Originally Posted by SnowTruck
...Does anyone have the service manual for the 05' Tundra and are able to tell me which one has the drivetrain?
The '05 Tundra Repair Manual set consists of four volumes, with a total of approximately 5800 pages, of which nearly 3000 are concerned with diagnostics provided by the truck's computers! The manuals break down as follows:
VOL. 1: Maintenance, Preparation, Specifications, and Diagnostics pages DI-1 through DI-1475. (Publication No. RM1150U1)
VOL. 2: Diagnostics pages DI-1476 through DI-2943; Engine Mechanical for 1GR-FE engine; Engine Mechanical for the 2UZ-FE engine; Emission Control for the 1GR-FE; Emission Control for the 2UZ-FE. (Publication No. RM1150U2)
VOL. 3: Fuel Systems, Cooling Systems, Lubrication, Ignition, Starting, Charging, Clutch, Manual and Automatic Transmissions, Transfer Case, Propeller Shaft, Suspension and Axle; Brakes, Steering, Supplemental Restraint System, Body Electrical, Body, and Air Conditioning. (Publication No. RM1150U3)
VOL. 4: Electrical Wiring Diagrams for the 2005 Tundra (Publication No. EWD611U)
So the answer to your original question is that Volume 3 contains the stuff about the drive train following the engine, but the stuff about the engine itself is in Volume 2.
