Battery died.. Changed it.. Now won't idle.
+ Reply to Thread
Results 1 to 14 of 14
Thread: Battery died.. Changed it.. Now won't idle.
  1. #1
    Join Date
    May 2003
    Location
    HB
    Posts
    21
    Liked
    0 times
    Rep Power
    13
    Default Battery died.. Changed it.. Now won't idle.
    Came out after a couple hours of being parked and my truck wouldn't turn over. the interior lights were dim so I tried to jump it but it didn't work. So I went to Pep Boys to get the battery tested and it was dead. So got a new battery, put it in and the car turns over and on, but will not stay on or idle. If I hold the gas on it will but as soon as a let off it dies. Can anyone help me.....
    Thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Justme's Avatar
    Join Date
    Mar 2006
    Location
    Windsor, CO
    Posts
    242
    Liked
    0 times
    Rep Power
    10
    Default Re: Battery died.. Changed it.. Now won't idle.
    My guess is (and it only is a guess!) when the battery was changed, the powertrain computer was cleared out of any learned performance from the engine and you need to drive it several times to give it a change to re-learn how your engine performs. I believe it takes 3 cycles for it fully re-learn. I forget what qualifies as a cycle (so many miles driven followed by some amount of time) I believe if you drive it for a couple days it will be back to normal.
    2006 Tundra DoubleCab 4X4, Donahoe 2.5" Coilovers, Donahoe AAL, Procomp rear shocks, JBA Headers, Magnaflow 14586, WAAG Brush Guard, BakFlip, LineX Bedliner, Clear Bra, Window Tint, E7007 Navigation, VSE subwoofer!!
  4. #3
    Join Date
    May 2003
    Location
    HB
    Posts
    21
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    How am I going to drive it if it won't stay on.....
  5. #4
    Supporter Picasso's Avatar
    Join Date
    May 2004
    Location
    Dallas, TX
    Posts
    643
    Liked
    9 times
    Rep Power
    250
    Quote Originally Posted by mtzerofive
    Thanks.
    A agree with Justme but would go a little further. To me these symptoms suggest that your engine might simply need a little maintenance. I would look at things like the MAF sensor, throttle body, spark plugs, and air filter. When were these last cleaned/changed? No need to answer here, just something to consider. Make sure ALL of your vacuum hoses are secure as well.
    My train of thought is this:
    Your ECU gradually adjusted to the reduced performance of one or more of these components as they degraded through normal operation. When the ECU trim tables were erased with the battery change, the component(s) needing maintenance were now apparent since the ECU was no longer compensating for them.
    I'm no expert, but your symptoms are very indicative of your truck needing maintenance on the above mentioned components.
    Let us know what you find out.
    Good luck.
    Paul
    Completed Mods:
    S&S long tube headers
    Brembo rotors
    TSB caliper upgrade
    Hawk LTS brake pads
    Stainless steel braided brake lines
    Total Chaos steering rack bushings
    Alignment to DJ's specs
    Century cap
    Line-X
    XM satellite radio module (connected to Pioneer head unit)
    Instrument cluster LED upgrade
    Future Mods:
    Rearview camera system
    BA Muffler (on order)
    Sound deadener
    Fusion Drive
    Flux Capacitor Control Unit (FCCU)
  6. #5
    Lurking Member Dubya's Avatar
    Join Date
    Jan 2006
    Location
    Mar Vista
    Posts
    31
    Liked
    0 times
    Rep Power
    10
    Does the HB in your location stand for Hunington Beach? If so I work at a great shop in Manhattan Beach. PM if your interested.
  7. #6
    Join Date
    Apr 2005
    Location
    San Diego
    Posts
    35
    Liked
    0 times
    Images
    1
    Rep Power
    11
    Red face Re: Battery died.. Changed it.. Now won't idle.
    I agreed with these guys. There should be a way to reset your computer to the default factory setting but I'm not sure what it is.
    Also, check the poles on the battery and make sure you were not given a battery with reversed polarity!
    Eastwood makes a computer and alarm "saver/setting gizmo" that uses a 9V battery into the cigarette lighter so that when you change your battery your do not lose your settings.
  8. #7
    Junior Member drewbush's Avatar
    Join Date
    Jan 2004
    Location
    Redondo Beach
    Posts
    152
    Liked
    0 times
    Rep Power
    12
    Turn the key to the second detent (the actual run position, not start position) and let it sit there for about a minute. It may need to relearn the throttle stop.
  9. #8
    Join Date
    Nov 2004
    Location
    San Diego, CA
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Check the fuses too.
  10. #9
    Junior Member derone's Avatar
    Join Date
    Jul 2003
    Location
    Raleigh, NC
    Posts
    183
    Liked
    0 times
    Images
    6
    Rep Power
    13
    You may want to pull the rubber elbow off the throttle body and clear the bore(s) where the throttle blades contact it. The blades might be getting stuck in the gunk in the bores.
    Doug
    '01 tundra TRD SR5 4x4 access cab, rear Helwig sway bar, front poly end-links, poly rack and pinion bushings, temp/compass mirror, '05 tail lights, JL audio stealthbox and amp, 6x9 Sony rear spkrs, TO-25 door tweeters, new '03 TRD coilovers w/daytech 3/4" poly spacer, rear HD-Bilsteins, all weather mats, rear seat mod, Draw-Tite bugshield, and TRD limited-slip diff.
  11. #10
    Join Date
    Jul 2005
    Location
    leesburg, va
    Posts
    195
    Liked
    0 times
    Rep Power
    11
    i had the same prob after i ran batt dead by leaving ig key on. what fixed it for me was removing the battery connections for about ten minutes, then putting back on. truck idles fine again
  12. #11
    Join Date
    Sep 2007
    Location
    San Diego
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Smile Re: Battery died.. Changed it.. Now won't idle.
    I too had the same problem. Changed the battery and it would not idle. Tried the suggestion to remove the battery cables for ten minutes. It worked like a charm. Thank you so much, this saved a tow to the dealer and money to fix the problem.
  13. #12
    Veteran Member Hi Volt's Avatar
    Join Date
    Aug 2007
    Location
    Langley, BC
    Posts
    554
    Liked
    70 times
    Images
    7
    Rep Power
    8222
    Quote Originally Posted by dennis4djb View Post
    A reversed polarity battery would not allow the engine to run at all, let alone no idle. The idle problem is one of two issues, a miscalibrated MAF - clean it and do a computer reset. The second issue is the low speed fuel pump resistor mounted on the driver fenderwell. When the RPM is brought up a relay bypasses the resistor for full pump speed, at idle the pump is designed to slow down through the resistor. It the resistor is bad or unplugged, the pump will not run at idle, however will do the normal prime during key on which will give the initial startup each time. Check the connector, and fuses.
    Two issues using one of these 9V battrey gizmo's:
    1 - The key must be in at least the acc position for the cig lighter to work( unless you have done the bypass wiring) otherwise the 9v battery is not connected to the vehicle's electrical system.
    2 - Don't leave your door open while doing this, otherwise the interior lights will kill the 9v battery off in seconds. Seen this so many times and it was always blamed on a bad 9v battery ! Go figure.
  14. #13
    Join Date
    Feb 2008
    Location
    Arcadia, CA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Hi Everyone,
    I know this thread is from 4 years ago ... however, I found it during my research ... therefore, I wanted to share my experience (which just happened today) as well. Hoping it may help others who find this thread as well.
    I replaced the battery on my 2002 Tundra today, and my car also started to die on idle. I wasn't sure what to think. So I feared a possible Fuel Injector issue. I went to PepBoys, and once I was there to get Injector Cleaner ... I spoke with one of the Mechanics. He told me the computer needed to reset, and to just turn the Air Conditioner on (to increase RPMs) and let the car idle for 5 minutes.
    Unfortunately, my Air conditioner didn't increase the RPMs much ... so I held down the gas peddle on 2,000 RPMS for about 10 minutes. After that, the car stayed on with the Air Conditioner (almost died without it on). So with the Air Conditioner on, I went to a drive on the roads/freeway ... got back about 15 minutes later and all was working well again (with or without the air conditioner on). I have driven it around and started it multiple times today, and all is as it should be (or at least as it was before the battery swap).
    Therefore, much like some of the posts above, it was all about helping the electronics reset and remember what they had to do.
    Hope this helps someone else as well. Before the advice from the mechanic ... I was starting to plan my trip to the dealership, and thinking what that was going to cost.
    Back from the dead! Gutz's Avatar
    Join Date
    Apr 2009
    Location
    SoCal
    Posts
    1,778
    Liked
    4 times
    Images
    24
    Rep Power
    1717
    Should have bought a Ford. LMAO...
    2007 RCSB |5.7 | TRD SC | JBA Headers | Auburn LSD
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Weird Problems With My Battery Please Help!!
    By Jeremy in forum Electrical & Computer Systems
    Last Post: 02-18-2006, 12:04 PM
  2. Changed Plugs...Now a Slight lump in the idle....?
    By TheGryme in forum Engine, Intake, Exhaust, Induction
    Last Post: 12-02-2005, 10:49 AM
  3. my battery died which do I get?
    By uracowman in forum Electrical & Computer Systems
    Last Post: 08-11-2005, 03:24 PM
  4. HOW-TO: Tundra - Installation of Optima Blue Top Battery w/Stock Battery Tiedown
    By DevinSixtySeven in forum 1Gen-Member Mods, Build Threads, Write-ups
    Last Post: 09-23-2002, 09:44 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
