trans guage
+ Reply to Thread
Results 1 to 4 of 4
Thread: trans guage
  1. #1
    Lurking Member jrm1966 is on the right track. jrm1966 is on the right track.
    Join Date
    Oct 2006
    Location
    nashville
    Posts
    24
    Liked
    0 times
    Rep Power
    7
    Default trans guage
    Guys I hate to ask cause I am sure it is in here somewhere. Problem is- I am old and my eyes get tired. So I hope you don't mind a question.
    I am mounting a BM trans gauge and it says put it inline coming out of cooler/radiator return line. Which line is that on 2000 Tacoma 6 cly TRD? It tells on the instructions for GM-Ford but not Toyota.
    Also adding a trans cooler too. I see different views on here as where to tie in the gauge. Also I see different views on where to mount the cooler in line -in outgoing line or return to trans line.
    Can ya help an old cogger?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Oct 2006
    Location
    nashville
    Posts
    24
    Liked
    0 times
    Rep Power
    7
    Thread Starter
    Question Re: trans guage
    Need help-any you guys have an answer??
    Thanks
  4. #3
    Junior Member MatildaSue is on a distinguished road.
    Join Date
    Mar 2006
    Location
    Bay Area
    Posts
    61
    Liked
    0 times
    Rep Power
    8
    Default Re: trans guage
    You might want to try another forum that is more mechanically inclined. I own a toyota too and never work on my truck. However when I owned a dodge I found dodgedakotas.com a decent site for technical questions; even if you don't own a dodge you might be able to word it to fit you needs. Hope that helps.
  5. #4
    Veteran Member ICON is a name known to all. ICON is a name known to all. ICON is a name known to all. ICON is a name known to all. ICON is a name known to all. ICON is a name known to all. ICON is a name known to all. ICON is a name known to all. ICON is a name known to all. ICON is a name known to all. ICON is a name known to all. ICON's Avatar
    Join Date
    Nov 2005
    Location
    Monson,ma
    Posts
    565
    Liked
    1 times
    Images
    8
    Rep Power
    264
    You want it to reflect the worse case senario, so you want it in the output line to the cooler. The input to the tranny will tell you what temp the cooled fluid is, which doesn't matter if the fluid coming out is being cooked.
    As for the cooler, i believe you want the auxilary cooler before it goes into the radiator, which should not be eliminated. The reasoning behind this, as told to me by a tranny pro, is that the radiator cooler does a couple things: it obviously lowers the trans fluid temp but it also aids in warming the fluid up on cold mornings by the warm coolant flowing in the rad. Placing the aux cooler AFTER the rad would eliminate this benefit.
    '06 AC SR5 4x4
    '05 Honda Foreman 500S 4x4
    '04 Honda Shadow Sabre 1100
  1. will 4 guage make a difference?
    By uracowman in forum Audio & Stereo
    Last Post: 12-21-2003, 03:58 AM
  2. 2003 V6 Auto Trans Cooler Install?
    By Bonefish in forum Engine & Drivetrain
    Last Post: 10-18-2003, 08:29 AM
  3. Inaccurate reading onOil Pressure Guage
    By Preludetundra in forum Engine & Drivetrain
    Last Post: 09-15-2003, 12:12 PM
  4. Oil Pressure Guage Redux . . .
    By rcl4668 in forum 1Gen-Sequoia
    Last Post: 08-10-2003, 05:47 AM
  5. Finally got around to flushing my trans with Amsoil synthetic
    By akauth in forum Engine & Drivetrain
    Last Post: 10-30-2002, 04:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
