NGK vs Denso Iridium or Platinum plugs
+ Reply to Thread
Results 1 to 8 of 8
Thread: NGK vs Denso Iridium or Platinum plugs
  1. #1
    Join Date
    Aug 2002
    Location
    Atlanta, GA
    Posts
    56
    Liked
    0 times
    Rep Power
    14
    Default NGK vs Denso Iridium or Platinum plugs
    Has anyone tried the NGK Iridium plugs in their V8 tundra and if so are you pleased with the performance and gas mileage? I see that the Denso Iridiums dominate the discussions but the NGK iridium is almost half the cost of the Denso.
    For those of you who use platinum, are they just as good as the Iridium with the performance and gas mileage
    Thanks
    JCS
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Dec 2003
    Location
    lexington, ky
    Posts
    222
    Liked
    1 times
    Rep Power
    512
    I put NGK Iridium IX in my 01 Sequoia and 95 Avalon about 2-3 months ago. Feels that the engine runs a little smoother, sounds smoother, after installation on Sequoia. I bought it because I do not like changing plugs often. Iridium should last longer than regular copper. I dont think there is a change in gas mileage in Avalon or Sequoia.
    Previous to Iridium, the Avalon has platinum for 60K. The Sequoia has copper plugs, but not sure for how long since I just bought the truck last year.
    Thanks
    Chris
    01 Sequoia and 95 Avalon.
  4. #3
    Fellow Tundra Owner RitcheyRch's Avatar
    Join Date
    Aug 2002
    Location
    Santa Clarita
    Posts
    1,838
    Liked
    36 times
    Images
    2
    Rep Power
    2680
    I use the NGK v-powers in everything I own and have never had a problem.
  5. #4
    KLS
    KLS is offline
    Supercharged Member KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,492
    Liked
    4 times
    Rep Power
    17
    We need two guys who both need plugs in their trucks. One guy installs $1.59 Denso copper plugs and make some speed runs. Take those out and put in the iridium plugs and make some speed runs. I don't think you'll see much difference, but who knows? If there isn't any difference, the guy whose idea it was to buy the expensive plugs gets stuck with the cost of them.
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
  6. #5
    Veteran Member big-o's Avatar
    Join Date
    Feb 2002
    Location
    Point of the Mountain, UT
    Posts
    1,041
    Liked
    7 times
    Images
    14
    Rep Power
    57
    Your talking about the same plug manufacturer. Toyota has been running those plugs for years. The only difference you will notice is with plug life! The iridium will last 50k plus, and the standard will need to be replace at 15k. You might notice a difference if you ran a hotter version with a supercharger or turbo.
  7. #6
    Join Date
    May 2003
    Location
    napa, ca
    Posts
    203
    Liked
    0 times
    Rep Power
    13
    I am running the NGK iriduims on my 2k V8 SR5 and no performance gain. My reasoning for putting them on was longevity of replacement interval. My wifes LX 470 factory recommendation are iriduim plugs. Same engine with a higher compression. Factory recommended plug replacement is 90k miles for here LX 470 ride.
  8. #7
    Join Date
    Aug 2002
    Location
    Atlanta, GA
    Posts
    56
    Liked
    0 times
    Rep Power
    14
    Thread Starter
    Thumbs up
    Thanks to all of you for the info. I will probably go with the NGK Iridiums vs the Denso becasue of the $ difference. I can get the NGK Iridiums here in Atlanta (NOPI AUTO PARTS) FOR AROUND $6.25 EACH.
    jCS
  9. #8
    Join Date
    Jul 2006
    Location
    bay minette, al
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Default Re: NGK vs Denso Iridium or Platinum plugs
    I have set of the Iridiums in my 01' Tundra. Been in there for about 100,000 miles. Just looked at them last week figuring it was about time to change them but they still looked like new. Well worth the few extra bucks. The first time I had the plugs changed I made the dealer do it (BIG MISTAKE!) I asked them about the Platinum / Iridium plugs but they refused citing warranty B.S. $150 bucks. OW! Fool me once. The next time I put the Iridium plugs in myself. (only took about 10 min. easiest plug change I hav ever done) The next time the dealer looked at the mileage and told me it was time to change plugs I told them (never mind I did it myself) but I didn't tell them I had put the Iridiums in it. A cleaner plug burns more efficiently and gets better mileage and performance. I HIGHLY reccomend them!
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. 07-28-2010, 06:04 AM
  2. 06-02-2010, 07:28 AM
  1. ND iridium plugs
    By DA86 in forum Engine, Intake, Exhaust, Induction
    Last Post: 04-30-2007, 09:48 PM
  2. New Plugs
    By nhparrot in forum Engine, Intake, Exhaust, Induction
    Last Post: 10-20-2006, 10:14 PM
  3. Denso Iridium = stalling?
    By Caspian in forum Engine, Intake, Exhaust, Induction
    Last Post: 08-13-2002, 04:44 AM
  4. NGK Iridium swap from Denso stock
    By Imdone in forum Engine, Intake, Exhaust, Induction
    Last Post: 06-16-2002, 11:43 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
