Is it possible to modify an '02 Sequoia center diff to lock in 4HI?
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: Is it possible to modify an '02 Sequoia center diff to lock in 4HI?
  1. #1
    Rookie JohnnyStep is on a distinguished road.
    Join Date
    Jun 2005
    Location
    Chicago suburbs
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Default Is it possible to modify an '02 Sequoia center diff to lock in 4HI?
    I really, really hate that I can't lock the center diff on my '02 Sequoia without being in 4LO, low gear. I ran across this article today that shows how to do a wiring mod to bypass a similar restriction on a Jeep Wrangler Rubicon:
    ROCKCRAWLER.com - Jeep Rubicon Locker Bypass
    Is there a way to enable the '02 Sequoia center diff to lock in 4HI by doing a similar modification? I'm way out of warranty, so I'm not the least bit concerned about that.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member CT-Tundra is on a distinguished road. CT-Tundra's Avatar
    Join Date
    Oct 2005
    Location
    CT
    Posts
    227
    Liked
    0 times
    Rep Power
    7
    Default Re: Is it possible to modify an '02 Sequoia center diff to lock in 4HI?
    I've done the Jeep Rubicon bypass. That has nothing to do with a center locking differential- that fix allows the axle air lockers operate in 4Hi as well as 4Lo. It's just a ground wire with a switch that defeats a relay. Nothing fancy and of debatable uselessfullness (probably should never be in 4Hi with lockers ON). Maybe some cases in sand dunes or snow, but not much else.
    A center locking differential allows the front and rear outputs of the transfer case to be selectably 'locked' together with equal rotational output. There's some cases where that woudl be useful, but I'd be careful in 4Hi- especially on pavement. That center locking diff will REALLY shine in 4Lo when off-road.
    I'd ask at yotatech.com or maybe even the Toyota forum at pirate4x4.com (be careful there....).
    2005 Tundra Access Cab 4x4 4.7L - BFG ATs on MT Classic Locks - Warn M8000
  4. #3
    Join Date
    Jun 2005
    Location
    Chicago suburbs
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by CT-Tundra View Post
    I posted over at Yotatech.com, too, but haven't gotten any responses. The Sequoia forum seems pretty dead. Sequoias seem to be the odd man out for off-road mods and such.
    I will try over at pirate4x4.com, but I gotta ask.... what am I being careful about?
    --John
  5. #4
    Junior Member Matador98 is on a distinguished road. Matador98's Avatar
    Join Date
    Feb 2004
    Location
    Santa Maria, CA
    Age
    31
    Posts
    396
    Liked
    0 times
    Images
    20
    Rep Power
    9
    Be careful, because the guys on pirate can be ********.
    Try over on IH8Mud as well. There is a 7-pin Mod that can be done to Land Cruisers with CDLs that might work for you, or there might be somebody out there with LC that knows a Sequoia. Do a search, there is a ton of info. Who knows, the systems might be almost the same.
    2006 Tundra DC, 80K, K&N Drop-in, Spintech Truck/RV Muffler, BedRug, Bilstein 5100s, VSE Sub
    Previously 2000 Tundra, 94K, K&N Drop-in, Spintech Truck/RV Muffler, Hellwig, Bilstein 5100s, 2005 Sequoia Center Console Installed and looking awesome! - TOTALLED
    1999 UZJ100 Land Cruiser, 225K, new carpet, no major Mods planned; it's the wifeys
    1987 FJ60 Land Cruiser, 209K, K&N Drop-in, Jacobs Ignition, Jacobs Wires, Dynomax Muffler and Hi-Flow Cat, Electric Fuel Pump Conversion, Rebuilt Carb, Rebuilt Combination Manifold, SS EGR Tube, Someday...A Lift
    Proud Member of the CBTMA
  6. #5
    Join Date
    Jun 2005
    Location
    Chicago suburbs
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by Matador98 View Post
    Thanks for the tip. That's very encouraging to hear that there's a mod for the LCs. If that's the case, I'm SURE there's got to be something for the Sequoia.
    If the rest of the driveline components didn't change from '02 to '03 on the Sequoias, then it would seem that only a minor mod should be needed to enable center diff locking in 4HI. In other words, if the '03 components can handle doing this, then the '02 should be able to as well, if everything's pretty much the same (differentials, axles, driveshaft, etc.)
    --John
  1. 2002 SEQUOIA - Auto Lock Doors No More ??
    By gnb in forum 1Gen-Sequoia
    Last Post: 08-26-2007, 06:52 PM
  2. 2003 Sequoia Door Lock programming - confused
    By grice in forum Electrical & Computer Systems
    Last Post: 09-24-2006, 03:22 PM
  3. What is your driving condition like in the snow?
    By PagalDesi4Life in forum 1Gen-Sequoia
    Last Post: 08-23-2005, 09:37 AM
  4. Diff lock vs. LSD
    By quicksilvr in forum Tacoma
    Last Post: 04-17-2005, 04:51 PM
  5. Electrical Rear Diff Lock
    By deanaddy in forum Engine & Drivetrain
    Last Post: 11-24-2004, 01:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
