engine knock when cold start
+ Reply to Thread
Results 1 to 6 of 6
Thread: engine knock when cold start
  1. #1
    Join Date
    Jul 2010
    Location
    Clover SC
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default engine knock when cold start
    hey guys,
    I have a 2005 tundra limited 4 door, 4.7 v-8, 158,000 miles, when i start up the engine has a loud knock 7-8 times, then it stops, only happens 3 or 4 times in a weeks period (only when the engine is cold). i thought about a spark knock, changed gas types still happens, i used fram oil filters, wal-mart high milage oil. cleaned throttle body, replaced timing belt/water pump, service transmission over the summer, was doing the knocking before i did all of this, oil pressure seems to be good.
    any ideas?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Dec 2012
    Location
    usa
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default Re: engine knock when cold start
    I have a 2004 tundra that has been having this same noise, and I can't seem to figure it out.
  4. #3
    Junior Member macmcalexander's Avatar
    Join Date
    Dec 2011
    Location
    Southern Indiana
    Posts
    99
    Liked
    19 times
    Images
    2
    Rep Power
    174
    My step-brother's 2005 doublecab, with 140,000 on the odo, also does this horrible knock at start up during the winter months. If he just jumps in it, starts up and just drives off in cold weather, it sounds like the engine is about to lock up. It is that bad. If he starts it and lets it warm before leaving to go anywhere, it sounded normal. Like all sweet 4.7L. He bought some kind of additive (Russian name) added it to his oil change, and so far it has made the cold weather start up knock stay quiet. He had tried our favorite additive, Lucas oil, to the previous oil change and it did not help at all. We have had great luck with that stuff in our old GM's junk and any engine that had leaky valve seals. He was thinking about trading it in but he is not into the new Tundra's, so he was thinking another brand. After he gets back home from Christmas away, I will post what the additive was. I thought, no-way would I have used it in my Tundra. But when it worked in his truck, well, it made me think that if mine sounded as bad as his, maybe I would. His 4.7L sounds like a sewing machine again.
  5. #4
    Veteran Member Tones's Avatar
    Join Date
    Dec 2005
    Location
    Houston, TX
    Posts
    568
    Liked
    7 times
    Rep Power
    23
    If what you're hearing is piston slap, it is pretty normal for this range of model years. I haven't had this problem on my '01. Perhaps it just doesn't get cold enough here.
  6. #5
    Join Date
    Jan 2013
    Location
    San Diego
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Make sure you use 5-30 winter time (60 deg. F and under) 10-30 summer time (60 deg. F and up).
    Its normal for it to knock first cold start of the day 45 F or colder and let it worm up before you go maybe till the temp gauge start to rise
    above the first line.
    Don't use high mileage oil it designed for vehicles that leak oil so its thicker you drive a tundra 160,000 mile you are still braking in the engine
    and the best oil filter you can use is a Toyota filter go to the dealer and buy a case 10 or 12 then write the mileage on each box that you want to change at 155,000 160,000 165,000,170,000 etc......
    Driving down the street when its cold and your oil is like molasses and your doing 2000 + RPM's is not good on your engine.
    don't be in such a rat race
  7. #6
    Supporter kerryman71's Avatar
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    44
    Posts
    2,696
    Liked
    804 times
    Images
    27
    Rep Power
    230367
    As was mentioned, it sounds like piston slap. It's pretty common in a lot of vehicles, particularly ours. I run Mobil 1 0W30 year round. The "knock" is more pronounced in the colder weather (it can get into the single digits here), but it isn't anything horrific. Try going with synthetic if you aren't already. If you're comfortable try the 0W30 but if not go with 5W30 and see if that makes a difference.
    John
    The fools, the fools the fools! They have left us
    our Fenian dead, and while Ireland holds these
    graves, Ireland unfree shall never be at peace!
    Padraig Mac Piarais (Patrick Pearse)
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
