Does P0155 always mean bad o2 sensors ?
+ Reply to Thread
Results 1 to 6 of 6
Thread: Does P0155 always mean bad o2 sensors ?
  1. #1
    Rookie dafogle is on a distinguished road.
    Join Date
    Aug 2006
    Location
    Magalia, Ca
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Question Does P0155 always mean bad o2 sensors ?
    Hi: The check engine light is on on my 2000 Tundra. I took it to autozone and the code that appears is P0155. I read about the extended warranty on the o2 sensors here ... I called the service dept and have an appt for tomorrow ... the service guy said that sometimes the computer throws this code but its' not the o2 sensors...
    Is this possible ?
    Thanks in advance for any thoughts/advice....
    Doreen
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member TS Support is on a distinguished road.
    Join Date
    Oct 2005
    Location
    TundraSolutions.com
    Posts
    783
    Liked
    0 times
    Rep Power
    8
    Default Re: Does P0155 always mean bad o2 sensors ?
    P0155 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    Problem Areas
     Open or short in heater circuit of heated oxygen sensor
     Heated oxygen sensor heater
     ECM
    2000 Through Mid-2002 Model Year Tundra V8 (2UZ-FE Engine) Oxygen Sensor Warranty Enhancement Notice
    2000 Through Mid-2002 Model Year Toyota Tundra V8 (2UZ-FE Engine). In recent months, Toyota has received reports of custome concerns regarding the two oxygen sensors located in the exhuast manifolds that monitor exhaust emissions. These oxygen sensors are installed ahead of the catalytic converter and are also known as the Number 1 Oxygen Sensors. To minimize these concers, Toyota will extend the warranty of these oxygen sensors for illumination of Malfunction Indicator Lamp (check engine light) related to any of the following diagnostic codes (as diagnosed by your local Toyota Dealer): PO135 and P0155.
    If your check engine light illuminates, please bring your vehicle into your local Toyota dealer for diagnosis and repair. Please note that a check engine light can illuminate for unrelated to the Number 1 Oxygen Sensors.
    This warranty extension is offered for a total period of 7 years or 90,000 miles from the vehicle's in-service date, whichever occurs first, for the failure of eiher of the Number 1 Oxygen Sensors. The specific components covered by this warranty extension are:
    - Number 1 Oxygen Sensor, Bank 1 (left side exhaust manifold)
    - Number 1 Oxygen Sensor, Bank 2 (right side exhaust manifold)
    This offer is limited to your specfic Tundra whose VIN is provided and is subject to the same conditions set forth in the New Vehicle Limited Warranty section of your Owner's Warranty Information booklet*, with the exception of the extended warranty coverage on the oxygen sensors listed above. Please note that this coverage is for warranty work performed at an authorized Toyota dealer only.
  4. #3
    Join Date
    Aug 2006
    Location
    Magalia, Ca
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thank you for the info!!!
    Doreen
  5. #4
    Rookie glassair is on a distinguished road.
    Join Date
    Dec 2005
    Location
    racine
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    A failing PCM will throw a P0155 code when in fact the O2 sensor is fine but the electrical feed to the sensor is bad from the PCM. I've been fighting this problem since 2005 with new sensors and multiple trips back to the dealer with check engine light on. Finally took to a mechanic (not Toyota dealer) who found intermittent power from the PCM to O2 sensor. Sensor heater circuit can't function without power. Big bucks for a new PCM but I'm so tired of the whole oxygen sensor problem I'll open the check book.
  6. #5
    Junior Member diablito1975 is on a distinguished road.
    Join Date
    Apr 2006
    Location
    orange county
    Posts
    192
    Liked
    0 times
    Rep Power
    8
    Quote Originally Posted by glassair View Post
    have you bought your pcm yet? if you havent send me a pm
  7. #6
    Lurking Member snowdogg is on a distinguished road.
    Join Date
    Mar 2008
    Location
    Minneapolis
    Posts
    36
    Liked
    0 times
    Rep Power
    6
    yeah, any update yet. I am pulling this code now and will take it in to the stealership to see if they will honor under this warranty update.
    let us know how this came out for you and how much the PCM was.
    thanks!
  1. O2 Sensors gone bad
    By TUNDRA RU in forum 1Gen-Tundra
    Last Post: 12-20-2010, 07:39 AM
  2. Backup sensors installed.... but....
    By Mudhutbob in forum Aftermarket Products
    Last Post: 12-26-2009, 10:06 PM
  3. Bad O2 sensors?
    By supritdeol in forum Engine & Drivetrain
    Last Post: 05-07-2005, 09:50 PM
  4. *The BS Thread* - READ ONLY -
    By Possum in forum Texas
    Last Post: 05-06-2004, 01:14 AM
  5. bad oxy sensors
    By blkcruiser in forum 1Gen-Sequoia
    Last Post: 09-03-2003, 01:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
