Hello all
3 1/2 years 76K on the Truck, no issues in performance and maintenance of the header. Solid performance as day one.
the Headers are very discolored. I tried to clean a little area and underneath all that stain is still stainless steel brightness. All the bolts are rusted.
One issue not related to the header performance is that I have now a check engine light.
Plug my laptop base OBD2reader and returned back an code P0155 Faulty O2 sensor(Bank2, Sensor1)
P0155 Code means on my Tundra is
BANK 2 - passenger side (Bank1 means driver side)
Sensor 1 - Front before CAT (Sensor 2 is after CAT)
History,
Original SS autochrome headers 00 to 04 3 years ago has one flaw.
The O2 sensor bunyong on the passenger side header was pointing directly to the side of the engine block instead of pointing down to the ground. That leaves me 1/32 of an inch clearance between the 4 wires of the O2 sensor to the engine block for clearance.
No way this baby will come out or be able to put a new one in without loosing or removing the header and flanges.
Back then 3 1/2 years ago, since the original manifold/sensor where taken out of the truck, I just transferred the original O2 to the new header and did not think I will ever pull/remove the O2 sensor out again.
Wrong,
76K later, and kicking myself as I type this message, I should have just waited 1 more year for Version 2 release with the correct O2 Sensor location.
So now, I am stuck and dreading 2 weekend to take out and put back the passenger SS header out.
Then I have to take the header to my favorite muffler shop. Have them plug up the original bunyong hole and weld a new one on the corrected position.
My favorite muffler shop say it should be fine doing this.
One more thing, SS Autochrome tech support back then was a PITA to deal with. I called SS Tech to see if I can order a spare gasket set.
Hopefully that change now. Still remember how I dreaded the 45 to 1 hour wait time rude tech experience back then.
Because I need a new gasket set and do not want to contact SS Autochrome tech support again, I just decided to go and contact JBA for the gasket set (Just the cylinder head/manifold gasket), not getting the Flange collector/downpipe gasket as tech support from JBA say that the flange gasket is the current o-ring from toyota and i need the flat triangle 3 hole gasket.
Hope this help for SS autochrome headers owners
