I may be mistaken...but aren’t the threads of a spark plug stainless steel?
If they are, and considering the seal provided by the grommet on the coil pack, galvanic corrosion should not occur.
I could see this as an issue if you were constantly blasting your engine with a pressure washer and had no seal on the spark plug chamber, but that area should remain bone dry.
I'd lean toward giving the Toyota engineers the credit due, and feel good assuming they have considered and researched the use and potential problems of dissimilar metals.
I just can’t see them designing such advanced engines to overlook or ignore any detail that may discredit their reputation for very well thought out power plants, especially something as simple as corroding spark plugs.
No moisture, anti seize compound, and a quality plug you should be fine.
If I am incorrect, be assured one of our esteemed members will promptly provide a more appropriate response.
I'd say search some of the shimmy...I mean Chevy forums for issues with the corvette, or some other maker who has used aluminum heads for several years.
