How many miles can we expect a 4.7L V8 to last? - Page 4
+ Reply to Thread
Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 69
Like Tree6Likes
Thread: How many miles can we expect a 4.7L V8 to last?
  1. #46
    Veteran Member Dude Boy's Avatar
    Join Date
    Feb 2000
    Location
    Northern Oregon
    Age
    69
    Posts
    1,462
    Liked
    6 times
    Rep Power
    1078
    One of the newer TS members got 81 miles out of his I-Force before it let go.
    81 miles
    ADDING POWER HAS NEVER BEEN SO FAST!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #47
    Supporter Verndog's Avatar
    Join Date
    Jun 2003
    Location
    Auburn, Wa.
    Posts
    1,377
    Liked
    1 times
    Rep Power
    14
    Thread Starter
    81 miles
    Wow....that is one ugly story. Man...if that happened to me....I'd be demanding a new truck. Turned out OK in the end....but a bummer for the poor soul that bought his "great deal discounted" 81 mile TRD.
    2003 Silver Sky TRD SR5 V8 4x4 Access Cab
    My 69 Mach 1 Pics
    Factory Options:
    TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
    Appearance Mods:
    PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
    Performance Mods:
    Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
  4. #48
    Join Date
    May 2008
    Location
    IA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default Re: How many miles can we expect a 4.7L V8 to last?
    My 2000 tundra V8 now has 144,000 miles. I bought it used and never knew if the timing belt was ever changed. I had procrastinated but decided to be safe and had it done yesterday. My mechanic advised I was very lucky as the belt was close to failing. You could see deep exterior cracks about every 1/4 inch all the way around. The mechanic said he had never seen one with this many cracks that was still working. Be advised. Don't wait too long.
  5. #49
    Supporter redbaron224's Avatar
    Join Date
    Sep 2002
    Location
    Western NC
    Age
    49
    Posts
    350
    Liked
    0 times
    Rep Power
    13
    I just passed 232,000 miles on my 4.7L. Doesn't leak or burn a drop of oil between changes either. Take care of it and you will be taken care of.
    My Ride: White 2000 Tundra Limited Access Cab, V8, 4WD, TRD with 267,834 miles
    MODS:
    SUSPENSION: front - Cornfed 2" lift, rear - TRD add-a-leafs. EXTERIOR: Ventvisors, UTR bed liner, Reese hitch ELECTRICAL: Alarm and remote start package, Prodigy Brake Controller ENGINE/DRIVETRAIN:Nitto Trail 285/75/R16 wrapped around Mickey Thompson Classics. Cat Back dual custom exhaust with glass packs and 2 1/2" Stainless tips straight back. Air intake box mod.
    Wife's Ride: Gray 2010 Sequoia Limited, 5.7L, 4WD, with 61,104 miles
    MODS:
    EXTERIOR: Weathertech Window Vents
  6. #50
    Veteran Member waiting tundra's Avatar
    Join Date
    Aug 2008
    Location
    oil slick central
    Posts
    1,846
    Liked
    178 times
    Images
    1
    Rep Power
    231468
    Quote Originally Posted by weavdog View Post
    How much money did it cost you to do the change?
  7. #51
    Veteran Member kathyricks's Avatar
    Join Date
    May 2007
    Location
    Salem
    Posts
    798
    Liked
    4 times
    Rep Power
    9
    The 4.7 is an old school, proven, bulletproof design based on the 1989 Lexus 4.0 V8. Well almost bulletproof (has weaker connecting rods than the 1989 Lexus 4.0 V8 so be careful not to overrev the 4.7).
    The 5.7 is all new (has resin coated internals, the 4 timing chains and the hydraulic roller rocker arm valve lifters). So it's the 5.7 owner who will be the test mules that will end up learning whether or not the motor has design weaknesses or not as the miles pile up.
  8. #52
    Supporter NHtoyman's Avatar
    Join Date
    Apr 2008
    Location
    boscawen, NH
    Age
    41
    Posts
    217
    Liked
    0 times
    Images
    5
    Rep Power
    8
    I have 153k on my 2004 4.7. Thing still rocks out. I know a couple people that had 250k when they got rid of them. Take care of your engine and it will take care of you.
    Love my Truck.
  9. #53
    Veteran Member Hi Volt's Avatar
    Join Date
    Aug 2007
    Location
    Langley, BC
    Posts
    554
    Liked
    70 times
    Images
    7
    Rep Power
    8223
    Quote Originally Posted by redbaron224 View Post
    Ditto, 367,000 Km ( 229,000 mi ) no leaks or loss of oil between changes. Compression is still up at 230 psi with variance less than 5 psi between cylinders.
    Highwaylizard likes this.
  10. #54
    Join Date
    Apr 2008
    Location
    Arlington, TX
    Posts
    110
    Liked
    0 times
    Rep Power
    8
    My old Landcruiser LX 450 had 250K on the dot. I trade it in for the Sequoia. I swear all I've did was the oil, filter and tires...Oh, one rear main seal, 500 bucks job.
    That is why I came back and got the Sequoia, I didn't want the LX 470 due to expensive self leveling suspension and the leather.
  11. #55
    Join Date
    Apr 2007
    Location
    Waynesboro, PA
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    I just turned 200,000 and getting ready to replace my timining belt again. Waited till 116,000 and it broke going 70 mph. It is an interference motor, but somehow no damage was done. The mechanic couldn't believe it. I'm definitely changing it this time.
    Tom
  12. #56
    Junior Member c350 Sr5's Avatar
    Join Date
    Jun 2003
    Location
    Edinburg, Texas
    Posts
    66
    Liked
    4 times
    Rep Power
    13
    my '03 is already around 92k with no problems other than the O2 sensors going out as usual.
    2003 White Tundra Sr5 v8
    -stock for now.
  13. #57
    Supporter 02TundraLTDTRD's Avatar
    Join Date
    Feb 2009
    Location
    Broomfield CO
    Posts
    533
    Liked
    0 times
    Images
    10
    Rep Power
    2857
    i have a 2002 Extended cab LTD 4X4 and i drive it like i stole it and i do maintenance on it like i still owe money on it and it I just turned to 135K miles and i am 100% satisfied with it.....
    2002 TOYOTA TUNDRA LTD – 265/75/17 Yokohama Geolander with 17” FJ Cruiser wheels – TRD Dual Cat back – JBA Shorty headers – K&N Dropin Filter – Dastek Unichip Q Series with Flux PDA and custom Dyno Tuned Map - Garmin Nuvi 1690 – Line X Bed Liner – TruXedo Lo Pro QT Soft Roll-Up Tonneau Cover - Luverne 3" mandrell bent Side Steps – Toyota OEM Brake Upgrade (TSB) - PowerSlot Cryo Rotors - Hawk LTS Pads -Smittybuilt Grill Saver - Hella 500 Spot Lights & Clear covers - Tint front side windows - Toyota "Tundra" door sill protectors - Hellwig Rear sway bar - Bilstein 2.5" lift front and Bilstein 1.25" lift Rear
    Audio upgrades - Alpine CDA-117 HU, Alpine PDX F4 (100w RMS x 4), Alpine PDX M6 (600w RMS x 1), Alpine RUX- KNOB, Boston S60's front, Boston SC65's Rear, Boston G310-44 Sub woofer, eKo Knu Power and Ground, 6 Channel Monster RCA's all round. (119.4 db)
    Future Modifications - Dynamat.
    SOLD
    Click here for something fun to watch! http://www.youtube.com/watch?v=PqXvQ8X4UJI
    2002 Ford Explorer XLT – BabyMobile (Wife’s car) (“,)
  14. #58
    Join Date
    Sep 2009
    Location
    AZ
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    mine died today with 210,000 I am very, very upset over it and am trying to figure out what to do. I loved that truck so much and thought I would easily get 250,000 out of it.
  15. #59
    Join Date
    Aug 2009
    Location
    Guam
    Posts
    59
    Liked
    0 times
    Rep Power
    7
    Get a used 5.7 and see if you can drop it in
  16. #60
    Join Date
    Aug 2014
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    I just bought a 2000 4WD 4.7 with 309000 miles and it runs great. I totaled a 2002 4.7 2wd last week with 90000 miles. Can I remove the engine from the 2002 (still runs) and put it in the 2000 4wd? The only difference I see is that the 2002 has IForce written on it.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. 06-27-2012, 06:07 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
