Old 09-22-2002, 12:39 AM
ripshion's Avatar
Last Online: 02-06-2005 12:49 AM
ripshion may have some regrets.
ripshion's Photo Albums
Question Exhaust manifold stud removal question
Quick question for the people that installed aftermarket headers on their Tundra's. How do you remove the exhaust manifold studs? What did you remove it with? The stud looks like it has a torksen head on it, socket? what size? I just want to make sure I have the right tool when I do make the install.
Old 09-22-2002, 05:24 PM
ricqik's Avatar
Last Online: 03-19-2010 10:11 AM
ricqik may have some regrets.
ricqik's Photo Albums
You can use a small socket that fits. I don't remember the # of the socket. My sockets are Metrinch so it has that shape. Mine are design to work for both metric and standard with same socket.
Stuffs:
JBA Headers, Costum Exhaust, ASP U/D Pulley, Crossdrilled & Slotted Fr Rotors, LSD, IS Kit, Manik SS Steps, HID Headlights & Fogs, Blacked Out Headlight & corners, LED tail lights
Toys:
04 Skeeter ZX250 w/300 Vmax HPDI (79.35gps so far)
05 Polaris Sportsman 700TWIN EFI (rarely ride)
Old 09-22-2002, 06:21 PM
ripshion's Avatar
Thumbs up Thanks!
Thanks ricqik
Old 09-22-2002, 11:14 PM
Last Online: 10-14-2002 11:27 AM
odrspang may have some regrets.
odrspang's Photo Albums
Default torx
I belive its a female torx #10
Old 09-23-2002, 12:02 AM
ripshion's Avatar
Default odrspang thx!
OK, thanks alot!
Old 09-23-2002, 12:26 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 03-01-2010 12:45 AM
Dude Boy may have some regrets.
Dude Boy's Photo Albums
Can you get the headers on using the stock studs? Seems like it would be better to go that route rather than screwing a bolt into aluminum threads. You would be a lot less likely to strip any threads if you could keep the studs. I think someone has said they were able to do this.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 09-23-2002, 02:04 PM
Dealer : Toyota Scion of El Cajon
2005 Toyota Tundra
Last Online: 03-12-2010 10:32 PM
tundrafire may have some regrets.
tundrafire's Photo Albums My eBay
Default JBA headers on stock studs
I installed my JBAs on the stock studs without any problems to date (installed approx. 6 mo. ago). I periodically check the torque (when the engine is cold only) and haven't had any loosen up. The kit came with new bolts, so I saved them just in case. I also have a problem with removing studs from aluminum (for fear of cross-threading/stripping) so if it's not broken...
Old 09-23-2002, 09:56 PM
ripshion's Avatar
Default JBA's
Tundrafire,
I am thinking about installing some JBA's and wanted to ask you if you notice any true horsepower gain ie. low-end, high-end, all around horsepower performance? Just need some input before I pull the trigger! Also, what kind of exhaust system do you have on your Tundra? The JBA's that I want to install will be working with my Bassani system.
Old 09-24-2002, 12:21 AM
Dude Boy's Avatar
2000 Toyota Tundra,
Has anybody used the JBA headers, JBA gaskets, stock studs, and stock locking nuts? Will that work? That's what I'm thinking about trying if the studs are the right length, and the nuts seem to match up to the header flanges OK. Tried to get some gaskets from the Toyota dealer and they had only one in stock. They said that the Tundra doesn't have a problem with cracked manifolds. Also told me that the supercharger should be out in a month and that they would sell me a set of TRD headers for $996.00 (carry out price) Real helpful guys, huh?
Old 09-26-2002, 01:49 AM
Dude Boy's Avatar
2000 Toyota Tundra,
Does anyone have JBA's and hasn't put them on yet? Put a straight edge across your header flanges and see how far out they are. Mine are like a 1/16" out, or a bit more. The bolts will probably pull them up to where they would seal, but I'm a bit worried about leaks. Anyone else have this problem? Headers flanges not as flat as they should be.
Dude
Old 09-27-2002, 01:20 PM
ricqik's Avatar
Mine are on my truck already. But before I installed them I did wonder the same thing. Mine too has a gap of whhat you mentioned. I have a slight leak, not at the block but at the collector and stock exhaust.
Stuffs:
Toys:
