Originally Posted by grumpy in NH
Cookiemech:
Thank's for replying! I used the 2-person pump and bleed method. I did it twice, using up about a 1/2 can of dot3. I close the bleeder well before the slave bottomed out, and bleed into a short hose submerged in a can of fresh dot3. The clutch master does not have a resevoir, it has a hose to the brake resevoir (dont like it). Luckily, the slave is handy on the front of the tranny housing from top side. This is frustrating though, not being able to adjust for basic proper operation of the car  My next try will be to cut out the carpeting(!) under the pedal-stop bracket on the clutch pedal. This arrangement uses the floor to prohibit excessive travel - but maybe here I can pick up my 1/4" i need to fully disengage the pressure plate. Otherwise - ther synchros are quickly turing to dust ....
Grumpy in NH, U.S.A.
Definitely not right for it to go so far before disengaging. It should start to disengage about 1/2 way off the floor. It does sound like air, but I had a similar problem on my T100. I too changed the fluid, and bleed thouroughly. This actually helped a little. But still not the answer. It was hard to pinpoint. It turned out to be a cracked bracket the pedal arm attaches too. I found that it would flex and allow the pedal to go about 1/2 way before any disengagement. Got a new (redesigned I may add) bracket from the dealer, and it shifted kike new again!
Another thing to consider, could the clutch be simply worn out? As they wear, I believe they catch lower and lower as the throwout bearing and diaphram change operating position.
EDIT: I should have read your first post more carefully. Probably not worn if it is a 2005. Still not right. Take it to a different dealer, maybe try a similar model if they have one.
Something to look into anyway.
Good luck
