KORE
Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "Exhaust leak? Ticking? What is it...", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-13-2007, 08:18 PM
Dealer : Checkered Flag Toyota
2002 Toyota Sequoia
htttrh's Photo Albums
Last Online: 01-26-2007 07:12 AM
htttrh is on a distinguished road.
Default Exhaust leak? Ticking? What is it...
I did introduce myself and have been searching like crazy on this engine noise I am experiencing.
My engine on my 2002 Sequoia LTD 4WD was quiet and purred like a kitten until 40k miles. Then I noticed as I drove thru the mountains in West Virginia what sounded like an exhaust leak near the engine(from engine bay). When I got to Ohio for a visit, I dropped into a Toyota dealership, I got blown off and was told Toyota considers this normal and they dont have a clue what it is(They did drive it)...that they have an employee with the same problem and has spent thousands trying to fix it with no luck.
I have read about relocating a wire or wire harness..anyone have pics of that so I can try that and does anyone have any information or a thread I may have missed(I search and read for a couple of hours) that may help me on this sputter or ticking sound,... it sounds more like an exhaust leak that anything else. I did opt for the Toyota platinum warranty bumper to bumper 100k...
In the mean time I guess I will inspect the heck out of it and see if I can see anything but any and all help is appreciated!! -Steve
Old 01-13-2007, 11:24 PM
Justang's Avatar
Dealer : South Coast Toyota Scion
2006 Toyota Tundra,
2002 Toyota Camry,
- Other - Mazda6
Justang's Photo Albums
Last Online: 05-21-2008 07:58 PM
Justang is on a distinguished road.
Default Re: Exhaust leak? Ticking? What is it...
I've never heard of the wire/harness relocation thing... but. Don't these engines have standard lifters (non-hydraulic) where the lash has to be adjusted? I think Toyota reccomends adjustment at 60k intervals.
The other thing is it could be a header/manifold tick. My truck with 20k does this. It didn't start until 15k, I thought for sure it was a leak. I took a stethoscope to then entire exhaust system while the truck was on a rack. No leaks anywhere. When the engine was revved, you could hear a loud tick coming from the exhaust manifolds. Put the stethoscope to the manifold and wow, it was deafening.
Just two options to think about. I've learned to live with mine. It only happens under moderate to loud acceleration. I just put a magnaflow on to cover the sound... lol. Probably not what you want to do with a Sequoia.
Hope that helps, and good luck.
2006 Toyota Tundra AC | Black | 4x4 | 5spd Auto | TeamWest Camburg C/O's |Camburg UCA's | MT Classic Locks | Tint | Magnaflow 18"
Old 01-14-2007, 05:19 AM
Flashgordon's Avatar
"Rosco" P. Coltrane
Dealer : Toyota of Naperville
2006 Toyota 4Runner
Flashgordon's Photo Albums
Last Online: Yesterday 07:07 PM
Flashgordon is on a distinguished road.
Steve, I've had this since day one on my '06 4Runner.
Toyota is aware of this problem, there is a TSB out for replacing the exhaust manifolds on newer Tundras', they are to "thin".
The injectors on my V6 are loud at idle then the exhaust ticking kicks in under light to moderate acceleration.
Even though the exhaust manifold part numbers are the same (Tundra to 4R), they won't do mine since it's a 4Runner and no TSB has been generated for those...yet.
Steve, can you hear it at idle or just under a load?
Like Justang, I've learned to live with it for now.
Justang, how much did the Magnaflow help?
**Benevento Bug Shield**WeatherTech Vent Shades**3M Body Skin; Bumper and Mirrors**3M Acrylic Head/Fog Light Covers**1" DayStar Front-End Coil Spacers**35% Drivers & Passengers Side Window Tint**Additional 20% Rear Window Tint**Air-Lift 1000 Brand Rear Air Suspension**Color Matched Grill**XM Radio**Nuvi 660 GPS**Home-Link Console**
Daytime Running Light Mod;
http://www.tundrasolutions.com/forum...light=easy+DRL
Old 01-14-2007, 06:35 AM
2002 Toyota Sequoia
Im going to go over it today and get back with you, it has just started recently and havent much time to investigate...I will get back here and tell you where its audible and all that and see if we come up with something. Get back with you guys later!
Old 01-14-2007, 08:42 AM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4
LGL002's Photo Albums
Last Online: 08-18-2008 05:42 PM
LGL002 is on a distinguished road.
I'd imagine it's a cracked exhaust manifold as that wasn't uncommon on early model Tundra and Sequoia's. They usually crack where the pipes are welded to the header/exhaust port flange at the heads and are impossible to see until removed. Normally the noise is most noticeable when the engine is first started with a slight load on it like backing out from your garage where there's something for it to reflect against and it's surroundings are relatively quiet.
On the Tundra's the other noise referenced is a ground wire on the right side (passenger side) of the firewall that can be relocated to the fender well at one of the power steering reservoir hold down bolts. It redirects some of the engine noise transmission through that ground wire away from the interior compartment.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Old 01-14-2007, 10:58 AM
Justang's Avatar
2006 Toyota Tundra,
2002 Toyota Camry,
- Other - Mazda6
It helped to cover some of the tick, but you can still hear it. But aleast you get the satisfaction of hearing the roar of the engine too.
I hadn't heard about the TSB for the exhaust manifold.
Old 01-14-2007, 11:00 AM
Picasso's Avatar
Dealer : Toyota of Dallas
Picasso's Photo Albums
Last Online: 02-23-2008 03:39 PM
Picasso is on a distinguished road.
Steve,
Welcome to TundraSolutions.
I second what LGL002 said. Another thing to try is to simply listen to the engine while it's running with the hood up and then compare that with what you hear while listening through the wheel wells.
When my manifold started leaking, the sound was far more noticeable through the left wheel well then any other place. Since the manifolds are lower on the engine, listening through the wheel wells will help determine this.
Pictures of my cracked manifold are in the S&S Headers Install album in my photo gallery. Just click on the tiny camera icon that is in the top right of this post.
Good luck.
Paul
Completed Mods:
S&S long tube headers
Brembo rotors
TSB caliper upgrade
Akebono ProAct ceramic pads
Stainless steel braided brake lines
Total Chaos steering rack bushings
Alignment to DJ's specs
Century cap
Line-X
XM Commander satellite radio w/USA Spec dual aux input adapter
Future Mods:
Rearview camera system
Sound deadener
Fusion Drive
Flux Capacitor Control Unit (FCCU)
Old 01-18-2007, 08:13 PM
2002 Toyota Sequoia
Thanks for the input, I took it to a new toyotaand they are calling it a "normal" injector noise. So I will keep looking, maybe thats all it is. Thanks for all the help!!!
Old 01-19-2007, 11:22 AM
Picasso's Avatar
If this were true, that would indicate that something in the injector had changed. I do not have a lot of experience with injectors, but this does not make sense to me in your case.
Tundra engines are not known for having injector noise issues. They are for exhaust manifold leaks.
Did you listen through the wheel wells to see if the sound was more pronounced there?
Good luck.
Paul
Completed Mods:
Brembo rotors
TSB caliper upgrade
Century cap
Line-X
Future Mods:
Sound deadener
Fusion Drive
Old 01-19-2007, 02:33 PM
Justang's Avatar
2006 Toyota Tundra,
2002 Toyota Camry,
- Other - Mazda6
Injectors are known to get noisy after so many miles.
Mine in my Mustang did at 60k. I ran Lucas injector cleaner and lubricant through the a tank and they were quiet for 10k miles or so.
Old 05-15-2007, 02:54 PM
YotaTruck's Avatar
Dealer : Cowansville Toyota
YotaTruck's Photo Albums
Last Online: 05-19-2008 10:20 AM
YotaTruck is on a distinguished road.
Thought I'd pipe in and offer a few sound files from my 2000 Tundra 4.7L which I believe has a cracked exhaust manifold. I recorded these using a microphone placed in the engine bay. Is this what you guys are hearing?
File Type: mp3 2000Tundra4.7L-TickingStartSequence.mp3 (342.5 KB, 128 views)
File Type: mp3 2000Tundra4.7L-Ticking Acceleration.mp3 (116.9 KB, 86 views)
Old 05-16-2007, 12:08 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Dude Boy's Photo Albums
Last Online: 02-24-2008 12:50 AM
Dude Boy is on a distinguished road.
I listened to the first and last sound clips and didn't hear your ticking. If it's the manifold, you should notice it more if you start it along side another car or a wall, with the window open. I replaced mine with headers and they are holding up a lot better than the original manifolds.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 05-17-2007, 02:53 PM
Picasso's Avatar
The ticking isn't very pronounced on the recording, but it does sound a lot like a leaky exhaust manifold. When this happens, the sound is typically more pronounced when the engine is either cold or only when it's warmed up. Mine only occurred with the engine running after cooling off for 15 mins after being warmed up.
Does your engine make this sound all of the time?
If your recorder allows you to listen with headphones while recording, you could use that as a means of locating the source of the sound. Tundra headers usually crack where the flared primary tube is held against the block by the flange. If you put the mike at each of the eight ports, I'll bet you'll find the leak.
Let us know what you find.
Paul
Completed Mods:
Brembo rotors
TSB caliper upgrade
Century cap
Line-X
Future Mods:
Sound deadener
Fusion Drive
Old 05-18-2007, 06:11 PM
Dealer : Sunnyside Toyota Scion
blue tundra's Photo Albums
Last Online: 03-31-2008 07:13 AM
blue tundra is on a distinguished road.
I had a similar sound on my 2001 Tundra, Dealer told me it was piston slap and it was normal. I had the exhaust manifolds changed with no improvement. Finally took it to another deal who quickly found a ripped weather seal or boot on the steering column which points right at the exhaust manifold and allows the sound to pass into the cabin. This may not be your problem but is worth the time to check.
Old 05-18-2007, 07:49 PM
YotaTruck's Avatar
Thanks for the replies guys. I don't think it's piston slap, but I could be wrong. It happens when the engine is cold, or after having stopped the engine for a few minutes, or even after a few minutes of idling at a light. It usually disappears when the engine is warm. It is very pronounced when listening outside through left (driver's) wheel well, and almost no sound in the passenger side wheel well.
I'd re-record it from the left wheel well, but don't have my microphone handy.
I'm pretty sure the driver's side manifold is cracked, but wanted to post good sound files to help other people quickly diagnose the sound and for my own reassurance that this is really what it sounds like. I'll try to get a new recording that is more pronounced.
Similar Threads for: Exhaust leak? Ticking? What is it...
2001 Sequoia exhaust manifold leak vgarzajr 1Gen-Sequoia 10 11-12-2006 10:49 PM
Ticking, Exhaust leak, Detonation, Piston slap Fireblade_rr Forced Induction Systems 0 04-02-2006 03:39 PM
Borla Exhaust Leak help PagalDesi4Life Engine & Drivetrain 4 03-17-2006 12:25 AM
Exhaust leak question? Leathernuts Engine & Drivetrain 6 04-19-2004 03:10 PM
Exhaust Leak? DRHeinz Engine & Drivetrain 4 07-29-2002 05:08 PM
Questions? Please use the Contact Us link. Dealer Hunter JPV Photography Consumer Electronics Hunter
