Go Back   Toyota Tundra Forums : Tundra Solutions Forum > SUV Forums > FJ Cruiser
Old 06-23-2006, 06:50 AM
FJman's Avatar
Dealer : Waipahu Toyota
2007 Toyota FJ Cruiser
Last Online: 07-11-2007 06:21 AM
FJman is on a distinguished road.
FJman's Photo Albums
Default Check Engine Light warning - Gas Cap
I had my check engine light come on yesterday. Took it to the dealer today and they said it was caused by the locking gas cap I put on. They said that if the cap is not tight or if you overfill the gas tank, the check engine light will come on. Apparently, the aftermarket locking gas caps do not provide an adequate seal and will cause the check engine light to come on which the dealer's service dept. may have to reset. They told me to put the original Toyota gas cap back on and drive 3 cycles of 4 miles to see if it will reset the light by itself. Toyota does not make genuine Toyota locking caps but their parts dept. sells the "Stant" brand locking gas caps which I was using. According to them, this is a known problem. Anyone else had this problem?
Old 06-23-2006, 01:39 PM
Dealer : Lee's Toyota
Last Online: 01-04-2007 09:24 PM
Mutine Bullfrog is on a distinguished road.
Mutine Bullfrog's Photo Albums
Default Re: Check Engine Light warning - Gas Cap
It's true. If the gas cap isn't on properly the check engine light will come on. I've had it happen on a number of new cars.
Old 06-23-2006, 05:46 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
We sell STANT locking gas caps. My dad has had one on his 2005 Tundra DC since week 1 and has no problems.
He also has one on his 2006 Prius.
According to STANT they do not make a locking gas cap yet for the FJ.
What part number did they sell you? It may not be for the FJ even tho it fits.
EVAP SYSTEMS are very critical anymore and everything has to seal and perform as designed by toyota.
25 yrs with TOYOTA
Old 06-25-2006, 04:23 PM
Dealer : Arlington Toyota Scion
2003 Toyota 4Runner
Last Online: 10-19-2006 01:51 AM
skisurf2 is on a distinguished road.
skisurf2's Photo Albums
this is a common problem on all makes and models. Most makes will reset themselfs after so many engine on and off cycles or unhooking battery for awhile. I have had this problem with stock fuel caps aswhile. I drive a frod company vehilce. It just started it at 98,000 miles, took it in and they said it was gas cap. The company I work for didn't replace it, I now have 110,000 on the vehicle, just covered the light with black electrical tape.
Check Engine Light? vegasgreed Engine & Drivetrain 22 07-31-2006 08:33 PM
Check engine light/bad gas? WillardBubby Tacoma 5 07-31-2006 07:45 PM
2001 4WD 4 banger check engine light hatcherb Highlander 2 03-02-2006 11:52 AM
Loss Of Power/Check Engine Light wgreene63 Engine & Drivetrain 10 01-12-2004 08:23 PM
Check Engine Light Kirbybus Engine & Drivetrain 11 05-08-2003 01:03 PM
