Old 04-13-2006, 04:03 PM
Dealer : University Toyota
Last Online: 09-17-2008 10:55 AM
jday4 is on a distinguished road.
jday4's Photo Albums
Default Transmission issue
Well, I have some questions. Last Sunday I was driving and my truck started to overheat, I let off the throttle and the temp went back down. I pulled over and noticed tranny fluid in the radiator. Intead of risking hurting the transmission I had to towed to Toyota and they a tranmission fluid line in the radiator had burst. So I get a new radiator and they assure me that no antifreeze/water entered the tranny. The pressure in the tranny is much higher than the radiator. The replaced the radiator and added some transmission fluid. I got in it today and started driving and it when it shifts, it hesitates and shifts hard into the next gear. I called them back and they said the the battery was disconnected and the transmission is relearning. I have had my battery disconnected before and it doesn't feel like that at all. Any suggestions what it could be? Could there be coolant in the tranny causing this problem? Could there be air in lines or what? I don't want to kill my tranny because of a radiator problem. Let me know if you guys have any suggestions before I go back to toyota. I am going to have someone flush the tranny fluid, what else could it be?
Old 04-13-2006, 05:37 PM
wylcat's Avatar
DIRT BAG
Dealer : Sparks Toyota
2002 Toyota Tundra,
2000 Toyota 4Runner
Last Online: 11-15-2009 09:01 PM
wylcat has blessed us with their presence. wylcat has blessed us with their presence. wylcat has blessed us with their presence. wylcat has blessed us with their presence.
wylcat's Photo Albums
Default Re: Transmission issue
I would have a tranny FLUSH (not drain and fill) done regardless of what the dealer says...better safe then sorry.
HAVE YOU DRIVEN OVER A FORD LATELY?
Team West SAWS (cranked up to 3.25")
Total Chaos UCA
ORS Manual hub kit
reese front receiver hitch
10,000 lb. winch on receiver hitch
Warn Quick connects front and rear
rear brake porportioning valve mod
3" perfomance products body lift
skyjacker AAL
wheelers urithane kit for front swaybar and steering rack
BFG AT's
Eagle101 wheels
CB radio W/ dual fiberglass 48" ant.
Old 04-13-2006, 06:40 PM
42GAMI's Avatar
Dealer : Servco Auto Center
2004 Toyota Tundra Stepside
Last Online: Yesterday 10:43 AM
42GAMI is on a distinguished road.
42GAMI's Photo Albums My eBay
umm, yeah, what he said.
i dont care if the tranny fluid pressure is higher, it can still mix.
MODS: (TRD Urban package) - tint, stereo, jack-in-the box antennae ball, and my middle finger.
... Find any spelling errors? Take it up with admin.
...... btw If I offend anyone, get over it. I know I will.
......... Panties are optional.
~ been there, done that, got the panties ~
Old 04-14-2006, 06:16 AM
Thanks for the info guys. If it did mix should I be able to see evidence on the dip stick? It only acts this way when I am in Park and shift to Reverse or when it shifts at RMP greater than 3000. As far as downshifting to go it hills every this is normal. I will flush it this weekend and we shall see what happens.
Old 04-14-2006, 08:56 AM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Yesterday 10:50 PM
Images: 17
LGL002 will become famous soon enough.
LGL002's Photo Albums
It may show on your dipstick but it'd be hard to determine water from air on it. Water's heavier than oil so it'll settle out at the lower parts of the system so it could get picked up by the oil pump sump and show up as a emulsion (creamy mix) on the dipstick. If there is water in the system it could take more than one drain/flush attempt to get it all out.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Old 04-17-2006, 07:39 AM
More questions
Well there was plenty of water in the tranny. Toyota assured me they checked it and it was fine (making a visit today to express my frustrations). It looked like pepto bismol while draining out of the pan. After changing this I had it flushed with 40 quarts of tranny fluid. I drained the pan again I can still see a slight tint in the ATF. I am going to have another flush done in the next couple of days. Anybody know what else I can do. As far as the tranny goes it feels great, like there is nothing wrong, but I know any little bit of water can cause damage to the clutches and other parts in the tranny. What else can I do, ATF can get expensive.
Old 04-17-2006, 08:18 AM
LGL002's Avatar
Images: 17
While a small amount of water isn't ideal it should under use boil off after the transmissions been run under operating temperatures a few times. It's the anti-freeze residual that may cause any problems that'll occur. Sounds like you've done enough flushes/changes to minimize the exposure to that product. If it were me I'd continue to drive it, monitor the operation of the transmission performance for a few weeks. Then after a few weeks pull the pan after it's been idle overnight and see if there's any evidence of residual material in the pan. I'm grateful it isn't my Tundra and I can feel your pain and frustration.
Larry
Optima 34R battery
Old 04-17-2006, 12:46 PM
Dealer : Puente Hills Toyota
1995 Lexus LS400 Pearl White
Last Online: 09-06-2008 08:14 AM
Lextreme is on a distinguished road.
Send a message via AIM to Lextreme Send a message via MSN to Lextreme Lextreme's Photo Albums
When your tranny fluid mixed with radiator fluid. Doesnt it also meant your engine also getting tranny fluid residue? I think you need a complete radiator flush overwise you will have overheating problem.
* 1995 LS400 - Supercharged 5.2 Stroker at work
* 1995 SC470 - 4.7L Tundra Motor Start-up Video
* 1993 SC300 - BHG
* 1993 Previa - Cargo Hauler and Love it!
Extending Automatic Transmission Life Transdude Engine & Drivetrain 211 10-29-2009 05:55 AM
transmission flush nhparrot Engine & Drivetrain 4 08-26-2007 08:46 PM
Replacement Transmission for 2000 Tundra with 38k johnmgeorge Engine & Drivetrain 72 07-08-2004 07:27 PM
Auto transmission questions Laubypt Engine & Drivetrain 13 08-23-2003 10:29 PM
