This is a discussion thread titled "Transmission Fluid Change", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-29-2006, 11:50 AM
RCraig's Avatar
Dealer : North Point Toyota Scion
2004 Toyota Tundra
RCraig's Photo Albums
Last Online: 04-23-2008 12:53 PM
RCraig is on a distinguished road.
Default Transmission Fluid Change
The Toyota Service Passport doesn't mention replacing the transmission fluid unitl 60,000 miles under the sever duty application(towing). I've got 45,000 miles (in two years) with the original fluid and I do occaisional towing.
I've got an '04 Tundra DC. Does it have a screen or a filter? Will droping the pan and changing the fluid be good enough?
I really don't trust the dealerships in my area. Their prices are very high and they recommend doing everything much sooner than Toyota. Who should you trust?
Old 06-29-2006, 12:40 PM
shall36's Avatar
Dealer : Central Florida Toyota Scion
2003 Toyota Tundra
shall36's Photo Albums
Last Online: 10-05-2008 08:43 AM
shall36 is on a distinguished road.
Default Re: Transmission Fluid Change
It uses a screen and a Toyota tech will tell you that IF they actually drop the pan, they are just going to clean out the screen. I dropped my pan at 30K and the screen was perfect and there was very little material in the bottom of the pan.
My advice would be to just drain and refill at 15k intervals. Maybe drop the pan at 100k just to look things over. Dropping the pan is a PITA as the gasket is not readily available and replacement screens are $$$. Plus, you have to clean the factory sealant off the pan.
You could get the Magnafine inline filter from IPT for $15.
Old 06-29-2006, 04:41 PM
RCraig's Avatar
2004 Toyota Tundra
Thanks for the advice. I assume that I could install the by the aux. trans. cooler (top side - supply, bottom side - return?) I guess if I filtered the oil just before the cooler it would help keep the cooler clean as well?
What is IPT? Not familiar with this term. Also, would I change this filter each time I change the fluid?
Old 06-29-2006, 11:03 PM
Dealer : Toyotaland
BaseCamp's Photo Albums
Last Online: 09-30-2008 09:50 PM
BaseCamp is on a distinguished road.
IPT is a vendor many from here have use. IPT Performance Transmissions Torque Converters and Transmission Parts for Ford, GM, Chrysler, and Import vehicles
Actually you should be the filter at the output line so that only clean fluid goes back into the transmission.
BaseCamp
Northern California
2006 Tundra Double Cab Limited
2005 Camry XLE
1986 Nissan Hardbody (600,000 miles and counting... )
2006 Keystone Outback 21RS
Old 06-30-2006, 09:01 PM
RCraig's Avatar
2004 Toyota Tundra
Similar Threads for: Transmission Fluid Change
Transmission Fluid Change TJ123 Highlander 28 01-14-2008 10:33 PM
Extending Automatic Transmission Life Transdude Engine & Drivetrain 208 03-13-2007 04:26 PM
Changing Transmission Fluid kolias Engine & Drivetrain 6 07-16-2006 11:39 PM
HELP?!?! first fluid change markobeans Engine & Drivetrain 1 05-15-2006 01:05 PM
4X2 Transmission and LSD Diff fliuid change recommendations?? tundrabrad Engine & Drivetrain 1 10-13-2003 11:47 AM
