Weird noise when engine breaking...
+ Reply to Thread
Results 1 to 6 of 6
Thread: Weird noise when engine breaking...
  1. #1
    Veteran Member GaryFisher is on a distinguished road. GaryFisher's Avatar
    Join Date
    Feb 2002
    Location
    Pluto
    Posts
    665
    Liked
    0 times
    Rep Power
    12
    Default Weird noise when engine braking...
    Today was a nice day out so I had the windows down for and extended period of time the first time this year. When I was moving slowly in traffic in first gear I noticed that when I took my foot off the gas and slowed down there came a high pitched rapid chirping noise. When I pressed the gas again it went away. I then sped up and took it out of gear and coasted and no chirping noise. It seems to only occur in first and second gears when I release my foot off the gas.
    Anyone got any ideas? Transmission problem?
    SR5 V6 4X4 5Spd Modifications Include... ACT performance clutch, Bassani Split Side Duals, Fabtech Shocks and front Coilovers, IS Kit, Grillecraft Grille, BBS Wheels, 285/75/16 Firestone Destination M/T's for wheelin, 20" Enkei RT-6's w 295/50/20's for street , Air Box Mod, Pro Comp Boost GaugeTRD Supercharger, URD Fuel kit, URD 2.2 Pulley ALL GONE - Now Audi S4 Avant
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2002
    Location
    Pluto
    Posts
    665
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    Default Re: Weird noise when engine breaking...
    No one has any thoughts eh?
  4. #3
    Supportive Supporter TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme is more than famous, they're infamous. TheGryme's Avatar
    Join Date
    Sep 2004
    Location
    Wrightwood, CA
    Posts
    923
    Liked
    37 times
    Images
    25
    Rep Power
    2904
    Check all the usual junk is all I can suggest....U joints, yokes, d-shaft support bearings. Declerating in 1st & 2nd would put a noticable load on those items.
    TheGryme Do It Right, No One Remembers. Do It Wrong....No One Forgets!
    '04 Tundra DC
    Grey....V8 SR5 4X4 TRD Off Road Suspension, LSD, Towing Package, 5100's Front & Rear, Total Chaos UCAz, Toyo Open Country A/T 265 75 16 ~ 6 Ply's, Magnaflowed, UNIChipped, True~Flowed (w/ Secret AirBox Mods!), DeBadged, ScanGaged, XM'ed, a Few Scrapes and Dings.....Yeah!
    '92 4Runner
    Black, V6, Downey / Rancho suspension F&R, 3 inch sus lift, 1 inch body lift, SAW T-Barz, 4:88's, ARB (rear), 32X12.50 BS Dualers on AR 8X15 Wheelz, Power Slots and Pads, Downey headers, MagnaFlo Muff, K&N FIPK, Ported heads, 1 piece stainless valves...way too much money in it!
    '04 YZ250F
    Dr.D Header and Can, JD Jetting, P38 AP, UNI Flame Proof Air Filter, No Back Fire Screen, Carbon Fiber Carb Heat Shield, Renthals, Maxxis Desert IT Tires, ASV Controls....
    '87 Nissan Pathfinder......gone but not forgotten.
  5. #4
    Guest mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch. mustang67408 wants you off his porch.
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    6,007
    Liked
    29 times
    Blog Entries
    4
    Rep Power
    0
    Quote Originally Posted by TheGryme
    The driveshaft center support bearing was the first thing to come to my mind.
    Excellent ideas.
    Poss vac leak?
    Brake squealer?
    Backing plate scraping?
    Belt chirping
  6. #5
    Join Date
    Feb 2002
    Location
    Pluto
    Posts
    665
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    Quote Originally Posted by mustang67408
    Excellent ideas.
    Poss vac leak?
    Brake squealer?
    Belt chirping
    What should I be looking for at the D-shaft center bearing? I just greased all points on the driveshaft put the sounds remains.
  7. #6
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    6,007
    Liked
    29 times
    Blog Entries
    4
    Rep Power
    0
    Quote Originally Posted by GaryFisher
    It is a sealed bearing, you can try to take it apart and get some grease in it.
    I added some attachments.
    Can you put the truck on jack stands, have someone duplicate the noise while your under it. That will better pinpoint the location.
  1. New power outlet mod + engine noise question
    By chrism in forum Electrical & Computer Systems
    Last Post: 02-21-2009, 08:17 PM
  2. Which BRAND of OIL?
    By nhparrot in forum Engine & Drivetrain
    Last Post: 10-29-2007, 10:43 AM
  3. Breaking in the engine?
    By Jdog in forum Engine & Drivetrain
    Last Post: 05-08-2004, 04:15 PM
  4. V6 engine noise
    By turyates in forum Engine & Drivetrain
    Last Post: 09-12-2003, 08:28 AM
  5. Why must I run premium gas to avoid engine noise??
    By Scott Hawn in forum Engine & Drivetrain
    Last Post: 02-12-2003, 05:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
