Puff of Blue Smoke on Startup
+ Reply to Thread
Results 1 to 11 of 11
Thread: Puff of Blue Smoke on Startup
  1. #1
    Join Date
    Jun 2002
    Location
    Hopkinton, NH
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Default Puff of Blue Smoke on Startup
    If the truck has been sitting for awhile, overnight say, 90% of the time I get a puff of blue smoke out the pipes on startup and then it's gone. It will not do it again that day. It does not consume any oil. It's the 4.7. Anyone else experience this?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2002
    Location
    West Allis, Wisconsin
    Age
    71
    Posts
    154
    Liked
    17 times
    Rep Power
    176
    I park my truck in a garage and, I suppose depending on which way the wind is blowing, I'll sometimes get a small cloud of blue smoke in the garage. The day after I got back from vacation towing my boat, about 1200 lb, I went to back the truck out of the garage to wash it and the cloud of blue was really noticeable. Although it's annoying, I don't think this is anything to worry about and is just characteristic of the engine and even may be designed that way for lubrication purposes.
    As to using oil. My vacation trip totaled 1500 hard miles towing the boat and the truck used just enough oil to see a change on the dipstick. Maybe 1 or 2 ounces, which I find perfectly acceptable.
  4. #3
    Join Date
    Feb 2002
    Location
    Stuart, FL
    Posts
    92
    Liked
    0 times
    Rep Power
    14
    Quote Originally Posted by truck'n
    My 2000 did this and there were several other posts way back about it. I called the Toyota rep and he said nothing to worry bout. Mine had the wrong dipstick so it was overfilled for awhile, but I think some else mentioned that the circumstances of humidity ,temp and emmissions systems puts to much oil in intake manifold and on short trips it does not get a chance to burn out & upon start up it puffs a little.. Mine did it for awhile when new and now will not do it at all. Guess I drive it a little harder now..
  5. #4
    Junior Member slow camry's Avatar
    Join Date
    Jul 2003
    Location
    Katy/College Station, TX
    Age
    29
    Posts
    322
    Liked
    0 times
    Rep Power
    12
    may be the valve seals?
    2003 Natural White Access Cab SR5 V8
    15.8 @ 85.1 stock
  6. #5
    Junior Member puppychop3's Avatar
    Join Date
    Sep 2002
    Location
    Sunland, ca
    Posts
    138
    Liked
    0 times
    Rep Power
    13
    My Supra did the same thing for years. Took it to the Toyota shop and they thought it was the valve seals. Never fixed it, drove the car to 230K miles.
  7. #6
    DJJ
    DJJ is offline
    Join Date
    Feb 2002
    Location
    Denver, Colorado
    Age
    41
    Posts
    151
    Liked
    0 times
    Rep Power
    14
    My 2000 did this too off and on for about two years. Recently I just started paying more attention to it. About a month ago I took it to the dealer and they said they overfilled the oil on an oil change the week before. They corrected the level but it still smoked. My advisor said it should not do that at all. So, they replaced the 32 valve seals under warranty and no problem since. He said that was the tech's first V8 he's done that to. I saw the invoice and the bill came to $1188. I've done research here and found others to have the same issue. At first I mentioned the valve seal idea to my advisor but they have to eliminate cheaper possibilities first.
    -DJJ
  8. #7
    Junior Member TampaBayTundra's Avatar
    Join Date
    Feb 2002
    Location
    Port Richey FL
    Age
    46
    Posts
    158
    Liked
    0 times
    Rep Power
    14
    In my Camaro when the carb was set too rich. Blue smoke is usually unburned fuel (or oil leaking thru valves however it would not just be at startup). Maybe your ECU is setting your A/F mixture a little rich during start up?
  9. #8
    Veteran Member Brian M's Avatar
    Join Date
    Dec 2002
    Location
    Galveston, Texas
    Age
    46
    Posts
    919
    Liked
    2 times
    Rep Power
    13
    The 1988-1991 GM V8's were notorious for this. Most attributed it to some type of drainback after sitting for a long period. Even still, I knew alot of guys that ran these trucks well past 150k miles with no related problems and no real oil consumption.
    BTW...I have never noticed this on any of my Toyota's.
    2011 Ford F150 Lariat 4x4 5.0L
    2013 Avalon Limited
  10. #9
    Join Date
    Feb 2002
    Location
    Mesa, AZ
    Age
    67
    Posts
    239
    Liked
    0 times
    Rep Power
    14
    My wifes Camry does this. It is probably the valve guide seals. Toyota fixed replaced the seals under warranty and the problem went away. However it has now returned. There must be something internal that is causing the seals to go out. It does not use oil, and only smokes when it has been sitting for a long time. My wifes Camry is the 4 cylinder - (I won't do that again) but it makes a nice city car.
  11. #10
    Rookie slickwillis777's Avatar
    Join Date
    Apr 2003
    Location
    Truckee
    Age
    35
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default puff of blue smoke
    Yeah, my truck does that to.
  12. #11
    Leader of Group Evil DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    11,128
    Liked
    728 times
    Images
    22
    Rep Power
    12366
    something i remember from a while back that may be useful:
    the pcv valve vents to the throttle body, just before the plate. one or two people put a small reservoir in the line between the block and the tb on the pcv line, they said it did catch a little fluid. maybe that has something to do with it?
    GFX by FreedomEagle50
    1-Gen Tundra Offroad Technical FAQ Index
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
