4.7l Engine Oil Capacity? - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: 4.7l Engine Oil Capacity?
  1. #16
    Join Date
    Dec 2004
    Location
    Rindge, NH
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Angry Oil!
    Quote Originally Posted by tundrabrad
    The dipstick seems to be a bit short for accurate measurement. I have the identical issue with my '03 V8.
    I just fill it up with all 7 quarts of Mobil 1 5W-30 SuperSyn!
    Brad
    I do the same with 6 quarts and it appears to be full - go figure!
    8 cylinder, etc.
    Folks the problem is the dipstick!!! The guide tube holds oil in its wall using surface tension, the stick dragging against the walls of the tube pulls oil onto the dipstick and here lies the problem.
    I've been fighting this for four years on four different Tundras.
    My guess is it should take 6+- quarts, however, I've seen it look like full with five quarts.
    TOYOTA - FIX THIS!!!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #17
    Supporter Rlockyer's Avatar
    Join Date
    Nov 2002
    Location
    CA
    Posts
    1,593
    Liked
    0 times
    Rep Power
    14
    Quote Originally Posted by osmosis
    Ditto.
    I can't get a solid reading if I follow SOP and slowly remove, wipe, replace, and remove. It's all over the place. If I look carefully, there's a place on the stick where it's definitely solid, all the way across, then a fine line up one side or the other.
    If I remove, wipe, then STAB the stick in and out quickly, I get a much more repeatable level. There's still some oil above the solid point, but it's much clearer. Also, be sure to check the front AND back of the stick... hint... the low side is the right one.
    6.5 qts with the stock filter, 7 qts with the ML301 (large can).
    2008 Tacoma 2.7 RC Base
    2003 SR5 TRD V8 <<< Sold 2005
    Better Built toolbox / Limited leather / Power outlet mod / RS3200 Plus / Rebadged w/TRD / Bully Nerf bars / '05 OEM Taillights / Clear corners / Factory Woodgrain kit / Gentex EC Mirror / Gaylord's Toolbox-Lid / MB Overdrives / Muthco Signal Mirrors / Sport Grille / TRD Dual Exhaust / Camry Nav System
  4. #18
    Join Date
    Mar 2008
    Location
    Minneapolis
    Posts
    36
    Liked
    0 times
    Rep Power
    7
    Default Re: 4.7l Engine Oil Capacity?
    wow, first v8 I've had and now I need to go get another 2 qts :-)
  5. #19
    Supporter 2XOverhead's Avatar
    Join Date
    Jun 2007
    Location
    Los Angeles
    Posts
    1,038
    Liked
    4 times
    Rep Power
    1233
    Quote Originally Posted by snowdogg View Post
    I'd buy 5 qt. jugs at a time. Use 1 and 2/5 jugs each change and save the other 3/5 for next time. You can pour the extra 1/5 into a qt. bottle and keep it in the truck just in case.
    Nice four year .
    MODS: Oversized Drain Plug.
    DIY: ATF Flush, w/ Pics.
    DIY: Coolant Flush, w/ Pics.
    Coming Soon?
  6. #20
    Join Date
    Aug 2009
    Location
    Los Angeles
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    This is a very good post on how to determine engine oil level. I tried it already and it worked. Thanks for this post.
  7. #21
    Supporter KDTundra's Avatar
    Join Date
    Feb 2002
    Location
    Fulton, Missouri
    Posts
    162
    Liked
    1 times
    Images
    10
    Rep Power
    14
    Strange....I have used Mobil 1 5w30 and a Mobil 1 M-102 oil filter since new on my 2001 Tundra EC. It has 110,000 and still running strong without any oil loss issues. Since turning 100,000 miles, I started changing every 5000 miles and consistently have used 6.5 to reach the "full" mark on the dipstick.
    Kevin
    2012 Tundra Double Cab, 4X4, SR-5 Package, TRD Off Road Pkg., 5.7 L FFV, Nautical Blue Metallic; Flowmaster Cat Back Exhaust System #817486; Line-X bedliner application; ARE "Z" series Camper Shell, Husky Floor Liners, Auto Vent Shades, TRD Cold Air Induction system, TRD Anti-sway bar.
    2011 Rav4 4WD, Pacific Blue Metallic, 2.5 L, Husky Floor Liners, Auto Vent Shades.
  8. #22
    Join Date
    Nov 2012
    Location
    Jacksonville
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    I have trouble reading my 2001 4.7 dipstick. The problem is one side will read in between the F dot and the Add dot, but the other side has oil way above the dots! I;m talking about 4 or 5 inches above. I hate it because I let everything drain out and put in 6.5 quarts like the book says and i dont know if it is needing another quarter or half a quart or I have put way too much in. So now I just put 6.5 quarts in and leave it. I don't trust my dip stick and I dont dare trust anyone to change the oil for me because they might read the high side of the dipstick and not put but 4 or 5 quarts. Do I have the wrong dipstick? Anyone else have this problem?
  9. #23
    Join Date
    Nov 2012
    Location
    Jacksonville
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Wow! I like those racks you got in the back of your Tundra, is that an '01? Did you do it yourself?
  10. #24
    Join Date
    Nov 2012
    Location
    Jacksonville
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thanks! I will try that!
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
