I have a 2005 tundra with less than 1k miles. I crawled under yesterday to check the fluid level in the rear diff (just want to make sure full from factory and I did notice some noise around 50mph). The Differential fill/check bolt was very tight, as I losened it, I felt and heard air pressure coming out from plug. I have never seen or heard this before. Anyone ever noticed this? I think there is a relief valve somewhere that should keep air pressure out of the rear difff? Could the valve be stuck? Any suggestions, should I have this checked out by the toyota folks?
The diff should not be pressurized- sounds like a pluged vent. Have the dealer check it or you could try to clear it yourself- its on the drivers side of the pumkin. Either way take care of it soon so you dont blow an axle seal
thanks. I will try to clear myself, if not will take it in.
While you're at it, consider extended the breather with a longer hose up into a fenderwell or something. Lots of guys have done this (me included) I think there is a write up out here somewhere.
Also, when you put the diff filler/drain plugs back in, coat the threads with anti-seize--it'll make removal the next time MUCH easier.
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
Do I need to do this even though I don't go 4-wheeling?
thanks, thats a great idea since it was a pain to get off or the old age arthritis is worst than I thought.
I am taking into the shop tomorrow, I crawled up undeneath it at lunch and check the valve and it looked ok to me. Better safe than sorry. thanks for everyones help
You don't HAVE to do it, but do they use salt on NC roads in the winters? If so, then it's just a matter of time before the aluminum cap gets crudded up again.
yeap, they use salt here. I have a some time before winter sets in to do this modification. thanks.
Took to stealer yesterday and they said the value was plugged and they blew out with air hose. I was hoping they would replace value but they didn't. I will just keep a watch on it. Just seems they where cheap on this repair, I mean how much can that small value costs.
