This is a discussion thread titled "Transmission Shifter "jerking" when put in Park.", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-15-2005, 03:34 AM
Dealer : Servco Auto Center
2006 Toyota Camry
Last Online: 12-02-2005 06:45 PM
lockoutpros is on a distinguished road.
lockoutpros's Photo Albums
Default Transmission Shifter "jerking" when put in Park.
Hi, i have an 05 Tundra Regular cab and was curious to know if anyone else on here has this problem. When i shift from Drive to Park and release it, sometimes it tends to move or jerk up after being placed on Park already, this is getting to be annoying and would like to know if i should take my truck in or if anyone has the same problem. Sometimes this happens when i go form Reverse to Park. This only happens a certain percentage of the time, so i know its not normal. Thanks,
Frank
Old 09-03-2005, 01:59 PM
VirgilGoneMad's Avatar
Dealer : Dublin Toyota Scion
2005 Toyota Tundra
Last Online: 04-22-2008 10:35 PM
VirgilGoneMad is on a distinguished road.
VirgilGoneMad's Photo Albums
Frank
I also have a reg. cab and does the same thing yours does...I don't know why.
Old 09-20-2005, 04:07 PM
Dealer : Universal Toyota
2005 Toyota Tundra
Last Online: 02-06-2006 03:07 PM
har_d_har is on a distinguished road.
har_d_har's Photo Albums
I have the exact same problem with my 2005 DC. Anywher from 50%-80% of the time, when you park the truck, put the shifter in park, then release the brake pedal, the shifter will move upward a little and will make a semi-loud "clicking" sound. It does not always happen, but is most noticeable when parking on an incline. I took it to the dealer to have them look at it, and they said it was normal (of course, that's what they always say). Not satisfied with that answer, we proceeded to pull new Tundras off the lot at random (I chose some, the dealer chose some), and sure enough, they all did it to some degree or another. The service advisor even checked the service manager's Tundra, and it did it at least half of the time as well. Apparently, when the transmission locks after putting it in park, the pull of the gears causes the shifter to butt up against the brake switch lock in the steering column, causing a little movement and the "clicking" sound. Bottom line, they can't do anything about it.
Old 01-10-2006, 03:02 PM
Dealer : Elk Grove Toyota Scion
2005 Toyota Tundra
Last Online: 11-26-2008 04:29 PM
ed95206 is on a distinguished road.
ed95206's Photo Albums
Default Re: Transmission Shifter "jerking" when put in Park.
I just notice the same thing on my truck. 05dc
05 tundra dc timberland mica
stockton, ca
Old 01-10-2006, 03:19 PM
2005 Toyota Tundra
I had the truck in the shop of couple of weeks ago after part of the shifter broke. They replaced the internal parts under warranty, but the shifter still moves and "clicks" even after they took it apart and put it back together. I guess it's just a Toyota and/or Tundra thing...who knows.
Bookmarks
Similar Threads for: Transmission Shifter "jerking" when put in Park.
Extending Automatic Transmission Life Transdude Engine & Drivetrain 210 12-20-2008 08:39 PM
Grinding while switching from 2wd to 4wd harkeyjt Engine & Drivetrain 11 08-06-2004 06:05 PM
tranny temp gauge? RRC/AMC Engine & Drivetrain 10 04-10-2004 06:18 PM
Auto transmission questions Laubypt Engine & Drivetrain 13 08-23-2003 10:29 PM
Finally got around to flushing my trans with Amsoil synthetic akauth Engine & Drivetrain 25 10-30-2002 07:01 AM
