This is a discussion thread titled "Replacing differential & transfer oil", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 09-19-2002, 01:50 PM
Dealer : Stone Mountain Toyota Scion
tansu's Photo Albums
Last Online: 10-20-2007 02:15 PM
tansu is on a distinguished road.
Default Replacing differential & transfer oil
Looked in garage and search but did not find instructions on how to replace front/rear differential oil and transfer case oil.
Does somebody have the specific link?
Old 09-19-2002, 05:43 PM
Dealer : Lustine Toyota/Dodge
Andy's Photo Albums
Last Online: 10-16-2008 01:41 PM
Andy is on a distinguished road.
There is no formal write-up on this, just old posts that work just as good, plus tips, etc.
One of the links below talks about using a 12mm allen wrench for the front differential...it's actually a 10mm allen wrench. The changes are all very easy. Reading the threads posted below should answer all your questions.
Quantity Discussion
Procedure, Etc.
Good luck,
Andy
BFG A/T 285.75.16 / MT Classic II's / Fabtech Coilovers / TRD Add-a-Leafs / SkidRow skidplate / Snug Lid / Grey Line-X / Color-keyed front & rear bumpers / Hella Supertones / Husky floor liners / Amsoil bumper-to-bumper / K&N drop-in / Super Magnet oil drainplug / TRD radiator cap / 55w Aux reverse lights / DRL's disabled / Fog light mod / Map light mod / Power outlet mod / Back seat angle mod / Visor labels removed / TS sticker!
Old 09-19-2002, 06:04 PM
Inactive Account
delrmx01's Photo Albums
Last Online: 11-20-2004 01:42 AM
delrmx01 is on a distinguished road.
Are synthetics okay to use if I have a LSD ??
Old 09-19-2002, 06:05 PM
Inactive Account
John97's Photo Albums
Last Online: 05-12-2005 09:56 PM
John97 is on a distinguished road.
Send a message via ICQ to John97 Send a message via AIM to John97
Sure, just make sure the synthetic you use has the L/S additive in it, or just add it separately yourself.
Old 09-19-2002, 06:09 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
A couple of good tips--
1) Drive to warm up the oil before you drain it--cold gear oil drains slowly and less completely. You won't get all the oil out of the rear differential, but that's OK--the new stuff is completely compatible.
2) Be sure that you can get the fill plug out before you remove the drain plug. If you drain the gear oil and then can't get the fill plug out, you're stuck! Buy the right size wrench (24 mm socket?); don't try to use a Crescent wrench and round off the head.
3) Be sure that you have a filling arrangement that works--funnel, sucker gun, tubing, whatever you need, before you drain.
4) Warm the new gear oil, hot water bath, whatever,...it'll go in faster & easier.
Ken
Old 09-22-2002, 09:04 AM
Brian's Toy's Avatar
Dealer : Glen Motors
Brian's Toy's Photo Albums
Last Online: 07-29-2008 11:50 AM
Brian's Toy is on a distinguished road.
KLS,
Thanks for those pointers. I've got to remember them when I'm ready to do that service.
Brian
Old 09-23-2002, 10:18 AM
BirdDog0's Avatar
Dealer : Downtown Toyota Scion of Spokane
2000 Toyota Tundra,
- Other - 87 4-Runner
BirdDog0's Photo Albums
Last Online: 06-23-2008 06:04 PM
BirdDog0 is on a distinguished road.
Side note: Be sure that your oil has the GL-5 additive in it for the front end. It is a requirement for proper lube of the front end components (4WD coupler, bearings)...
2004 Pontiac GTO
2005 Dodge Magnum Special Edition SXT
1991 Honda Nighthawk 750
1987 4Runner
Old 09-23-2002, 11:08 AM
cappi's Avatar
Dealer : Spitzer Toyota
2001 Toyota Tundra,
2006 Toyota Sequoia
cappi's Photo Albums
Last Online: 11-17-2007 11:40 AM
cappi is on a distinguished road.
Default a little more info
I just did mine yesterday(using Mobil1) and here are a couple of extra tips...
1) Ken is right, it takes a 24mm socket for transfer case and rear end.
2) The front diff is an allen socket as previously posted but I think a T55 torx fits snugger to get it off.
3) A transfer pump to get the oil into the gearboxes is a must.
PS My fill and drain plugs were pretty easy to get off with the exception of the drain on the front differential. The darn thing cost me an hour in getting it off!
Old 09-23-2002, 01:31 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I'm sure a transfer pump works well, but I changed my gear oil with a combination of funnel, plastic tubing, and sucker gun....whatever works.
Ken
Old 09-23-2002, 02:55 PM
cappi's Avatar
2001 Toyota Tundra,
2006 Toyota Sequoia
Default pump
Ken
It's a hand pump. I got it at Autozone for $9. Works off a push/pull plunger.
Old 09-23-2002, 07:48 PM
DaveS's Avatar
Dealer : American Toyota
DaveS's Photo Albums
Last Online: 11-16-2008 12:05 PM
DaveS is on a distinguished road.
When I switched to synthetics in my rear differential, I also jacked up the drivers side rear to allow even more of the old oil to drain out...
2001 Silver Sky Metallic 4x2 SR5 V8 Access Cab TRD | JBA Titanium Ceramic Coated Headers | Ivan Stewart Aero Kit | Ivan Stewart Graphics and Plaque | ABS | Auto Dimming Temp/Compass Mirror | Toyota Chrome Tube Steps | Toyota UTR Bed Liner | Hidden Hitch receiver w/ DrawTite Wiring | Toyota VIP 3000 Security System | TRD Floor Mats | Alpine CDA-9811 HU | Sirius Sportster Satellite Radio | Polk Audio DB6500 Components (Front) | Polk Audio DB675 Coaxials (Rear) | Alpine MRP-F450 Amp. | JL Audio Stealthbox | JL Audio 250/1 Amp. | Total Chaos Steering Rack Bushings | Hellwig Rear Anti-Sway Bar w/ Greaseable Bushing Mod | Daystar Front Urethane Bushing Kit w/ Greaseable Bushing Mod | Optima 34R Battery | Russell Stainless Steel Brake Lines | Brembo rotors | OSRAM SilverStar Headlights | Sylvania SilverStar Fog Lights | 5 Michelin LTX M/S Tires and Extra Alloy Wheel for 5 Wheel Rotation | Wheel and Spare Tire Locks | Synthetic Fluids
Old 09-24-2002, 12:17 AM
Dealer : Stevens Creek Toyota
akauth's Photo Albums
Last Online: 11-16-2008 10:43 AM
akauth is on a distinguished road.
Or pour an extra quart of synthetic in before you put the drain plug back in. This will flush a lot of the junk in the bottom out (there is some for sure) and ensure that you have 100% clean synthetic in there.
I always do a flush like that regardless as to whether it's the engine, the trans, the transfer case, or the diffs.
Just put a little new fluid in to make sure all the old stuff is gone and then put the drain plug back in and finish the fill.
Alan
Old 09-29-2002, 08:34 AM
Good point Alan!
Brian
