V8 Oil Capacity
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: V8 Oil Capacity
  1. #1
    Junior Member dano100's Avatar
    Join Date
    Jul 2002
    Location
    Bucyrus Ohio
    Age
    63
    Posts
    69
    Liked
    5 times
    Rep Power
    13
    Question V8 Oil Capacity
    According to the owners manual the oil capacity in my '04 DC is 6.5qts. with filter. Most vehicles have a 5qt. capacity so I put a tag on the oil cap so that the local Quick Lube doesn't short me a quart and a half when I get my oil changed.
    I had my truck at McDaniel Toyota today for a check engine light (a faulty 02 sensor) and they saw the tag and informed me that the V8 takes 7 qts. I questioned the service manager and he went back and asked the technician who said it is 7 qts.
    I have always checked my oil level the day after it is changed and it is always at the top fill line. So who's right, the owners manual or the Toyota service technician at McDaniel Toyota?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Assistant Administrator nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    23 times
    Rep Power
    1673
    Quote Originally Posted by dano100
    Drain & Refill with Oil Filter Change - 6.2 liters (6.5 Us qts, 5.5 Imp. qts)
    Drain & Refill without Oil Filter Change - 5.7 liters (6.0 Us qts, 5.0 Imp. qts)
    Dry fill - 7.1 liters (7.5 Us qts, 6.2 Imp. qts)
    Reference - page 704, 2004 TOYOTA TUNDRA Repair Manual (RM1091U)
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  4. #3
    Junior Member hirschg's Avatar
    Join Date
    Dec 2003
    Location
    Pittsburgh, Pa.
    Posts
    72
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by nhparrot
    Every time I have changed my oil and filter it took 7 qts to reach the full line on the stick thats what I have gone by
  5. #4
    Junior Member Diablo's Avatar
    Join Date
    Nov 2002
    Location
    Fort Worth, Texas
    Age
    50
    Posts
    213
    Liked
    1 times
    Rep Power
    13
    It always takes 6.5 quarts when I change my oil and filer. I just changed it last weekend and again, 6.5 quarts to fill it.
  6. #5
    Junior Member Desertnate's Avatar
    Join Date
    Jun 2004
    Location
    St Louis
    Posts
    119
    Liked
    0 times
    Rep Power
    11
    6.5 quarts filled up my Sequoia too.
    What I find interesting is my 2.5L I6 BMW enginge takes 6 quarts of oil and my 4.7L V8 Toyota engine takes 6.5.
  7. #6
    KLS
    KLS is offline
    Supercharged Member KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,492
    Liked
    4 times
    Rep Power
    17
    I use a Toyota filter (not an oversized filter), and I just dump in 7 quarts. If the sump is a fraction of an inch overfilled it is not a big deal.
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
  8. #7
    Junior Member Matador98's Avatar
    Join Date
    Feb 2004
    Location
    Santa Maria, CA
    Age
    34
    Posts
    391
    Liked
    0 times
    Images
    20
    Rep Power
    12
    Quote Originally Posted by Desertnate
    That's nothing. My 87 land cruiser with a 4.2 tractor engine takes 8.1 quarts
    2006 Tundra DC, 80K, K&N Drop-in, Spintech Truck/RV Muffler, BedRug, Bilstein 5100s, VSE Sub
    Previously 2000 Tundra, 94K, K&N Drop-in, Spintech Truck/RV Muffler, Hellwig, Bilstein 5100s, 2005 Sequoia Center Console Installed and looking awesome! - TOTALLED
    1999 UZJ100 Land Cruiser, 225K, new carpet, no major Mods planned; it's the wifeys
    1987 FJ60 Land Cruiser, 209K, K&N Drop-in, Jacobs Ignition, Jacobs Wires, Dynomax Muffler and Hi-Flow Cat, Electric Fuel Pump Conversion, Rebuilt Carb, Rebuilt Combination Manifold, SS EGR Tube, Someday...A Lift
    Proud Member of the CBTMA
  9. #8
    Join Date
    Jun 2004
    Location
    St Louis
    Posts
    119
    Liked
    0 times
    Rep Power
    11
    Quote Originally Posted by Matador98
    That is what I found interesting...I would have thought bigger engines would take more oil. In my non-mechanic brain I would reason a 4.7L, or lets round to 5.0 for this example, would take twice as much oil as a 2.5L since it has twice the displacement, two extra cyclinders, and much bigger internals to lubricate.
    So does my 2.5L have a huge capacity or is the 4.7 run lean
    8.1 quarts...Good grief that is a lot of dinosaurs...
  10. #9
    Join Date
    Feb 2002
    Location
    Silicon Valley, CA
    Posts
    1,802
    Liked
    2 times
    Rep Power
    15
    I've got an oversized filter on mine (Amsoil SDF15)and I kept the shorter dipstick over the longer one so I get 5mm more oil in there (Toyota says that doesn't harm the engine) and I put in 8 quarts of synthetic every fill to top it off to the line. Actually I put in a little more because I'll pour in some fresh oil while the drain plug is out to flush out the last of the dirty oil from the engine.
    I use maybe 3mm of oil on the dipstick between changes at 7,000 to 12,000 mile change intervals. (I'm running synthetic).
    Alan
  11. #10
    Junior Member Pistolero's Avatar
    Join Date
    Jul 2003
    Location
    Kansas City
    Posts
    174
    Liked
    0 times
    Rep Power
    12
    I had an '84 Mitsubishi Montero 2.5L 4 banger that took 6 quarts. I thought that was an awful lot for a 4 cylinder. But, I don't think it's so much the engine size as the design and volume of the pan.
  12. #11
    Join Date
    Jan 2004
    Location
    Oceanside,CA
    Posts
    704
    Liked
    0 times
    Rep Power
    12
    Mine takes 7qts with a drain\refill and Toyota filter change. Make sure your getting the right filter. 90915-YZZD3.
  13. #12
    Join Date
    Dec 2004
    Location
    Rindge, NH
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Unhappy Oil Level
    So who can tell when its full??? I've got a 2004 Tundra and the dipstick is VERY difficult to read. The residual oil on the walls of the guide tube makes it look like it's got more oil than it contains...
  14. #13
    Supporter sequoiasoon's Avatar
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    45
    Posts
    1,232
    Liked
    3 times
    Images
    8
    Rep Power
    13
    Quote Originally Posted by osmosis
    don't reinsert the dipstick right away after the initial wipe. 45 seconds or so normally lets enough drip down making it easy to read.
  15. #14
    Supporter ThomasE's Avatar
    Join Date
    Feb 2002
    Location
    San Jose, CA
    Posts
    371
    Liked
    1 times
    Rep Power
    14
    I changed my oil and filter today and refilled 6.5 qts which brings the oil level halfway between the min & max on the dipstick. 7 qts would bring it up to the max. 6.5 or 7 qts., either will be fine, the half qt won't make any difference.
    TRUCK: 2001 2WD V8 AC MODS: JBA headers! Magnaflow muffler, TRD 4x4 coils & shocks, Wheeler's AAL's, Truxedo bed cover, Bridgestone Dueler AT LT265/75/16, Surepull hitch, Drawtite convertor box, MAPP nerf bars, Toyota bed mat
  16. #15
    Junior Member maxtorqe's Avatar
    Join Date
    Feb 2003
    Location
    Woodbridge
    Posts
    52
    Liked
    2 times
    Rep Power
    981
    Default V8 Oil Cap Drain & Fill
    I use AMSOIL SDF 57 filters (exact replacement) and a drain and fill takes about 6.5 to 6.75 Qts. Over 12,000 miles it may "use" about 2-4 oz. of oil.
    - Max
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
