Originally Posted by ejsfj
how about GPS
NO GPS for the 07, it interferes with the drivers sight.
The 08 dash has been redesigned.
The accessory (altimeter/compass) meter can be added but the dash pad needs to be changed also. The wiring should be there, but you'll have to check. It doesnt show a wire harness without accessory meter, so I assume it is wired for it, but it shows different a dash for it.
25 yrs with TOYOTA
