Badly need help with coolant change
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Badly need help with coolant change
  1. #1
    Junior Member dboy4ever's Avatar
    Join Date
    Oct 2000
    Location
    Cupertino, CA
    Posts
    143
    Liked
    1 times
    Rep Power
    15
    Default Badly need help with coolant change
    I changed the coolant on my V6 Tundra today. Did everything according to the manual and the instructions on Maintainence Bay. Anyway, I drained the coolant (did both drain plugs on the V6), reinstalled the plugs, poured in new coolant, closed radiator and resevior cap...
    When I bled the cooling system, however, the temperatur gauge soon went above the old usual temperature, and even though I had the knob turned all the way to heat, the air coming out of the AC vents are just cold. I shut the engine because I didn't want it to overheat due to some stupid mistake I might have made. I double checked the instructions and am 100% sure I did everything accordingly. What could have gone wrong? Thanks very much.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Oct 2000
    Location
    Cupertino, CA
    Posts
    143
    Liked
    1 times
    Rep Power
    15
    Thread Starter
    Another thing... I could only manage to pour in maybe 5 or 6 liters of coolant before the radiator filled up, whereas the manual says the capacity is 10... Now where are the hidden 5 liters that I didn't drain?
  4. #3
    Supporter Genthar's Avatar
    Join Date
    Jun 2002
    Location
    Escondido, CA
    Posts
    995
    Liked
    1 times
    Rep Power
    15
    Just some guesses:
    Capacity: Probably includes what's in the block and heater lines. So just draining the radiator won't get you all the way to capacity.
    Overheating: Possible bad thermostat. Incorrect coolant mix. Air in the thermostat.
    Hope you figure it out!
    Genthar
    Teamwest Coilovers, Camburg Upper A arms, Daystar Steering Rack Bushings, Total Chaos Diff Drop spacer, JBA Headers, Y-Pipe, and EVOL exhaust, Dynabead balancing media.
  5. #4
    Join Date
    Oct 2000
    Location
    Cupertino, CA
    Posts
    143
    Liked
    1 times
    Rep Power
    15
    Thread Starter
    Thanks for the quick reply Genthar.
    I did drain the engine block. That drain plug was a b*tch to get to but I managed to eventually.
    As to the coolant mix, I bought the pre-mixed kind, 50% antifreeze and 50% water.
    If it's a bad thermostat, it would have broken down during my coolant change because I had NO problems prior to the coolant change.
  6. #5
    Supporter SATundra's Avatar
    Join Date
    Mar 2001
    Location
    San Antonio, TX
    Age
    55
    Posts
    2,558
    Liked
    3 times
    Rep Power
    16
    Did you check the fluid level AFTER it got hot? Im suspecting you took out 10 but only added 5-6 when you refilled. You have to start the truck, let it warm up until the thermostat opens, THEN finish adding the remaining fluid to it to total 10. Also dont forget to turn ON (turn temp knob to hot) the heater, this will allow water to flow through the heater core and get out the remaining air. Sounds like you only filled up the radiator and part of the block, maybe your missing fluid should be in the heater core.
    Just something to check.
    SATundra
    2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
    MODS:
    TIRES:
    Michelin LTX M/S LT265/75/R16 load C rated
    SUSPENSION:
    front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
    INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
    EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
    ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
  7. #6
    Join Date
    Oct 2000
    Location
    Cupertino, CA
    Posts
    143
    Liked
    1 times
    Rep Power
    15
    Thread Starter
    Good guess SATundra.
    After I wrote the initial post, I went back outside to my Tundra to find out that the radiator was sucking coolant from the resevior. I filled up the resevior, started the truck again, and again it was approaching the red line on the temp gauge. (Yes I did turn on the heater).
    So I turned off the engine, waited for it to cool down, and again coolant was being sucked out of the resevior, and so I filled up the resevior...... I repeated this whole process for about 4 or 5 times when Hallelujah! warm air began coming out from AC and the temp gauge stayed right in the middle. After all that, I had put in a good 8~9 liters of coolant. Problem gone. Yet another reminder not to expect life as we expect it to be.
    Thanks again, Genthar and SATundra for your insights.
  8. #7
    Leader of Group Evil DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    11,128
    Liked
    728 times
    Images
    22
    Rep Power
    12366
    stupid question from the peanut gallery...
    who, specifically, takes old coolant? (please dont tell me to find a gopher hole...heard that one )
    -sean
    GFX by FreedomEagle50
    1-Gen Tundra Offroad Technical FAQ Index
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  9. #8
    Veteran Member 5 Speed's Avatar
    Join Date
    Feb 2002
    Location
    Santa Barbara, CA
    Posts
    961
    Liked
    120 times
    Images
    19
    Rep Power
    5201
    The block heater bolt is easy to get at if you gather as many socket extensions together (2 feet or more) and access the bolt from the tire well. One thing that is easy to do and makes life easier down the road is remove the overflow tank and clean out the inside so it is spotless. I have a older Toyota that I purchased used and the overflow plastic was so dirty it was almost impossible to see the level without opening up the fill cap. I believe my V-6 Tundra is only held in place with 1 bolt.
  10. #9
    KLS
    KLS is offline
    Supercharged Member KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,492
    Liked
    4 times
    Rep Power
    16
    -sean
    "Recycle/Disposal Options
    Antifreeze should not be disposed of by throwing it in the trash, pouring it down the storm sewer, or putting it into septic systems. Many storm sewers discharge directly to surface waters, such as ponds or streams. Degradation of the antifreeze consumes the oxygen in the water, effectively smothering plant and animal life in the pond or stream and causes a foul odor. Poured into a septic system, the antifreeze may damage the
    system by killing the microorganisms necessary for decomposition.
    Acceptable methods of managing used antifreeze include recycling, disposal at a hazardous waste treatment, storage, or disposal facility (TSDF), or discharge to a wastewater treatment plant with prior written approval of the Publicly Owned Treatment Works (POTW). Most wastewater treatment plants discourage sewering of used antifreeze, and many no longer allow discharges of antifreeze to their systems at all. Recycling used antifreeze is the preferred option."
    http://www.cdphe.state.co.us/hm/antifreeze.pdf
    Call your local recycling center or public hazardous waste disposal center. Or ask a repair shop if you can add it to their waste antifreeze.
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
  11. #10
    KLS
    KLS is offline
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,492
    Liked
    4 times
    Rep Power
    16
    dboy4ever,
    I prefer to use full-strength antifreeze. I look up the cooling system capacity and add the correct amount of antifreeze for the proportion I want...40% in moderate climates, 50% for normal freezing winters, 60% for -30F and below. I then top off with distilled water. I've never gotten a system to drain completely. As you found, getting all the air bled out can be a chore. I flush the cooling system every two years, and change the thermostat maybe every four years...'stats wear out, and they're cheap.
    Ken
  12. #11
    Join Date
    Mar 2001
    Location
    San Antonio, TX
    Age
    55
    Posts
    2,558
    Liked
    3 times
    Rep Power
    16
    -sean
    Cant say for certain, but I would "assume" Pep Boys would.
    BTW we dont have gopher holes in this part of Texas but we do have Armadillo holes. All im gonna say is I keep mine in the garage.
    SATundra
    MODS:
    TIRES:
    SUSPENSION:
  13. #12
    Join Date
    Oct 2000
    Location
    Cupertino, CA
    Posts
    143
    Liked
    1 times
    Rep Power
    15
    Thread Starter
    Stealth, go to this website and then click "antifreeze" in the Auto category.
    http://www.earth911.org/master.asp?s...t=1&serviceid=
    KLS, I know I should mix them myself, but I have a good excuse: I was too lazy.
    An interesting side story. When I was doing the coolant change yesterday, a neighbor who works at a nearby Toyota dealership (whose identity will not be revealed) came over. I started complaining about the engine block drain, and the guy said what, there's only 1 drain plug, and that's on the radiator. So I showed him the service manual, and he was like okay but draining the radiator would be enough because that's all we do at the shop. I said then why do they put another drain plug on the engine, because draining the radiator is not a complete job.
    Finally the guy was convinced. I showed him how hard the engine drain is to get to, and he said okay maybe that's why we skip it. Yeah, and that's why I prefer to do it myself.
    That got me thinking... just how many things do they skip at the dealership in other maintainence procedures? My guess is don't rely on your fingers when counting them. This is where DIYing really pays off.
  14. #13
    Junior Member Crazychopstick's Avatar
    Join Date
    Nov 2003
    Location
    San Angelo, TX
    Age
    30
    Posts
    135
    Liked
    0 times
    Rep Power
    12
    Quote Originally Posted by dboy4ever
    How do you "Bleed" your coolant system?
  15. #14
    Join Date
    Oct 2000
    Location
    Cupertino, CA
    Posts
    143
    Liked
    1 times
    Rep Power
    15
    Thread Starter
    Quote Originally Posted by Crazychopstick
    Good question. As far as I can remember, "bleeding" the coolant simply means the following.
    Once you've filled up with new coolant, turning on the engine. Turn the A/C on, the temperature knob (the blue/red one) all the way to maximum heat, and the fan control to highest wind.
    You may notice the air coming out is not hot at all. But keep the engine and A/C running until hot air comes out. In the meantime, check the coolant resevoir level periodically and fill up if necessary. Stop when hot air comes out of the A/C.
  16. #15
    Junior Member toyotafreak's Avatar
    Join Date
    Nov 2003
    Location
    Corona, CA
    Posts
    98
    Liked
    0 times
    Rep Power
    12
    Default Just did the Sequoia @ 30K
    So here's what Chiltons told me to do (when the rubber met the road, I couldn't stand to spend $200 on OEM manuals ;-(
    The drain thing - OEM coolant is ethylene glycol and bad for the environment. Got to collect all that stuff, not just flush it out. So, we drain the radiator into a bucket. Then we drain the block (two valves on the 2UZ) into another bucket. Close all the drains.
    The flush thing - Once the system is drained, pull the thermostat housing off, pull the thermostat out, and reinstall the thermostat housing without the thermostat. Disconnect the hose going from there to the top of the radiator at the radiator. Stuff a garden hose into the radiator in the hole opened by removing the input hose. Install radiator cap. Turn hose on, turn engine on, turn heater on hot, turn fan on full. Return to engine bay to find water being exhausted from the thermostat hose onto the fan, which is slung ALL over. Wait until the water runs really clear. Secure engine and water. DRAIN the radiator and block again. Reinstall the thermostat and reconnect the radiator hose. Remove the resevoir to flush and empty. Note: after looking at the book again, you might not need to run the engine during this step, which would keep you from spraying water all over the place).
    The fill thing - After you make sure all drain plugs are secure, SLOWLY start filling your radiator through the cap until it's full. Put cap on. Partially fill the resevoir. Run engine with heater/fan on hot. Feel that radiator input hose you had removed and reinstalled; once it gets hot, your thermostat's opened. Turn the engine off and let it cool long enough to be safe to open the radiator. SLOWLY refill the radiator, and squeeze the input line to move bubbles from the line into the radiator. Add more coolant if necessary. Finish filling the resevoir up to the FULL line. Inspect for leaks.
    The follow-up - after a couple days, you'll want to come back and check/fill the resevoir level; mine dropped a few inches.
    Here's the coolant deal: if you didn't use the Toyota poison coolant, and used some of the clean stuff, you wouldn't have to drain. I'm pretty sure you could just pull the thermostat and do the flush thing step to both empty and flush. Still have to get under there to drain the tap water after flushing, but it'd save you from doing it twice. I for one have had so many coolant system failures in my life that with the Sequoia, I take no chances. OEM stuff right at 30K (18 months).
    2003 TOYOTA Sequoia SR5: 89K, TRD cat-back, fueled by Chevron; M1 oil/filter
    2000 TOYOTA Epic S22: Powered by Lexus 1UZ w/VVTi, Chevron/M1
    1995 TOYOTA Hilux: 206K, any gas, any filter, first 100K Castrol Syntec, GTX since
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
