Can you drain the torque converter?
+ Reply to Thread
Results 1 to 12 of 12
Thread: Can you drain the torque converter?
  1. #1
    Junior Member avu3 is on a distinguished road. avu3's Avatar
    Join Date
    Sep 2003
    Location
    Green Valley, Kali
    Posts
    73
    Liked
    0 times
    Rep Power
    10
    Default Can you drain the torque converter?
    on a 2000 Tundra? I'm used to draining the pan and torque converter when I do a trans fluid change. I have and have read the flush procedure, but was still curious. Its not discussed in the manual, but a picture seems to show a bolt in the TC behind the inspection plate.
    Thanks,
    Scott
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford will become famous soon enough. lelandstanford's Avatar
    Join Date
    Feb 2002
    Location
    Houston, Tx
    Posts
    1,733
    Liked
    0 times
    Rep Power
    15
    I don't recall a drain plug on TC before. Is there an access hole on the bottom of bell housing?
    Which vehicle you had experience with TC drainage?
    2005 Tacoma AC 2WD 2.7L 5M
  4. #3
    Join Date
    Sep 2003
    Location
    Green Valley, Kali
    Posts
    73
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Domestics. An old Volvo. Never touched a Japanese auto before.
    Scott
  5. #4
    Banned P07r0457 is on a distinguished road.
    Join Date
    Jul 2005
    Location
    Southern Oregon
    Posts
    427
    Liked
    0 times
    Rep Power
    0
    proper way to flush the trans is via one of those machines that hooks in-line with the tranny cooler... gets 99% of the fluid.
  6. #5
    Guest mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch.
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    6,007
    Liked
    29 times
    Blog Entries
    4
    Rep Power
    0
    Quote Originally Posted by P07r0457
    This is 100% correct and there is no drain in the torque conveter on a toyota. Hasnt been one since the old A30 3 speed trans (corona mark2).
  7. #6
    Veteran Member Mike Donofrio is on a distinguished road. Mike Donofrio's Avatar
    Join Date
    Feb 2002
    Location
    Jersey
    Posts
    1,482
    Liked
    0 times
    Rep Power
    13
    Quote Originally Posted by mustang67408
    I usually take one of the lines off of the tranny cooler (always the wrong one first) start the truck, pump out a few quarts, shut the truck off, add a few qyarts, cycle the gears, pump out a few quarts, shut the truck off, etc until I have drained off about 14-16 quarts. I can tell I am hitting the new fluid when it appears much more cherry red than the icky brown stuff-usallly at about 14 quarts or so.
    Does this not drain the torque converter at all? I always though I'd be getting most of it. Now I know the machine is really the best way, but is this considered to be pretty reliable for DIYers?
    That brings me to another question. Are the impellers in the torque converter turning when the truck is in neutral--in other words is cycling the gears really necessary? That parts gets kinda messy and makes me glad I only do it about once a year!
    Mike D
    Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/LockRightInstall.pdf
    2000 Tundra with 175,000 miles and still going!
    Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
  8. #7
    Join Date
    Jul 2005
    Location
    Southern Oregon
    Posts
    427
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by Mike Donofrio
    It does drain the torque converter... Although that's a very messy way to do it -- and you run a few quarts low for a while. I wouldn't be comfortable doing it, but it technically should work. It does drain the torque converter.
    the torque converter is bolted to the flywheel, which spins at the same speed as the engine. Fluid is always flowing through it, when the engine is running -- regardless of what gear the tranny is in.
  9. #8
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    6,007
    Liked
    29 times
    Blog Entries
    4
    Rep Power
    0
    Yes this does drain the torque converter. But there is no physical pug in it to remove and drain it. Thats what I thought avu3 was talking about.
    Your way works just like a machine, sounds like a good way to do it, for the DIY'r
    Cycling thru the gears will help new fluid get into the clutch packs and flush the old stuff out.
  10. #9
    Join Date
    Feb 2002
    Location
    Jersey
    Posts
    1,482
    Liked
    0 times
    Rep Power
    13
    I think he was talking about a plug, that would be a great idea. They've already taken the dipstick out and practically welded the unit shut so I think Toyota is heading in a different direction. But the DIYer must always be on the lookout for creative solutions.
    Only difference is with my way, you inevitably screw something up and wind up splooging your driveway with used red stuff. My girlfriend hates me for this reason...Alrhough I rather think her driveway now looks like a modern art masterpiece.
    Mike D
  11. #10
    Join Date
    Sep 2003
    Location
    Green Valley, Kali
    Posts
    73
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    Thanks guys, I'm doing the flush method from the KB/Garage. Someone also posted a great thread with additional commentary (but damn if I can find it now).
    The sealing washer on the pan drain bolt is amazingly expensive for how little it is. I just paid $3 for something smaller than a dime.
    Scott
  12. #11
    Supporter THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms is a splendid one to behold. THarms's Avatar
    Join Date
    Nov 2003
    Location
    KS
    Posts
    540
    Liked
    0 times
    Rep Power
    32
    Quote Originally Posted by avu3
    Scott
    Search under my name (THARMS)... I posted the step-by-step directions awhile back after I had done mine.
    2009 Camry Hybrid (wife's car)
    2007 Tundra Crewmax Limited TRD 4X4 (What a truck!!!)
    2001 Sequoia Limited (for sale)
    1999 Solara SLE (kid's car)
    1995 T100 DX 4x4 (my tonka toy, but its gotta go as my wife says I don't need 2 trucks )
    2000 Mustang (black sheep of the family)
  13. #12
    Join Date
    Sep 2003
    Location
    Green Valley, Kali
    Posts
    73
    Liked
    0 times
    Rep Power
    10
    Thread Starter
    That was cake, took me about an hour and a half. Thanks to TS and the authors of the how-to. Trans shifts a lot better on this new fluid, I'll feel better as I tow off next two weekends fully loaded for the races.
    Scott
  1. TRD Duals vs. Banks Monster Exhaust
    By Lexus Luthor in forum Engine & Drivetrain
    Last Post: 06-04-2012, 01:05 PM
  2. Oil Drain Plug Torque
    By southtex in forum Engine & Drivetrain
    Last Post: 12-14-2005, 06:52 AM
  3. Torque Converter Operation Explained
    By Transdude in forum Engine & Drivetrain
    Last Post: 06-11-2004, 07:14 AM
  4. Header/Cat Converter Torque Values
    By Ripper in forum Engine & Drivetrain
    Last Post: 04-18-2004, 03:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
