Originally Posted by skisurf2
Would you buy a Fj or H3?
What do you think is a better buy for the money?
What do you think of the 5 cyclinder inline 5 vs Toyota's V-6?
You can't get the answer here. You're on the FJ forum! Besides, you have to check them out for yourself.
I will tell you this, though. The FJ rides much better onroad than the H3. The frame on the FJ is much stiffer. Toyota did a wonderful job on this. It feels like a unibody, even though it is a body on frame. The H3 is based on the Colorado pickup chassis, and the frame is flimsy. No, you won't permanently twist it, but it jiggles going down even a smooth road.
In a pure offroad environment, the H3 starts shining. Contrary to what the Detroit News says, the H3 has a much tighter turning diameter, 37 feet, vs. 41.8 for the FJ. It also has a 4.03:1 low range vs. the FJ's 2.566:1. That along with the 33" optional tires, it is better for extreme rock crawling. Overall, though, the FJ will do just about everything the H3 will. It all depends on how hardcore you are.
The H3 five cylinder engine has more vibration than the FJ V6, especially between 1500 and 2000 rpm. The FJ also has more power, although that changes in 2007, when the H3 gets bumped to 242 horsepower, surpassing the FJ's 239. The H3 has 400 pounds more to haul around, so acceleration will still fall behind for the H3. Mileage is about the same for both, but the H3 uses regular, rather than premium for the FJ. The FJ also has a 6 speed manual, vs. the H3's 5 speed.
Both have poor visibility, due to the narrow windows. Both have wind noise at highway speeds with the flat, vertical windshields. Both are quite good for road noise.
The interiors are as different as night and day. The FJ is best described as rugged utilitarian, which is quite functional, while the H3 is more car like and plusher. You can even get leather in the H3. The radio is a lot better in the H3, too.
As far as value, the H3 is probably a better buy, because you can get those at invoice, while you'll have to pay MSRP for the FJ for a while. I would expect the H3 to depreciate more, so if you keep it five years or more, you may come out better with the FJ.
Don't forget to include the new 2007 Jeep Rubicon in your shopping. It promises to be an awesome offroad machine. It will be available in two and four doors. No pricing is available yet, but it will probably be close to a loaded FJ 4WD.
Good luck!
Michael
