2000 Tundra-Where's The Thermostat
+ Reply to Thread
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By dyogim
Thread: 2000 Tundra-Where's The Thermostat
  1. #1
    Join Date
    Sep 2006
    Location
    Canada
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Default 2000 Tundra-Where's The Thermostat
    Just wondering where it's located and how hard it is to replace.
    2000 Toyota Tundra V8
    Thanks,
    -=Jasper=-
    2004 Toyota Tundra TRD 4X4
    2006 Honda CRV SE
    2006 Bombardier Renegade 800HO
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member drewbush's Avatar
    Join Date
    Jan 2004
    Location
    Redondo Beach
    Posts
    152
    Liked
    0 times
    Rep Power
    12
    Default Re: 2000 Tundra-Where's The Thermostat
    just follow the upper radiator hose to where it attaches to the engine. Three 10mm bolts hold down the housing. you will want to drain a little coolant out before removing it.
  4. #3
    Join Date
    Oct 2006
    Location
    Austin, TX
    Age
    41
    Posts
    481
    Liked
    4 times
    Rep Power
    9
    I was following your other thread regarding tranny fluid and tranny problems. I will do the following, buy new radiator, thermostat and good Hayden heavy duty ATF cooler.
    1) Drain the radiator and block of coolant.
    2) Replace thermostat and possibly the upper and lower radiator hoses along with the pressure clamps if you have money to do the job thoroughly.
    3) Flush the radiator with fresh Toyota coolant.
    4) Install a new Hayden cooler for the ATF, there must be enough space to install it and hook up the return line in series with the cooling from the radiator.
    5) Flush the entire tranny and TC with fresh ATF.
    Then only go into investing $2500 on the tranny.
  5. #4
    Join Date
    Feb 2008
    Location
    Gardnerville NV
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by drewbush View Post
    I know this is a little late, but I thought I'd add to this based on my experience with my 2000 Tundra V8 (2UZFE engine).
    I found the thermostat in my truck by following the bottom radiator hose. The hose was connected to a die-cast part with 3 screws (I used a 12mm socket that is now somewhere in the skid plate). I had to remove the hose to get to the bottom screw.
  6. #5
    SAS'ed #5 dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    36
    Posts
    6,482
    Liked
    315 times
    Images
    119
    Rep Power
    24698
    This should help.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Cooling 2UZ-FE - thermostat.JPG
ID:	29145   Click image for larger version.
Name:	Cooling 5VZ-FE - water pump.JPG
  7. #6
    Join Date
    Feb 2015
    Location
    littlerock,CA
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    I think you are correct in saying the thermostat is located on the lower hose at the engine. Everybody keeps saying it is the top radiator hose. I need to change mine but I have been waiting for someone to concur that it's on the lower hose at the engine. Is that where you found it?
  8. #7
    DJ
    DJ is offline
    Join Date
    Sep 2000
    Location
    Newcastle, OK
    Posts
    2,342
    Liked
    525 times
    Rep Power
    25421
    Quote Originally Posted by mytoys View Post
    I think you are correct in saying the thermostat is located on the lower hose at the engine. ... Is that where you found it?
    Yes. I have replaced the timing belt twice in my '00 Tundra (Access Cab V8 4WD), and both times I replaced the thermostat. They get old and weak, and the time to change it is when the whole system is drained down anyway. It is as the diagram below shows, at the engine end of the lower radiator hose.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
