This is a discussion thread titled "intermitten problem shifting from park to drive", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-07-2005, 04:13 PM
Tundra_DC's Avatar
Dealer : Sand Mountain Toyota
2007 Toyota Tundra double cab SR5 5.7,
2008 Toyota Sienna
Last Online: Yesterday 09:51 AM
Tundra_DC is on a distinguished road.
Tundra_DC's Photo Albums
Default intermitten problem shifting from park to drive
All,
I have 2005 tundra, great truck but sometimes when I try to shift from park to drive (foot is pressing brake pedal and truck is started) it will not let me move gear shifter from park to drive. It has happened 4 times in last month. Took into shop today and they of course told me that they cannot recreate problem so no trouble found. They did say that they have had problems with camry's. They said that I would have to prove it. It really sux, coz I was waiting in a gas line the other day, stopped. Since traffic wasn't moving shifted into park, then turned off truck. As soon as traffic started moving, cranked truck while pressing firmly on the brake pedal, then tried to put into drive and no go. Then of course people started honking, etc. I have to shut the truck off and back on , basically fiddle with it and then it will final work.
Any help appreciated. I know there is a switch on the brake pedal when pressed turns on the brake lights and also tells the truck the brake pedal is pressed so you can shift out of park. Wondering if there is an adjustment to this switch.
Old 09-07-2005, 05:55 PM
Dealer : Camelback Toyota Scion
2005 Toyota Tundra,
- Other - 96 Acura 3.2 TL
Last Online: Yesterday 04:07 PM
tempetom is on a distinguished road.
tempetom's Photo Albums
It sounds like you're on the right track with the brake switch needing adjustment. I wonder if the brake light comes on when this happens? Too bad it's an intermittent problem. Good luck; let us know if you ever find out the answer.
I'm having a little problem with my ignition key turning to start. I have to turn the steering wheel a bit just like on my 96 Acura. That one drove me nuts when it first happened.
Old 09-08-2005, 01:44 PM
Tundra_DC's Avatar
2008 Toyota Sienna
Not sure if brake light comes on, maybe it will do it while someone is riding with me and I can have them check. I found the adjustment procedure here on tundra solution, I will adjust this weekend. Too bad the dealer didn't try, they said the whole switch would have to be replaced. Time to find another shop :-).
Old 09-10-2005, 09:17 AM
Dealer : Springhill Toyota Scion
2004 Toyota Tundra
Last Online: 03-05-2007 11:58 PM
killieans14 is on a distinguished road.
killieans14's Photo Albums
I have the same problem with my 04 DC Tundra. Were did you find the adjustment procedure on tundra solutions so I can try it also. Plus, did the adjustment work? let us know.
Old 09-11-2005, 04:24 AM
Steelshot's Avatar
Dealer : Toyota of Santa Barbara
2002 Toyota Tundra
Last Online: 01-05-2009 01:11 PM
Steelshot is on a distinguished road.
Steelshot's Photo Albums
Don't know if the 2005 DC is the same, but on my 2002 AC there is an independent switch that the brake lever hits to activate the shift lever release. Look under the dash near the brake pedal pivot. You can see the switch where the brake hits. This switch has nothing to do with the brake lights. I have mine adjusted so that I can shift out of park without the brake.
Ivan Stewart Body Kit; IS Wheels; Clear Corners w/ silverstar 3157A bulbs; Snug Top SuperSport cap; Marathon Super Hides seat covers in Shadow Grass; Husky floor liners; Toyota self-dimming rear-view mirror w/ temp & compass; Yakima Track Racks; debadged; Colgan front mask (only when going off-road); Cornfed 2 inch lift; Fabtech add-a-leaf; Total Chaos 1 inch differential drop kit; silver/blue TRD Offroad decal from Street Graphics.net; Line-X spray-in liner; 2005 tail lights; tailgate seal; Challenger Step Bars; Hellwig sway bar w/ Frontrange disconnects; SolidWiring Technology FOG603 foglamp mod & DRL601 switchable DRLs; battery manager; Prodigy brake controller.
Old 09-12-2005, 09:06 AM
Tundra_DC's Avatar
2008 Toyota Sienna
I found the procedure at INFO: 2005 Tundra Brake System
and the pdf is ovi.pdf. Basically under Knowlegde forums, suspension, steering and brake, then Tundra, then click 2005 tundra brake system, then you will see Brake pedal.zip. Click on that and select ovi.pdf. I was lazy this weekend with watching football and haven't tried yet. I didn't see another switch that steelshot was talking about, will look and see if I can find that as well.
Old 09-20-2005, 01:15 AM
otacg78's Avatar
Dealer : Beaver Toyota Of Santa Fe
1996 Toyota T100
Last Online: 02-11-2006 04:41 PM
otacg78 is on a distinguished road.
otacg78's Photo Albums
I ahve kinda the same problem but i suspect im just not pushing in the brake far enough, because i dont really have to fiddle with it, just push in the brake farther. hmm, i hope i dont develop this problem.
Aint no kinda ugly that beer can fix.
Bookmarks
Similar Threads for: intermitten problem shifting from park to drive
Driveline vibration. nhparrot Engine & Drivetrain 4 01-14-2008 01:13 PM
hard shifting problems kpk Engine & Drivetrain 14 10-15-2003 07:55 AM
Transmission Problem TTNGUYEN 1Gen-Sequoia 7 01-06-2003 02:13 PM
Front drive line noise and vibration Marlin Wonders Engine & Drivetrain 16 12-22-2002 06:05 PM
Drive Line / Ujoint findog1922 Engine & Drivetrain 2 03-10-2002 12:29 AM
