repost from old TS) nhparrot Engine & Drivetrain 0 03-28-2002 02:41 PM
