4.7l Engine Oil Capacity?
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: 4.7l Engine Oil Capacity?
  1. #1
    Join Date
    Nov 2003
    Location
    dubuque
    Posts
    30
    Liked
    0 times
    Rep Power
    12
    Default 4.7l Engine Oil Capacity?
    Just changed the oil for the first time in my Tundra DC and the manual says 6.5 qt. But that gets the oil level only in the middle of the full and add marks on the dip stick. (I let the truck sit all night) so I put another 1/2 qt. in. Now it looks ok. Is this normal?
    Thanks PW
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    KLS
    KLS is offline
    Supercharged Member KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,492
    Liked
    4 times
    Rep Power
    17
    I get the same results in my '01 Tundra, so I just dump in 7 quarts.
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
  4. #3
    Supporter LGL002's Avatar
    Join Date
    Jan 2003
    Location
    Plymouth, MN
    Age
    74
    Posts
    2,231
    Liked
    14 times
    Images
    17
    Rep Power
    1319
    Wonder why unless it's filter size. Mine's always topped off at 6.5 using the Pure One filter.
    2003 Camry SE V6 Navigation, Sirius, Lunar Mist
    Optima 34R battery
    Turn signals are meant to indicate intent not result.
  5. #4
    Junior Member dgg2002's Avatar
    Join Date
    Jan 2003
    Location
    Palm Harbor, FL
    Age
    56
    Posts
    132
    Liked
    1 times
    Rep Power
    13
    Quote Originally Posted by lgl002
    Mine takes 7 qts with the Pure One filter... Go figure.
  6. #5
    Join Date
    Nov 2003
    Location
    dubuque
    Posts
    30
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    I'am useing the filter the dealer gave me.
  7. #6
    Supporter RoundTuit's Avatar
    Join Date
    Sep 2003
    Location
    Columbia, MD
    Age
    71
    Posts
    263
    Liked
    0 times
    Rep Power
    12
    My first oil/filter change took 7 qts. and I am using the small stock filter.
  8. #7
    ΜΟΛΩΝ ΛΑΒΕ imjin's Avatar
    Join Date
    Oct 2003
    Location
    California
    Age
    46
    Posts
    1,613
    Liked
    2 times
    Images
    66
    Rep Power
    169
    Quote Originally Posted by KLS
    Ken
    Ditto. 7 qts. tops off my 01 quite nicely too.
  9. #8
    Supporter tundrabrad's Avatar
    Join Date
    Oct 2003
    Location
    Menifee CA
    Age
    52
    Posts
    588
    Liked
    0 times
    Rep Power
    12
    The dipstick seems to be a bit short for accurate measurement. I have the identical issue with my '03 V8.
    I just fill it up with all 7 quarts of Mobil 1 5W-30 SuperSyn!
    Brad
    ________________________
    Tundrabrad
    Menifee CA
    2003 Tundra SR5 Access Cab 4X2 - Stratosphere Mica
    Factory Options/Accessories:
    Limited Slip Differential * RS3200 Security System * Towing Package * 17" Limited 5 Spoke Alloy Wheels * All Weather Floor Mats * First Aid Kit * Cargo Net * Wheel Locks * Aluminum Skid Plate * Auto Dimming Mirror * Fog Lights * Bed Extender
    Mods/Additions:
    Sylvania SilverStars * RhinoLiner * OBX Fire Extinguisher * Westin Signature Nerf Bars * Bullring Retractable Tiedowns * Snuglid Tonneau Cover * Coleman 400 watt Power Inverter * Magnafine transmission filter * Hellwig Anti-Sway Bar * SuperPlug
  10. #9
    Supporter Rlockyer's Avatar
    Join Date
    Nov 2002
    Location
    CA
    Posts
    1,593
    Liked
    0 times
    Rep Power
    14
    My '03 tops the dipstick with 7qts using the ML-301 (large) filter. 6.5 qts using the ML-102 (small) filter.
    70k now and it's never burned a drop.
    2008 Tacoma 2.7 RC Base
    2003 SR5 TRD V8 <<< Sold 2005
    Better Built toolbox / Limited leather / Power outlet mod / RS3200 Plus / Rebadged w/TRD / Bully Nerf bars / '05 OEM Taillights / Clear corners / Factory Woodgrain kit / Gentex EC Mirror / Gaylord's Toolbox-Lid / MB Overdrives / Muthco Signal Mirrors / Sport Grille / TRD Dual Exhaust / Camry Nav System
  11. #10
    Join Date
    Apr 2004
    Location
    Ontario, CA
    Posts
    42
    Liked
    0 times
    Rep Power
    11
    Also keep in mind that its better to keep your level 1/2 quart short than over. They may be telling you this to keep you from mistakenly over filling pan. It won't hurt to keep your oil level half way between the two marks on your dip stick.
    White 04 D-Cab Limited. DVD, moonroof, TRD, leather, heated seats, tow package, bed extender, overhead temp/comp, 20" crome Boss wheels, 275/55 Goodyear Eagles, Navigation.
  12. #11
    Join Date
    Jan 2003
    Location
    pearl river, la
    Age
    78
    Posts
    55
    Liked
    0 times
    Rep Power
    13
    Talking
    It takes every ounce of 7 quarts to reach the full mark on my 2002 dip stick, which is the exact location when I drove my truck home the day I bought it new and checked the oil. I used to buy my oil from the local Toyota dealer along with their filter. The parts dept manager told me it would take 7 full quarts with the Toyota filter. His previous job at the dealership before becoming the parts dept manager was changing oil in their vehicles. Last oil change I switched to Mobil 1 10-30, and guess what, it took exactly 7 quarts with a Toyota Filter to reach the full mark.
  13. #12
    Join Date
    Jan 2003
    Location
    Los Angeles
    Posts
    16
    Liked
    0 times
    Rep Power
    0
    This just happened to me this weekend. I changed the oil on my 04 Tundra (1st time) just as i've done with our Sequoia. However, to my surprise, it took 7 qts to fill the Tundra instead of the 6 1/2 qts to fill the Seq. What the heck... Is the oil pan on the Tundra larger? Or what?
    DV
  14. #13
    Junior Member fooddude's Avatar
    Join Date
    Apr 2004
    Location
    Orange County, CA
    Posts
    263
    Liked
    0 times
    Rep Power
    11
    Quote Originally Posted by Rlockyer
    My '03 tops the dipstick with 7qts using the ML-301 (large) filter. 6.5 qts using the ML-102 (small) filter.70k now and it's never burned a drop.
    Are these the Toyota OEM filter part numbers?? Both work on the Tundra v8? What cars are each of them really for?
    Get down, Do you?
  15. #14
    Join Date
    Nov 2002
    Location
    CA
    Posts
    1,593
    Liked
    0 times
    Rep Power
    14
    Quote Originally Posted by fooddude
    Those are the Mobil-1 filter numbers.
    The M1-102 is the one shown in the reference for the 4.7, and is the small filter. The M1-301 is the large 1-qt filter that crosses from the FL1A.
    M1-103 is the TEENY filter used on the Echo/Highlander/Rav4/Corolla four-bangers.
  16. #15
    Veteran Member mitchr's Avatar
    Join Date
    Feb 2002
    Location
    Kingsport, TN
    Posts
    639
    Liked
    1 times
    Rep Power
    14
    6.5 qts on my 2000(with Toy filter or Pure One), it took 7.5 qts when I had the wrong dipstick that came with the first Tundra's. Unless they changed the oil pain capacity I don't think you could get 1/2 qt difference with a different oil filter, even the large filters some people use. There used to be some info on the correct length of the dipstick on the site before it crashed a while back.
    Mitch
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
