This is a discussion thread titled "Oxygen Sensors and Silicone Grease", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 10-28-2006, 05:14 AM
Dealer : Toyota of Greensburg
2005 Toyota Tundra
cookiemech's Photo Albums
Last Online: 02-07-2008 01:48 AM
cookiemech is on a distinguished road.
Default Oxygen Sensors and Silicone Grease
Does anyone have any hard evidence that use of silicone (sometimes called "dielectric") grease on spark plug boots causes contamination of oxygen sensors? I have read numerous articles warning against using coolant with silicates, since minor head gasket leaks will cause that to be burned in the combustion chamber(s) and thus contaminate the sensor(s); also, I have seen warnings not to use non-oxygen-sensor-safe sealants on valve covers or anywhere that the vapors could be drawn into the intake side of the engine. Also, silicone sprays are considered unacceptable as those may be drawn into the intake.
But I have not seen specific warnings about using a bit of silicone grease to ease installation of spark plug boots (in my experience, it makes this process much easier and permits removal without damage).
What's bothering me is that I have three recent experiences with spark plug changes after which oxygen sensor failures occurred within 1000 miles: 2002 Tundra V8 with just over 90,000 miles, 2001 Sienna with just over 90,000 miles, and most recently a 2000 Hyundai with 93,000 miles.
Coincidence? The only place I used the grease was inside the spark plug boots (well, you know, on the Sienna and Tundra the tube extending down from the individual coil).
Old 10-28-2006, 10:00 AM
Flashgordon's Avatar
"Rosco" P. Coltrane
Dealer : Toyota of Naperville
2006 Toyota 4Runner
Flashgordon's Photo Albums
Last Online: Today 09:15 PM
Flashgordon is on a distinguished road.
Default Re: Oxygen Sensors and Silicone Grease
I've never heard or read any hard evidence on dielectric grease when used on spark plug boots causes contamination of oxygen sensors. Actually the industry recommends that a "dab" of this grease be applied to the boot to aid in the conductivity and to seal out moisture.
Oxygen sensors, as you know go through extremes. I think the mileage you show of failures is about right and has nothing to do with spark plug replacement or the use of dielectric grease on the boots.
Coincidental?
I think so.....
**Benevento Bug Shield**WeatherTech Vent Shades**3M Body Skin; Bumper and Mirrors**3M Acrylic Head/Fog Light Covers**1" DayStar Front-End Coil Spacers**35% Drivers & Passengers Side Window Tint**Additional 20% Rear Window Tint**Air-Lift 1000 Brand Rear Air Suspension**Color Matched Grill**XM Radio**Nuvi 660 GPS**Home-Link Console**
Daytime Running Light Mod;
http://www.tundrasolutions.com/forum...light=easy+DRL
Old 11-10-2006, 02:58 AM
Cali-Tundra's Photo Albums
Last Online: 12-25-2007 02:55 PM
Cali-Tundra is on a distinguished road.
Send a message via Yahoo to Cali-Tundra
using dielectric grease on the boots should have no effect on the O2 sensors...silica based products, such as coolant, will cause contamination of the O2 sensors if they come in caontact...you can still use the same coolant, but if you ever have a head gasket leak and get coolant in the exhaust , you should also replace the O2 sensor(s)...and i would not recomend using any kind of silcone on the threads of the sensors either...hope this helps
2000 AC Tundra 4.7L
Old 11-10-2006, 09:28 AM
Dealer : Stevens Creek Toyota
- Other - 2006 Highlander AWD
ddvk's Photo Albums
Last Online: Today 09:59 PM
ddvk is on a distinguished road.
There is no truth to all this stories.
If you are that apprehensive about anti-sieze messing up O2s (which I don't believe), then put a tab of engine oil on the threads while replacing. This is what it is recommended by some .... But then there is nothing better than anti-seize!!!
Old 11-10-2006, 03:13 PM
I wouldnt consider Anti-Seize to be silicone, which is what i was talking about....
And if you say "there is not truth to all [these] stories," then why dont you correct it!
2000 AC Tundra 4.7L
Old 11-13-2006, 12:35 PM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Today 08:15 PM
not sure i understand where youre putting the di-grease...you mean youre putting a film over the outside of the coil, or putting the grease on the head of the spark plug to keep water from getting between the plug and the coil?
ive always used antisieze on the plug threads but i dont think that's what he's on about.
i didn't know it was industry recommended practice to use dielectric grease on the plug/coil interface. i suppose it also would make sense to use it where the coil seals to the block, is this ok as well or will the grease heat/smoke/etc? ive had water down the spark plug wells before.
-sean
GFX by FreedomEagle50
Manual Hubs
Old 11-15-2006, 07:40 PM
2005 Toyota Tundra
I use a small amount of dielectric grease between the spark plug boot and the insulator on the spark plug, the purpose being to facilitate installation of the boot. What I am imagining happening is the extremely hot environment around the spark plug vaporizing a bit of the silicone grease and that vapor finding its way into the induction system and contaminating the oxygen sensor(s).
Also I use a small dab of anti-seize paste on the spark plug threads, but I wasn't concerned about any effects from this (I've never heard that this poses a problem).
Old 11-15-2006, 07:52 PM
Dealer : Gray Daniels Toyota
2007 Toyota Tacoma
LIMITED's Photo Albums
Last Online: 10-20-2008 07:44 PM
LIMITED is on a distinguished road.
I should be ok I use it on all plug wires.
