This is a discussion thread titled "Trouble Code 0430 and Rear Driveshaft problems.", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-26-2007, 05:16 PM
Dealer : Gene Messer Toyota
FiberodTundra's Photo Albums
Last Online: 11-04-2008 08:04 PM
FiberodTundra is on a distinguished road.
Default Trouble Code 0430 and Rear Driveshaft problems.
The check engine light came on a while ago and gave me this code. Anyone know what it is? Also, how do I get the stinkin drive shaft out. I have taken the rear nuts and bolt out of the rear yoke and the one from the front. I have yanked and pulled and pryed. Are they just prone to rusting in place? Do I need a bigger hammer? I am trying to change out the carrier bearing.
'01 Tundra SR5 4x4 TRD Equipped Access Cab. This truck is currently being rusurrected for company use.
Old 03-27-2007, 01:00 AM
apimpdad's Avatar
2002 Toyota Tundra
My eBay apimpdad's Photo Albums
Last Online: Today 07:34 PM
apimpdad is on a distinguished road.
Send a message via AIM to apimpdad
Default Re: Trouble Code 0430 and Rear Driveshaft problems.
well i dont know about the code but the driveshaft.... well i have had to take mine out twice. first off dont forget the 2 bolts for the carrier bearing, i used a flathead screwdriver and a regular hammer and started knocking it loose where it was attatched . it will eventually come out but just dont drop it on yourself like i almost did.
2002 Tundra-SAS-Dana 50-Sterling 10.5-Inchworm 2.28 Dual Transfer Case-4.56 Gears-38.5 Thornbirds-ASP Underdrive Pulley-Flowmaster Muffler
Build Thread-
SAS on 02 Tundra
Old 03-27-2007, 05:24 AM
Dealer : Michael Toyota
TS Support's Photo Albums
TS Support is on a distinguished road.
P0420(Bank 1)/P0430(Bank 2)
After engine and catalyst are warmed up, and while vehicle is
driven within set vehicle and engine speed range, waveforms
of heated oxygen sensors have same amplitude (2 trip detection
logic)
 Gas leak on exhaust system
 Heated oxygen sensor
 Three-way catalytic converter
The Tundra Solutions Forums staff
Old 03-27-2007, 12:19 PM
Dealer : Stevens Creek Toyota
- Other - 2006 Highlander AWD
ddvk's Photo Albums
Last Online: Today 05:57 PM
ddvk is on a distinguished road.
The most likely culprit is a lazy or dead O2 sensor. Cats/pre-cats have been along for decades, their premature death does seldom happens.
Since urs is a 2K1 vehicle, it is time for the O2s to be replaced anyway!!!
Old 03-27-2007, 03:24 PM
Driveshaft problem solved. BIGGER hammer and pry bar. I greased up the joints and replaced the carrier bearing and allis good now. As for the trouble code, I replaced the rear o2 sensor on the passenger side after the cat. I'll go ahead and order sensor for the front tomorrow. Also, is there an easier way to get the front driveshaft out without having to pull the transmission crossmember out? The output shaft seal on the transfer case is shot and needs to be replaced.
