Welcome to the Tundra Solutions Forum forums.
KORE
Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "Check Engine light on; then a problem!", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-26-2006, 08:48 AM
Dealer : Claremont Toyota Scion
2000 Toyota Tundra,
2007 Toyota Tundra 5.7 CrewMax
LawyerRon's Photo Gallery LawyerRon's Photo Albums
Last Online: Today 12:10 AM
LawyerRon may have some regrets.
Angry Check Engine light on; then a problem!
Vehicle is a 2000 Tundra 4.7 Access Cab;
Yesterday, while pulling into a driveway, the "check engine" light suddenly came on and there was a loss of power. They engine didn't die; the tach went to about 1,000 RPM like it was at idle. When I pressed on the gas pedal, the engine would not accellerate. In fact, pressing on the gas seemed to have no effect.
So I stopped the truck, shut it off, started it back up, and it ran normally. The check engine light was still on for about an hour, then it went off. Truck ran fine, but then it did the same thing several hours later. Any ideas?
TIA
Old 03-26-2006, 09:08 AM
randyeverett's Avatar
Dealer : Coad Toyota
2005 Toyota Tundra,
2008 Toyota Rav4 Limited, V-6
randyeverett's Photo Gallery randyeverett's Photo Albums
Last Online: 05-14-2008 09:58 AM
randyeverett is on a distinguished road.
Default Re: Check Engine light on; then a problem!
TIA
LawyerRon, couple of thoughts. Check your gas cap.
Also, go by autozone and have them hook it up to the code reader.
Then post your code and shmeone should be able to help you out.
good Luck,
RE
Great Apes are not great......they're just big gay monkeys.
Bone-stock 05 Access Cab Tundra, V-8, 4x4, TRD Off-Road w/LSD, Spectra Blue Mica
05 Camry LE, 4cyl
Old 03-26-2006, 09:18 AM
2000 Toyota Tundra,
Thanks Randy,
I checked the cap this morning and it seems to be OK. Funny thing is, the truck fired right up this morning and ran normally with full power. The check engine light is now off too. I think I'll go by Autozone this morning when they open.
Old 03-26-2006, 11:10 AM
2000 Toyota Tundra,
OK, went to Autozone and scanned for the code. Here it is:
"P0121 TPS/Pedal Position Sensor A CKT Range/Perf"
Looks like a sensor of some sort needs to be replaced?
Old 03-26-2006, 12:13 PM
freddie's Avatar
Dealer : Carson Toyota Scion
freddie's Photo Gallery freddie's Photo Albums
Last Online: 05-21-2007 08:57 AM
freddie is on a distinguished road.
P0121 Throttle/Pedal Position Sensor/Switch A Circuit. Range/performance problem.
http://www.yotatech.com/showthread.php?t=59005
Old 03-27-2006, 08:55 AM
2005 Toyota Tundra,
LawyerRon,
Never replaced it on a Tundra. Don't think it's that difficult though. I'm inclined to buy the part, look at it, figure out basically how it works, and install it. If it doesn't work or you can't get it on....... take it back........ no harm done(usually). Frequently, AutoZone has directions for R/R of alot of the stuff they sell. Don't know if the TPS from AutoZone is of high quality or not.
If Mustang67408 is around, maybe he'll chime in here with some step-by-step.
I've PM him, so hopefully he'll pop in.
good luck,
RE
05 Camry LE, 4cyl
Old 03-27-2006, 09:09 AM
2005 Toyota Tundra,
Meantime, Check this thread:
No response at gas pedal
RE
05 Camry LE, 4cyl
Old 03-27-2006, 06:56 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Gallery mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Here ya go with a how to replace straight from toyota.
After you replace it make sure to disconnect the battery to clear the code and reset the ECU.
You may need a SCAN TOOl to set the % of throttle opening.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
Old 04-01-2006, 02:50 PM
Dealer : Toyota Of Portland
2000 Toyota Tacoma
theyotaguy's Photo Gallery theyotaguy's Photo Albums
Last Online: 06-10-2008 04:31 PM
theyotaguy is on a distinguished road.
Will the one they have at the 'Zone work?
*A parts man with a code-reader is NOT your friend!
*The most expensive parts are the cheap ones that let you down.
*Testing ROCKS - parts swapping is for the .
*Anybody can take a dump in a box and mark it guarranteed,but what you really need to do is buy a quality part.... "Tommy Boy"
Old 04-01-2006, 02:58 PM
2002 Toyota Tundra,
As long as the reader reads, "REALTIME DATA" and Throttle %.
I have never seen the one at Autozone, so i really dont know.
Some code readers are just code readers and dont do DATA LISTS.
23 yrs with TOYOTA
K.I.S.S.
Old 04-01-2006, 07:16 PM
2000 Toyota Tacoma
I was only kidding,man.
Similar Threads for: Check Engine light on; then a problem!
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 04:25 PM
Check Engine Light? vegasgreed Engine & Drivetrain 22 07-31-2006 07:33 PM
Check engine light is on, again!!!! ripe911 1Gen-Sequoia 4 03-13-2006 03:30 PM
Check Engine Light @ 5000 miles? oldirtyhughes Engine & Drivetrain 3 02-20-2004 07:38 PM
Check engine light ON kolaroman Engine & Drivetrain 1 09-23-2003 02:09 PM
Questions? Please use the Contact Us link. Dealer Hunter JPV Photography
