Old 11-07-2002, 12:41 AM
Last Online: 08-11-2003 02:46 PM
autoteach is on a distinguished road.
autoteach's Photo Albums
Wink tade off that gas/power robbing fan
toyota put on a large radiator fan and an thermostatic fan clutch on the tundra that keeps the fan roaring all the time. this is good if you are towing or hauling a load, but most people don't. so you can drill a hole in the fan clutch on the engine side and drain the oil out. the fan will now spin free. thread the hole and put in a bolt to keep a little oil in for lubrication. if you ever need more cooling than the electric fans which you will mount, can give--you can turn the bolt further in. this will lock the fan solid till you don't need the extra cooling, then back the bolt out. move the horns to each side of the radiator. if you are smart you have mounted another transmission oil cooler between the radiator & the a c condensor, and another trans cooler high on the left side in front of the condensor. the little extra trans cooler that was there can be moved and used as a power steering fluid cooler. a 14 inch fan can now be mounted high on the right side over the condensor and a 16 inch mounted low on the left side. each fan is controled by an adjustable thermostat with the temp pick up taped to the upper radiator hose. the right fan is controled by a thermostat(kragen/checker) that turns on the fan when the air coditioner is on and also when it reaches a temperature right before the temp gauge move off it's normal position. you will get over 1 mile per gallon more, more power, and it will be quieter. 40 years as a auto shop teacher and mechanic helped me develope this procedure.
Old 11-07-2002, 01:43 AM
Banned
2008 Toyota Tundra SR5 CM TRD 4x4 5.7,
- Other - Toyota FJ60
Last Online: 07-18-2008 12:35 PM
Sequoia2003 may have some regrets.
Sequoia2003's Photo Albums
Default Too much work
Too much work for 6hp. Thanks for the info though, never thought of that before.
Old 11-07-2002, 06:47 AM
PXLpainter's Avatar
Moderator
Dealer : Manhattan Beach Toyota
2006 Toyota Camry-Solara V6 SLE Convertible
Last Online: 11-06-2009 11:51 AM
Images: 9
PXLpainter is on a distinguished road.
PXLpainter's Photo Albums
This might be a good procedure to do a step-by-step with photos for the Garage.
Really interesting and thorough - thanks for sharing!
Jeff
PXLpainter
• 2001 SR5 Tundra (sold)
• 2006 Solara SLE Convertible (sold)
• 2008 FJ Cruiser - TRD Edition
Old 11-07-2002, 08:07 AM
Last Online: 08-12-2003 06:14 AM
BillD is on a distinguished road.
BillD's Photo Albums
Think mine will stay just as is, thank you.
Correct me if I'm wrong, but it was my understanding that a thermostatic fan clutch operates as the name implies, responding to underhood temperatures. When the engine is cold the fan is disconnected, when too much heat is generated the fan is allowed to cool the engine. A bi-metallic thermostatic coil senses the underhood temperature and operates the clutch accordingly.
Old 11-07-2002, 10:52 AM
Tundra 5150's Avatar
Dealer : Folsom Lake Toyota Scion
2002 Toyota Camry
Last Online: 01-17-2009 01:17 PM
Tundra 5150 is on a distinguished road.
Tundra 5150's Photo Albums
You are indeed correct. The only time it is engaged when its cold is after initial startup from sitting over night. Immediately after shutting down underhood temps go up from lack of air movement thereby heating up the bi-metallic spring to allow max engagement. That's why the fan seems to roar on a cold morning. At this time the spring is cold and set to allow minimal engagement. The fan will quiet down after the revs put enough centrifugal force on the fluid to expel it out of the cavity and disengage it. Then, all is quiet till things heat up. In the summer time, they seem to run full time with the A/C running-as they should. Sometimes on a setup like the Tundra's A/C cooling capacity is diminished when only an electric fan is used as many of these do not provide the volume of air the stock fan gives. Often to gain equivalent volume from an electric you will have to use such a large fan that there will be a high amp load on the alternator giving you back the parasitic drag. Along with reduced alternator life, you get into the law of diminshing returns. Furthermore, a clutch fan is never fully locked. Using a bolt to fully lock the fan will give poor mileage and negate any previous gain. This is a truck so it will have truck like characteristics.
So yeah, mine will stay as is too. Thank you.
Old 11-07-2002, 01:56 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I thought the fan roared first thing in the morning because the silicone oil (thicker when hot, thin when cold) settles to the bottom overnight and needs a few seconds to get redistributed to do it's job...whatever.
Anyway, no thanks. My truck is fine when towing 5000# in 109°F weather and running light in -20°F weather. I do have an additional ATF cooler for those towing days.
Ken
Old 11-07-2002, 02:39 PM
Hover's Avatar
Dealer : Cavender Toyota
Last Online: 11-02-2008 01:02 PM
Hover is on a distinguished road.
Send a message via ICQ to Hover Hover's Photo Albums
My engine roars like a huge mountain beast in heat whenever i've been in fastfood place's drivethrough for a while. Especially when you have to pull out onto an access road at 45mph. It kinda scared me the first few times, but then I realized it was because I had been sitting so long with the A/C on in this good ol' Texas heat.
-Hover
<About to post a question? Try Searching the forums first!>[/b]
Old 11-07-2002, 05:35 PM
Last Online: 05-18-2006 09:50 AM
Tundra_Jules is on a distinguished road.
Tundra_Jules's Photo Albums
Ken-I'm with you. Ain't no way I would start messing around with the fan clutch. If it's broken, I would replace it, but I'm certainly not going to mess with something as vital to the health of my engine as the cooling system to gain an insignificant 6hp. The risk is too great.
What's a new engine go for these days anyway?
Old 11-08-2002, 03:20 AM
Rlockyer's Avatar
Dealer : Crown Toyota Scion
2004 Toyota RAV4
Rlockyer is on a distinguished road.
Rlockyer's Photo Albums
Originally posted by Hover
011010010010000001101100011011110111011001
100101001000000110110101111001001000000111
010001110101011011100110010001110010011000
0100000000
Okay, I converted it to hex and came up with 69206C6F7665206D792074756E64726100
I'm assuming that it has some significance in octal or decimal?
I was thinking that it might spell something interesting in hex... but what can you spell using only the letters A-F?
Old 11-08-2002, 03:41 AM
Agent WD-40's Avatar
Dealer : Fox Toyota of Rochester
Last Online: 11-18-2009 01:44 PM
Images: 12
Agent WD-40 is on a distinguished road.
Agent WD-40's Photo Albums
Is it ASCII code?
Old 11-08-2002, 05:05 AM
Rlockyer's Avatar
2004 Toyota RAV4
Originally posted by Agent WD-40
Is it ASCII code?
Yikes... I'm not THAT talented.
Binary to hex is easy.
Old 11-08-2002, 02:32 PM
Last Online: 12-19-2002 12:23 PM
crfralick is on a distinguished road.
crfralick's Photo Albums
Unhappy OOOKAYYYYY!
You guys are really starting to scare me now.
Old 11-08-2002, 05:36 PM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ will become famous soon enough. DJ will become famous soon enough.
DJ's Photo Albums
Is it ASCII code?
Yup. Hex '69206C6F7665206D792074756E64726100' spells "i love my tundra". Hmmm ...
Old 11-08-2002, 06:21 PM
Images: 12
Default Re: OOOKAYYYYY!
Don't worry, its just us nerds doing nerdy stuff. My fellow nerds and I will retire to the nerdery with our calculators now.
Old 11-08-2002, 07:03 PM
Hover's Avatar
It's binary...
i love my tundra
-Hover
