I just had my 2004 4.7 V-8 Tundra serviced at 9500 miles, (not the first time).
I was told the rear main seal is leaking. I know it is covered under warranty but I am familiar with Chevy engines and when their rear main goes out, usually at high miles to to crank movement, just replacing the seal is a temporary fix, it will leak again because the crank bearings are worn.
I am concerned about the low miles and this leak and if some other steps should be taken sooner rather than later.
Respectfully:
John Mizer
