Diagnostic codes PO441&PO446
+ Reply to Thread
Results 1 to 8 of 8
Thread: Diagnostic codes PO441&PO446
  1. #1
    Join Date
    Jan 2005
    Location
    Nor Cal
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Default Diagnostic codes PO441&PO446
    Hi,
    I need some help resolving a Check engine light condition.
    I rented the Code reader, and I'm getting PO441& PO446. Plus a pending version of both of them. I read a series of posts where a VSV and charcoal canister problem were diagnosed. Do you know what these two codes mean together?
    After reading old posts, I'm wondering if overfilling the gas tank last night might be the problem. If the canister is blocked, will it free itself, after the level in the fuel tank comes down? If the tank is flooded will the fuel evaporate out and return to normal?
    Thank in advance,
    Don Coulter
    San Leandro Ca.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    SAS'ed #5 dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    36
    Posts
    6,561
    Liked
    396 times
    Images
    119
    Rep Power
    26436
    Default Re: Diagnostic codes PO441&PO446
    Try checking for any loose, disconnected hoses. Start at the EVAP system and work your way out.
    Clear out your PM box. I tired PMing you with some additional resources.
  4. #3
    Join Date
    Jan 2005
    Location
    Nor Cal
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Turns out it was an overfull fuel tank. Burning some gas seems to have taken care of it.
    Thanks,
    Don
  5. #4
    Supporter TwinStop's Avatar
    Join Date
    Oct 2004
    Location
    Twin Falls, ID
    Posts
    243
    Liked
    0 times
    Rep Power
    11
    I have also have codes PO441 & PO446 and I am not lucky enough have a full tank. I am in the habit of filling my tank up to the very top of the filler tube. Anyone have the diagnostic procedures and the location of the items I'm diagnosing. For a 2001 tundra with 4.7
    Thanks Mark
    Spin tech 3224XL, JBA Cat4ward® Headers, JBA Titanium Header Coating, Powertrax No-Slip, CR Laurence Co.® Sliding Window, Powered by Unichip, PC2150 ODYSSEY® Drycell battery, TruSpeed Speedometer Recalibrator, Peel™ & Seal
    6"x25' Roll Self-Stick Aluminum Faced, stubbswelding.com SKO Tundra access cab rock sliders with the heavy duty legs, LT265/75SR16 C Dueler A/T REVO with UNI-T AQII Technology, WHEELER'S Tundra 4X4 Performance Front Coil Set, Hellwig Anti Swaybar, Ivan Stewart grill.
  6. #5
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    36
    Posts
    6,561
    Liked
    396 times
    Images
    119
    Rep Power
    26436
    Quote Originally Posted by TwinStop
    Thanks Mark
    This is related to your EVAP system. Black box with a bunch of hoses coming out of it, near your brake booster, reservoir, etc. I know there is a troubleshooting checklist in the Subscriber Forum. Look in there. If you haven't found it, I'll look for it later.
  7. #6
    Join Date
    Oct 2004
    Location
    Twin Falls, ID
    Posts
    243
    Liked
    0 times
    Rep Power
    11
    Quote Originally Posted by dyogim
    Thanks I was crawling under the truck looking for it. I have looked but haven't found the checklist. Since TS changed the garage I've had a heck of a time finding info.
    Mark
  8. #7
    Join Date
    Oct 2004
    Location
    Twin Falls, ID
    Posts
    243
    Liked
    0 times
    Rep Power
    11
    Looks like it was a loose hose. I was tugging on hoses and connections and ended up with a hose in my hand, so I'm assuming the other end was disconnected I hooked it back up and flipped the switch on the unichip to clear codes and all looks good so far.
    Thanks Mark
  9. #8
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    36
    Posts
    6,561
    Liked
    396 times
    Images
    119
    Rep Power
    26436
    Thanks Mark
    Exactly what happened to me....At least it was an easy fix.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Clearing diagnostic codes?
    By jrfiero in forum Highlander
    Last Post: 10-25-2007, 08:11 AM
  2. Service History Operation Codes ?
    By highalti2d in forum Avalon
    Last Post: 10-01-2005, 02:32 PM
  3. Pulling Codes of the Computer
    By JustinH377 in forum Engine, Intake, Exhaust, Induction
    Last Post: 12-05-2004, 05:45 AM
  4. Clearing codes on Sequoia?
    By beachcomber_bill in forum 1Gen-Sequoia
    Last Post: 10-28-2004, 02:13 PM
  5. INFO: Sequoia AC/Heating System Diagnostic Trouble Codes
    By nhparrot in forum Knowledgebase Archive
    Last Post: 03-16-2003, 10:59 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
