I've just rolled past about 90,000 and i have never changed the transmission fluid. I'm thinkin that its better late than never, right? Should i run just the toyota stuff or some type of synthetic? what are some people's experiences and suggestions? thanks
__________________ 2000 Toyota Tundra V8 Ivan Stewart Edition
2.5" Shocks by Sway A Way (Camburg)
King Coil Springs 650lb x 14"
11pk Deavers w/ 5100 Bilsteins
LT285/75R16 Nitto Terra Grappler Load Range D 122Q
Weld Racing Renegade 16x8 3 5/8 BS
JBA Titanium Coated Headers
Eclipse AVN5435 Unit
'05 Tail Lights
Clear Corners
TRD LSD soon!
I'd clean the transmission with Auto-rx for their safe, effective 1000 mile cleaning process, then install your choice of Dexron-III synthetic ATF. Dexron-III ATF is the correct type for a 2002 Tundra. I like Schaeffer, Mobil 1, Amsoil, Royal Purple, and RedLine ATFs.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Ken is any Dexron III ok for an '01 2WD tranny? Maybe a Pennzoil or something.
I have been running Mobil 1 for the last 2 complete fluid change outs but im at 86k now and probably will upgrade to a newer truck before long and don't want to spend the extra money for the Mobil 1 right now. I seem to remember some trucks you had to add some other fluid to it or maybe that was for transfer cases or rearends, I can't remember which.
__________________ SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky MODS:
TIRES: Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION: front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod, EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers, ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Do you check the tranny fluid level while the truck is running and in park, or when its turned off?
I usually do it when I run errands around town and once you're all done. That's a good time to check it.
'05 Tail Lights
Clear Corners
TRD LSD soon!
For 2000-2002 Tundras, your choice of Dexron-III ATF. If you're using a synthetic, it is likely good for 50,000 miles or more. To save money, you can get a $20 analysis at Blackstone Labs. You might find that synthetic fluid has many thousands more miles of life remaining.
Ken
Ken
When I drained the Mobil 1 out, after almost 50,000 miles it still looked almost new. I couldn't believe it. I went ahead and did the complete flush but just put the Pennzoil Dex III in it for now. Wish I would have kept a tube of the old fluid to have tested, just out of curiosity to see if it was still going strong. Thanks for the info.
