Fuel Cells
+ Reply to Thread
Results 1 to 7 of 7
Thread: Fuel Cells
  1. #1
    Join Date
    Oct 2003
    Location
    Anaheim
    Age
    40
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Default Fuel Cells
    Anyone installed a fuel cell in their Tundra? Whose fuel pump did you use and what fuel pressure must it be regulated at? I'm looking at getting a 35-gallon Fuel Safe cell and need to also know if there's a sending unit that will adapt to the factory fuel level gauge. thanks in advance.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Joe
    Joe is offline
    Veteran Member Joe's Avatar
    Join Date
    Feb 2002
    Location
    South of Winnipeg
    Posts
    544
    Liked
    3 times
    Rep Power
    14
    I'm having one installed and I'm going with an electric fuel pump and they were able to match up a sending unit so my gauge will still be accurate. When I get the particulars I'll post them.
  4. #3
    Join Date
    Jul 2003
    Location
    Southeast
    Posts
    860
    Liked
    0 times
    Rep Power
    13
    Im not exactly sure of the purposes of a fuel cell, but if I was gonna get another tank, or a different tank, Id get one about 100 gallons. That way I only have to fill up once every 3 months! Oh and Id just blown up in an accident too i suppose.
  5. #4
    Joe
    Joe is offline
    Join Date
    Feb 2002
    Location
    South of Winnipeg
    Posts
    544
    Liked
    3 times
    Rep Power
    14
    Quote Originally Posted by file014
    Fuel cells have several purposes - on specialty rock crawling rigs they run 8 to 10 gallon cells to cut down on weight, some off-road rigs want the weight on the passenger side to help off-set the driver's fat arce for better weight distribution, long range off-road rigs want a little larger tank so they don't have to carry so many 6-gallon gas cans and also don't want to worry about punching a hole in the tank (this refers to a bed mounted fuel cell) and some just want extended range while traveling cross-country. 35 to 40 gallons is normally as large as you want to go. With a 4-link rear I had to replace my tank and I requested a custom built tank (several baffles) in the area of 40 gallons +/- with the sending unit situated in the rear/middle of the tank so when I'm mainly climbing and running with minimum fuel, I might run dry on a steep downward incline but I won't run out of fuel while attempting a steep climb.
    700+ pounds of fuel is a bunch so you'll have to beef that Tundra up a little to carry it around.
  6. #5
    Join Date
    Oct 2003
    Location
    Anaheim
    Age
    40
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by Joe
    Joe- have you got any pics of your 4-link setup? Do you know whose fuel pump and regulator you have for the fuel cell? i need to know what fuel pressure to run and what sending unit. thanks!
  7. #6
    Joe
    Joe is offline
    Join Date
    Feb 2002
    Location
    South of Winnipeg
    Posts
    544
    Liked
    3 times
    Rep Power
    14
    I don't have any pictures yet as the 4-link will be installed early next week. I pick my vehicle up a week from today. I'll have all the info and some pictures, which I'll post no later than the 15th.
  8. #7
    Join Date
    Oct 2003
    Location
    Anaheim
    Age
    40
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    whose building and installing the 4-link and what did you do for front suspension?
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
