This is a discussion thread titled "Clunks in 4WD", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
I went mud riding today and my truck was giving me some clunks that made me a little uneasy. When I got a little deeper in the mud it started sounding like my hubs were popping or something. I thought at first it was just when I turned the wheel, but it continued to do it when I had it straight. I don't think I was spinning the tires to much. Is this normal? I've had the truck in 4WD a good bit and I haven't really heard it like I did today.
I don't think that stuff would qualify as high traction. I stepped off in it and lost my shoe. I had to go digging for it because it was covered up as soon as it came off. I'm not sure what it was, but I don't think it was because of high traction. Any more guesses?
Happened to me a few years back. Front end spider gears disintegrated in complete silence...only notice I got was WAAAY better gas mileage and zero 4wd.
Might wanna take her to the shop...they can drain the dif and use a borescope to check out the gears without having to disassemble the front dif.
Or, it could be a vacuum leak on teh 4wd actuating piston on the rear, right side of the dif (kinda round looking attachment to the dif axle)
2004 Pontiac GTO
2005 Dodge Magnum Special Edition SXT
1991 Honda Nighthawk 750
1987 4Runner
Just noticed your in Tuscaloosa. just traded my truck in to a dealer in Aberdeen, MS (I live in Columbus)
If you need a hand with that front end, lemme know. I've ripped mine and a buddy's out several times, replacing the crap spiders with lockers...
PM me if ya wanna
2004 Pontiac GTO
1987 4Runner
Not what I wanted to hear. My gas mileage sure hasn't gotten any better. If I drained the diff fluid would there be metal particles if the spider gears were failing? How could I check on the actuating piston to see if that was the cause of the problem?
I am the guy Birdog helped out with that diff. Yep, drain the fluid--if it's the diff, you'll see all kinds of metal in coming out. If that's the case--stop driving until you can fix it. If it's the spider gears, consider yourself blessed--destroying the front is the first step in getting true 4WD. You can feel free to PM if you have any questions on it, I am (perhaps) more of an expert on fronts than Birdog is by now (4 times and counting) Now, if yer working on spyplanes....
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
Does anyone have any ideas how much a new set of spider gears would cost for the front? I saw I can get a Detroit True Trac for around $380.
Shipping cost if you can find someone who has replaced them with a front locker. Or you might be able to find a front diff complete for about 100-150. Check TTORA.com
Boody - If indeed your front end is blown out...I am a 45 minute drive away and I have a complete ring/pinion/carrier set in my shed from my front end. Came off a 2001 Tundra front end...it's the stock set-up...i.e., open dif, spider gears and the sort....it'll solve your problem...and for tons cheaper than what you'd get elsewhere.
Heck, I'll even deliver. It'll give me a reason to take a flight out to Lula again.
BD0
2004 Pontiac GTO
1987 4Runner
I had chunks literally fall out onto the ground when mine was drained....bad part was after I drained the original front dif, some chukns came out of suspension and binded my pinion bearing...I ended up having to hit up T.A.P. in Rancho COrdova, CA for a lightly used 2001 front end replacement for $250. I rebuilt THAT front end with a lock-rite locker and did away with those pesky spider gears all together.
2004 Pontiac GTO
1987 4Runner
