I am training for an ironman and as such have lost my keys with Fob and my backup set too! I have a 2007 FJ cruiser. I purchase 2 semi-used ones from
ebay and 1 from keyless rides. Using the followoing procedure I was able to program 1 from
ebay and the keyless ride one:
- drivers door open unlocked
- insert key an dreomove 2x
- close and open driver door 2x
- insert key and reomove from ignition
- close driver door
- insert key trun to on then to off and remove
- locks cycle
- press and both lock and unlock simulktaneously on transmitter for 1s
- then press and hold unlock on transmitter for 2 secs
- locks cycle
- transmitter programmed.
This procedure work for the
ebay and the keyless ride one. the second
ebay one I got all the way to the locks cycling once but then got no response after holding both lock unlock and then unlock for 2s which means not programmmed.
This would have been the fifth programmed transmitter ( 2 originals, 3 repLAcemeNts) Is that th eproblem? If So, How do I remove all programmed and start fresh?
Both units from
ebay were
fcc id:hyq12ban
canada:15511021295
rss-210
denso
unti from Keyless was
fcc#HYQ12BBX
IC#1551A-12BBX
DENSO
i WOULD THINK THE CANADA # MADE A DIFFERENCE BUT i WAS ABLE TO SUCCESSFULLY PROGRAM THE FIRST ONE i BOUGHT. I need help. I do not understand why I can not program this last transmitter? I have 3 more weeks to Ironman and surely am at risk of losing another fob! I also tried the pdf. programming option whereby you manually flip the locks 5x, etc. This procedure did nto work at all. Please help!!
