2002 Tundra - check engine light
+ Reply to Thread
Results 1 to 8 of 8
Thread: 2002 Tundra - check engine light
  1. #1
    Join Date
    Aug 2003
    Location
    Memphis
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default 2002 Tundra - check engine light
    I've got a friend with a '02 Tundra v6 automatic, 4x2 that the check engine light came on recently. The code is P0770, which is "Shift Solenoid E Malfunction". Can anybody tell me what that translates to specifically for the Tundra? The truck seems run and shift just fine.
    Any advice would be appreciated.
    thanks, Todd.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Assistant Administrator nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    20 times
    Rep Power
    1673
    Transmission DTC
    Lock–up does not occur when driving in the lock–up range
    (normal driving at 80 km/h [50 mph]), or lock–up remains ON
    in the lock–up OFF range.
    (2–trip detection logic)
    Check shift solenoid valve SL operation.
    NG - Replace solenoid valve SL.
    OK - Check valve body
    NG - Repair or replace valve body.
    OK - Replace torque converter clutch
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  4. #3
    Join Date
    Aug 2003
    Location
    Memphis
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Glenn, thanks for the quick response. I was hoping it was something I could fix, but this appears to be some internal solenoid in the transmission. Any idea what the quoted service time is for this repair? What the parts? I don't mind going to the dealer, but I like to have a good idea of what to expect.
    thanks, Todd.
  5. #4
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    20 times
    Rep Power
    1673
    No idea, the solenoid in question must be gotten to by dropping the tranny drain pan.
    ~Glenn
    Yes I am a pirate!
  6. #5
    Join Date
    Aug 2003
    Location
    Memphis
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    I understand. If I can resolve the issue by replacing the solenoid, do you know if the check engine light will clear itself?
  7. #6
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    20 times
    Rep Power
    1673
    Quote Originally Posted by ToddStyles
    The Check Engine Light or Malfunction Indicator Lamp (MIL) comes on when the ignition switch is turned ON and the engine is not running. When the engine is started, the MIL should go off. If the lamp remains on, the diagnosis system has detected a malfunction or abnormality in the system.
    In addition to the MIL lighting up when a malfunction is detected, the applicable Diagnostic Trouble Codes (DTC) prescribed by SAE J2012 are recorded in the ECM memory. If the malfunction does not reoccur in 3 consecutive trips, the MIL goes off automatically but the DTCs remain recorded in the ECM memory.
    The trick is the solenoid may not be the culprit. There are prescibed diagnostics to identify the root cause. I gave you the basics.
    ~Glenn
    Yes I am a pirate!
  8. #7
    Join Date
    Aug 2003
    Location
    Memphis
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Glenn, thanks for your expertise. My buddy called this morning and the MIL is no longer on, so it looks like it was a glitch that cleared itself. I did some research last night and it appears that there was a TSB issued for his truck, "EG024-02", that addressed the P0770 code. However, I couldn't see the details associated with the TSB.
    Todd.
  9. #8
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    20 times
    Rep Power
    1673
    Todd.
    Seeing details of tsb's comes with a club membership subscription.
    However, this TSB reads "Some owners of 2002 model year Tundra trucks equipped with V6 engines and automatic transmissions may experience a M.I.L. “ON” condition with DTC P0770 (Shift Solenoid “E” Malfunction) stored when operated under the following specific operating conditions:
     Operation in ambient temperatures above 90 degrees F.
     When towing a trailer or carrying a heavy load.
     When climbing a long uphill grade.
    The ECM logic (SAE term: Powertrain Control Module/PCM) has been revised and the transmission valve body has been improved to prevent this condition from occurring.
    transmissions produced BEFORE the Production Change Effective VIN 5TB#N##1#2#######
    Applicable Warranty*:
     R & R ECM (PCM) repair is covered under the Toyota Federal Emissions Warranty. This warranty is in effect for 96 months or 80,000 miles, whichever occurs first, from the vehicle’s in-service date for ECM (PCM).
     R & R of the Valve Body is covered under the Toyota Powertrain Warranty. This warranty is in effect for 60 months or 60,000 miles, whichever occurs first, from the vehicle’s in-service date.
    ~Glenn
    Yes I am a pirate!
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
