Old 05-08-2007, 09:17 PM
Dealer : Central Florida Toyota Scion
2005 Toyota Tacoma
Last Online: 11-08-2008 03:34 PM
rymigo is on a distinguished road.
rymigo's Photo Albums
Default Bad Oil Change?????
ok i just got done changing my oil from the reg blend to sythetic. The joker at the dealership told me that my 6 cyl tacoma takes 5 1/2 quarts...not sure if this is the problem....but...
now i changed the oil filter and added the new oil...but my motor sounds like its strangling a cat when the rpms rev up....i did something wrong....this is the first time i did my own oil change on this truck. its an 06 tacoma....can someone help?
Old 05-08-2007, 09:21 PM
2005 Toyota Tacoma
Default Re: Bad Oil Change?????
also when changing the filter some oil did get on the main belt...so i dont know
Old 05-08-2007, 09:33 PM
Dealer : High River Toyota
1999 Toyota Sienna
Last Online: 11-18-2009 01:04 PM
volvo4fun is on a distinguished road.
volvo4fun's Photo Albums
100% sure you put in engine oil, not water or whatever?
Did you check the oil level?
Does it sounds like a squeeling belt?
With the correct oil level or something close to it, you are going to be fine. Unless of course you had a catastrophic engine failure right at the moment of the oil change. If that is the case we are going to be talking about this for a long time.
Robert
Old 05-08-2007, 10:00 PM
Dealer : Superior Toyota
2003 Toyota Tacoma
Last Online: 10-24-2007 10:54 AM
pug407 is on a distinguished road.
pug407's Photo Albums
When you change the oil you need to follow 2 steps:
1) Prior to the change: check the correct grade of oil that your truck uses, how much oil and the correct oil and filter. Also you need to know where the oil fill cap is, oil drain plug and where is the oil filter. Also you need to know where the drain plug of the transmission (automatic or manual) is so you won't get confused. Have the wrench for the plug in hand, a funnel, rags (for cleaning) and maybe an oil filter wrench.
2) When you change it: open the oil fill cap, take out the oil dipstick, place a container that holds more than the capacity of the oil your taking out under the truck and take out the oil drain plug with the wrench first then with the hand not letting the plug get in the container. Wait until all the oil is draining and replace the oil filter with a new one (apply a thin layer of new oil to the filter gasket befor installation )
Clean the plug and put it back, tightening with the wrench. Using the funnel add the recommended amount of oil. Replace the fill cap, and the dip stick (after cleaning it).
Start the truck, check for the oil indicator in the dash, it should be on for a few seconds then off, it's normal. If stays on the pressure is low and you have done something wrong, maybe too little oil or the filter is loose...
After the light goes off step on the gas several times and after a couple of minutes switch off the engine. wait 5 minutes and check the oil in the dipstick, it should be between the min and max points.
If you did this when you changed the oil the problem is somewhere else, if you're not sure check with a mechanic to see what went wrong.
Hope this helps...
Old 05-08-2007, 11:21 PM
Dealer : Harrelson Toyota
2006 Toyota Tacoma
Last Online: 02-08-2009 12:06 AM
tacomaman06 is on a distinguished road.
tacomaman06's Photo Albums
just let it run a bit( after youve made sure that your oil level is correct and everything is tight!!), cause if oil did get on the belt, it will make it squeal until
it either dries, or soaks into the belt( and if this is the case..soaked in, you may want to change your belt), other than that....you should be ok!! and 5.5 quarts is correct......check your manual for capacities,as its relatively close on everything! hope this helps. keep us posted!!
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 05:25 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
1st Oil Change on New Tundra - Service Rep's Claim?? SportRallyFiveSpeed 1Gen-Tundra 61 12-01-2006 10:53 AM
GEORGE! or anyone else..Whats The Best "DINO" Oil nhparrot Engine & Drivetrain 0 03-28-2002 04:21 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
