tightening new oil filter
+ Reply to Thread
Results 1 to 14 of 14
Thread: tightening new oil filter
  1. #1
    Junior Member punisher's Avatar
    Join Date
    Jan 2001
    Location
    Huntington Beach, Ca
    Age
    48
    Posts
    159
    Liked
    0 times
    Rep Power
    15
    Default tightening new oil filter
    Do most folks use an oil filter wrench to tighten their replacement filters or just tighten it as much as you can by hand? I have found I cant get the whole 3/4 turn as recommended by hand, but dont want to use a wrench
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2002
    Location
    Milford, MA
    Posts
    361
    Liked
    2 times
    Rep Power
    14
    I've found if I use my hands or a wrench the filter pretty much bottoms out and comes up against the mounting plate when fully tightened, knock on wood I've never had a leak. Just be sure to lubricate the gasket with new oil before installing.
  4. #3
    fly
    fly is offline
    Join Date
    Sep 2002
    Location
    Longview, TX
    Posts
    175
    Liked
    0 times
    Rep Power
    13
    If you are using a wrench to tighten your new filter, you are putting it on way to tight!
  5. #4
    Veteran Member george60's Avatar
    Join Date
    Mar 2003
    Location
    Northern California
    Age
    73
    Posts
    657
    Liked
    2 times
    Rep Power
    453
    SUGGEST
    I tighten the filter down by hand, Then I put the wrench on and go 1/4 more. Never had a problem.
    "... nevertheless, thou may chose for thyself ..."
    Mormon Doctrine
  6. #5
    Junior Member Wadingboy's Avatar
    Join Date
    Feb 2002
    Location
    Laytonville, Ca.
    Posts
    210
    Liked
    0 times
    Rep Power
    30
    'til I started following this board I used Fram filters, the ones with the black grip end. Don't need a wrench on or off. Why don't all the filter makers do this?
  7. #6
    Join Date
    Feb 2002
    Location
    Laytonville, Ca.
    Posts
    210
    Liked
    0 times
    Rep Power
    30
    On another note, when my daughter brought her new car home for help changing the oil I figured "no problem." Well, I think they put the filter on with an impact wrench because I had to drive a metal stake through the filter then use a 3' galvanized pipe as a handle to break the d**n thing loose. Needless to say it was THE messiest oil change ever.
  8. #7
    Join Date
    Feb 2002
    Location
    Silicon Valley, CA
    Posts
    1,802
    Liked
    2 times
    Rep Power
    15
    I'd get yourself a set of oil filter pliers. You might not need them for 5 or 10 years but since it might cost you $10 it' worth it to have around when you need it. "It's all in the tools".
    I prefer to buy tools when I have the chance knowing full well they'll "have their day" when I'm soooooo glad I bought them.
    I even went as far as to get a large vise grips that is capable of clamping around a full sized filter (or a mason jar cap) because I've been through this too. Plus a regular pliers like filter wrench.
    Sometims an end cap type wrench is handier too. Couple buck there too....
    Though the worse I've ever had is to drive a phillips screw driver through it to form a handle and twist with that.
    In almost all cases I would not *ever* advise tightening with a wrench. As long as it doesn't leak with the engine up to full temp, I don't worry about it and it will only seal tighter with time.
    alan
  9. #8
    fly
    fly is offline
    Join Date
    Sep 2002
    Location
    Longview, TX
    Posts
    175
    Liked
    0 times
    Rep Power
    13
    Originally posted by george60
    SUGGEST
    Why do you use a wrench? You should be able to make the quarter turn by hand.
  10. #9
    Join Date
    Mar 2003
    Location
    Northern California
    Age
    73
    Posts
    657
    Liked
    2 times
    Rep Power
    453
    Why Do I Use A Wrench?
    It's arthritis in my hands and the Tundra V8 oil filter is hard to get to.
    Mormon Doctrine
  11. #10
    Supporter SATundra's Avatar
    Join Date
    Mar 2001
    Location
    San Antonio, TX
    Age
    56
    Posts
    2,558
    Liked
    3 times
    Rep Power
    17
    Ditto.
    Spin it on until it touches, then turn until its tight (about 1/2 to 3/4 turn) BY HAND.
    SATundra
    2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
    MODS:
    TIRES:
    Michelin LTX M/S LT265/75/R16 load C rated
    SUSPENSION:
    front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
    INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
    EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
    ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
  12. #11
    fly
    fly is offline
    Join Date
    Sep 2002
    Location
    Longview, TX
    Posts
    175
    Liked
    0 times
    Rep Power
    13
    Well, those are good reasons.
    I guess you don't take off the skid-plate off, so a wrench makes it easier to turn the filter.
    If you do it that way, you can use an old serpentine belt to unscrew the filter from top side, after you break it loose with the wrench, of course. Just a tip.
  13. #12
    Veteran Member Dude Boy's Avatar
    Join Date
    Feb 2000
    Location
    Northern Oregon
    Age
    69
    Posts
    1,462
    Liked
    6 times
    Rep Power
    1078
    I have the same problem. I've found that wearing a rubber glove gives me enough extra grip that I can usually get 3/4 - 1 turn more after the gasket makes contact.
    ADDING POWER HAS NEVER BEEN SO FAST!
  14. #13
    Junior Member charlie's Avatar
    Join Date
    May 2002
    Location
    New Orleans, LA
    Age
    64
    Posts
    207
    Liked
    0 times
    Rep Power
    15
    Default Why no wrench?Older hands need an edge
    I have read the "don't use a filter wrench to tighten the oil filter" for 35 years,and I generally can get the 3/4-1 turn(after touching) by hand,but sometimes the wrench is more convenient,especially if the filter is slippery,or the space is limited.The smaller filters don't allow as good a grip,and the smaller diameter gives you less mechanical advantage-less torque.If you take it easy with the wrench it should be fine.Mark the filter into quarters so you can tell how much you have turned it after meeting resistance.Older hands need an edge.Charlie
  15. #14
    Join Date
    Feb 2002
    Location
    Silicon Valley, CA
    Posts
    1,802
    Liked
    2 times
    Rep Power
    15
    Default Re: Why no wrench?Older hands need an edge
    Personally, I don't really monitor how tight I have the filter by "turns". I get it spin on tight with oil on the filter gasket so it's pretty tight and then I'll "eyeball" the gasket squish as I tighten it up 1/2 turn. After that I just replicate it. Too, I think you can feel when it's properly tight by "feel". I guess it's really a combination of both for me.
    You can practice by doing a 3/4 turn backing off to 1/2 turn (you need oil on the gasket) and you'll see how thick the gasket needs to be. After that, I'll just tighten 1/2 turn (which is enough) right away either in 1 step or 2 or "whatever".
    If you're doing it for someone else (and you're not going to be the one to pull it off and you have to assume they are an idiot who won't guess that leaking oil means something), then I'd do the full 3/4 turn.
    Alan
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
