Be very careful that the universal sensor is an true replacement for what you are removing. I do not know the specifics of the Tundra sensors, but on Siennas they are "air/fuel ratio sensors" on 2001-up models. What that is, is a wideband oxygen sensor which is not the same as a "universal" oxygen sensor and the two are not electrically compatible. Installing the universal sensor (which fits just fine) causes another check engine light very quickly. In my experience the universal sensor is cheap (~$80), while the OEM A/F ratio sensor costs more (~$200). Note that if the universal sensor doesn't work properly, now the experience costs $280. DAMHIK
