Old 07-31-2005, 08:00 PM
Yallrun's Avatar
2007 Toyota Tacoma X-Runner
Last Online: 08-13-2009 04:39 PM
Yallrun is on a distinguished road.
Send a message via AIM to Yallrun Send a message via MSN to Yallrun Send a message via Yahoo to Yallrun Yallrun's Photo Albums
Default No response at gas pedal
I was just coming home from the store, stopped at a stop sign in the mashed the gas to go, but just idol'd threw the intersection. Mashed the gas almost to the floor still nothing, kept mashing it them boom truck took off. WTF? Did this all the way home and check engine light came on! Anyone have any idea what's going on?
Thanks,
John
2007 X-Runner
Bring back Dave Peters. lol
Old 07-31-2005, 08:01 PM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
Last Online: 11-06-2009 11:33 AM
Images: 2
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch RitcheyRch's Photo Albums
Mines been doing the same thing except no check engine light.
Old 07-31-2005, 09:13 PM
Dealer : McGeorge Toyota
2004 Toyota Tundra
Last Online: 06-04-2008 08:56 PM
Xtrema is on a distinguished road.
Xtrema's Photo Albums
Partially clogged exhaust?
Old 07-31-2005, 10:20 PM
Genthar's Avatar
Last Online: 11-05-2009 09:51 PM
Genthar is on a distinguished road.
Genthar's Photo Albums
Throttle position sensor would be my guess...Some people have reported similar symptoms in the past and it turned out to be the TPS.
Genthar
Old 07-31-2005, 10:37 PM
AC's Avatar
AC AC is offline
Dealer : American Toyota
2000 Toyota Tundra,
- Other - Porsche Cayenne S
Last Online: 10-25-2009 10:41 AM
AC is on a distinguished road.
AC's Photo Albums
Default Yup
That's it. Had the same problem a year ago. Changed the TPS and all is good again. There is a thread around under something that I forget now. I think I payed around $275. for the part.
Old 07-31-2005, 10:58 PM
RitcheyRch's Avatar
Fellow Tundra Owner
2002 Toyota Tundra
Images: 2
I was thinking the same thing. Now if I knew where that stupid thing was and if is difficult to change.
Old 08-01-2005, 09:33 AM
Yallrun's Avatar
Thanks guys, I'll toss a new TPS on it. I reset computer and it's fine now, but I'm sure it will return.
Thanks again,
John
2007 X-Runner
Old 08-01-2005, 04:16 PM
Banned
Last Online: 04-10-2007 06:15 PM
P07r0457 is on a distinguished road.
P07r0457's Photo Albums
I've noticed that my 2005 doesn't respond quickly under WOT... However, if I move the pedal 50-75% of the way, it screams... It's part of the electronic throttle (as opposed to the mechanical throttle cable, that it replaced) and the computer's attempt to improve mpg, and even out driving.
Old 08-03-2005, 09:02 AM
mitchr's Avatar
Dealer : Phil Bachman Toyota
Last Online: 10-28-2009 11:01 AM
mitchr is on a distinguished road.
mitchr's Photo Albums
Thanks again,
John
On the Tundra's there are 2 posibilities but more than likely it is the Throttle Pedal Sensor not the the Throttle Position Sensor that has gone bad. I had the exact same symptoms when mine went out. I installed it myself in about 15 minutes. On the 2000 it is located on the passenger side of the throttle body. It might be under the accelerator pedal on a 2001 but I am not sure I know they moved it there on later models. Also your sensor will go out again and mine ran fine for a couple of weeks before it went out again. I would take it and get the code ran to be certain and then fix it because it might not start working again next time Good Luck.
Mitch
Old 08-03-2005, 06:44 PM
AC's Avatar
AC AC is offline
2000 Toyota Tundra,
AC's Photo Albums
Default Correction
It's actually called the Throttle Lever Assembly(TLA)if you will. This is the Toyota part number 22060-50011 at least for the 00. There's a couple of pics here if it helps. 3 bolts, 10 min like Mitchr, said.
AC
TRD Supercharger
ASP od pulley
Supra TT Fuel Pump
Hellwig Antisway-bar
Magnaflow Single Exit Exhaust
SS Autochrome Shorties w/JetHot 2000
Cornbred 2 1/2" coil spacers w/1" aal's in rear
Rear seat mod
LEER Cap w/limo tint
"Rusty"Rhino Brush Gaurd
Newest edition of German decent...
04' Porsche Cayenne S
Old 08-03-2005, 08:03 PM
mitchr's Avatar
AC
Tha is the part only 3 screws and a electrical connector. Remove the old(bad) one and line up the flat part that protrudes from the TLA and then you will need to turn it toward the front of the truck about 20 degree's to allow the screw holes to line up. This is if you have the one located on the throttle body, I am willing to bet that the throttle pedal sensor is on the later models and is actually located somewhere real close to the accelerator pedal.
Mitch
Old 08-03-2005, 08:46 PM
AC's Avatar
AC AC is offline
2000 Toyota Tundra,
AC's Photo Albums
Mitch
I'm curious, what ended up being the problem with yours afterall?
TRD Supercharger
ASP od pulley
Supra TT Fuel Pump
Rear seat mod
Old 08-03-2005, 08:56 PM
mitchr's Avatar
The sensor had failed for whatever reason. The way I understand it it is basically a rheostat that controls the input the actuall throttle sensor (drive by wire). Did you have to replace yours? I noticed the photo's.
Old 08-03-2005, 09:25 PM
AC's Avatar
AC AC is offline
2000 Toyota Tundra,
AC's Photo Albums
Default No
No I didn't, because when the my mechanic checked it with the OBDII, it came up with a different part, but related. He then subsequently called Toyota for their advice and they suggested changing more that just that sensor. I don't know why. I ask him, well what if that doesn't fix it? He said, that if that didn't fix it, then he wasn't doing his job right and he would remedy it. Which I thought was very fair. They only work on Toyota's. All x-stealership mechanics. It only cost $50 buh anyway. One year and 6 mos. later, still hasn't missed a beat.
TRD Supercharger
ASP od pulley
Supra TT Fuel Pump
Rear seat mod
Old 08-16-2005, 08:57 AM
RitcheyRch's Avatar
Fellow Tundra Owner
2002 Toyota Tundra
Images: 2
I changed the fuel filter and the problem seems to be resolved for the time being.
Gas pedal problem??? monseq 1Gen-Sequoia 3 07-08-2005 09:13 AM
Gas pedal on 03'+ (lets fix it!) mandzach Engine & Drivetrain 28 10-04-2004 07:00 PM
Gas Pedal touchy when starting off. greener Engine & Drivetrain 8 09-24-2004 11:10 PM
Sticky gas pedal bigruffa Engine & Drivetrain 5 03-07-2004 06:00 PM
Sequoia lows - transmission, seats, gas pedal itwonder 1Gen-Sequoia 12 08-18-2003 03:18 PM
